  • Antworten 121
Hmmmm:
non ha più un solo segmento come per i precedenti modelli, ma è provvisto di due segmenti cromati in ghisa S10 con caratteristiche specifiche per ottimizzare resa e prestazioni nel tempo.
"It does not have solely one pistonring like the precedent models, but it is foreseen for 2 chromed pistonrings"
2 Kolbenringen :-D
AL
google translated:
THE CONTINUOUS TRADITION The Polini Motor has developed a thermal group with absolutely unknown piston for Vespa P200E. The cylinder is characterized from the fusion in grafitica cast iron to lamellare autolubficante and antiusury. Draft of a particular cast iron in which the granelli of grafite of the fusion they are distributed in finer way. This characteristic offers an extraordinary mechanical resistance and reduces thermal stress of the motor. It eliminates eventual decrease of power. It improves the lubrication. It favors the sliding of the piston. It resists to the elevated temperatures of exercise. It maintains in the time the own mechanical characteristics unchanged. The distribution diagram is unknown. The lights of travaso are of new conformation. They assure absolutely performanti performances. Greater cue and resumption. Better distribution of the power to every regimen of spin. The drainage light favors the evacuation of exhaust gaseses optimizing the yield of the motor, above all to the high and medium regimes. The piston is the synthesis of an advanced entire new plan. It is distinguished for being to high turbulence and is directly derived from the competitions. It comes fused for gravity to high silicon tenor. A single segment like for the previous models does not have more, but it is supplied of two segments chromium plates to you in cast iron S10 with specific characteristics in order to optimize rendered and performances in the time. The head is fused in light alloy. E' characterized from the squish specific for elevated performances. Kit the Polini for Vespa P200E comes delivered complete of series packings.
Also auch ein zylinderkopf dabei!!! :love: steht im letzten satz
FREU! :-D
warum nich gleich den englischsprachigen artikel nehmen? :-D
TRADITION GOES ON
Polini Motori has developed a new cylinder kit for Vespa P200E with a brand new piston. The cyclinder is die-cast in self-lubricated lamellar graphitic cast-iron. It's a particular cast iron where the grains of graphite are much smaller and finely distributed in the die. This eliminates eventual loss of power, improving the lubricating. Smoother piston movement. Resistant to the highest temperatures. No mechanical problems after long time of using. New distribution diagram. Transfer ports with a brand-new design and conformation grant very good performance. It optimises the pick up when starting, the power output at low and medium rev. The exhaust port optimises the evacuation of combustion gases optimising the engine performance, at low and medium rev. The piston is the synthesis of a brand new project. It distinguishes itself to be at high turbulence and it comes from race style. The piston, gravity cast in high silicon content light alloy, is fitted with two "S10" chromed cast iron piston rings assuring longer life and optimising the engine efficiency. The head is die cast in light alloy. It features a specific squish for high performance. The Polini kit for Vespa P200E has provided with a complete gasket serie.
ups, johannes war schneller...
Bearbeitet von jochen0407
Hab den Zylinder und den Kolben da liegen sehen...
Der obere Ring ist ein L-Ring. Sah überhaupt schwer nach nem Pinasco-Kolben aus.
Falls es im englischen Text steht, war zu faul, alles zu lesen... :wasntme:
Edit meint noch, Kopf lag keiner bei
Bearbeitet von chris69
cooool! mehr wissen will!
polossi für arme
das wär ja ein ding :-D
vermutlich habens einfach den pinasco kolben
der ja auch an asso ist in den zyl verpflanzt
@chris69
wo hast den gesehen?
Am Polini-Stand auf der Intermot.
Wir haben aber auch schon gemutmaßt, daß die sich von den Kollegen von Pinasco nen Kolben geliehen haben, damit einer mit 2 Ringen dabei liegt, auch wenn der eigene noch nicht fertig is...
Die waren aber alle so beschäftigt, daß ich dann auch keine große Lust hatte ewig zu warten, um nachzufragen...
hab mal polini angemailt, obs ned a richtigs foto hätten :-D
edith 1
stoffi hat ihn auch gesehen
kriegt bald welche :-D
edith 2
in ö hat kudlicka die polini generalvertretung
sobald da gibts detailfotos :-D
Bearbeitet von freakmoped
Würde mich mal interessieren wann das Teil dann auch wirklich zu haben ist und zu welchem Kurs.
Scheint noch was zu dauern, wenn es keine Bilder gibt und der Kolben in der Auslage nur geborgt war!
Wenn es keine großen Änderungen am Zylinder gibt, würde ich zumindest mal den Kolben bestellen. Bin aber auch gespannt ob ein brauchbarar Kopf dabei ist.
vielleicht hab ichs ja überlesen, aber wenn der Zylinder immer noch aus GG is, dann hat man die gleichen Probleme wie vorher auch! dann kann der Kolben das schönste Schleifbild haben und die tollsten Ringe, aber Leistung wird er trotzdem nicht ab können!
für mich jetzt schon ein Flopp, wenn immer noch aus GG!
bei Zyliköpfen haben wir doch eh schon den besten Lieferanten.
Polini hätte mit uns zusammenarbeiten sollen um mal einen Malossikiller auf die Beine zu stellen. :-D
@freak
es geht hier doch um den Polini 208. das hat mit den kleineren doch gar nichts zu tun. Meine Kritik richtet sich an den 208er. Das die kleineren Zylinder gut halten, weiß ich doch :grins:
genauso mit dem Überströmlayout. wenn der unten am Fuß immer noch so kleine Eintrittsfenster hat, isja auch wieder von Nachteil wenn nix durch kommt.
mir persönlich gehts um Leistung und Haltbarkeit und die sehe ich mit GG nicht.
...dann augen auf!
polossi und GS-Kolben haben bewiesen daß es am kolben liegt
(abgesehen davon daß man von den kolbenfehlern des polini hier genug lesen kann)
Und wieso sollte der Große nicht haltbar sein, die Kleinen aber schon. Kann kaum am Material des Zylinders liegen. Wenn ich den Artikel richtig verstanden habe, hat das Teil ein komplett neues Kanallayout.
GG hat einfach einen prinzipiellen Nachteil bei der Wärmeableitung und beim Gewicht.
Beides wiegt bei den Vespen, insbesondere bei den Largeframes für mich so schwer daß ich nicht mehr GG fahren werde.
Bin aber sehr auf den Kolben und Kopf gespannt. Und in 20 Jahren gibts den Kit ja vielleicht in Alu :-D
Grüße
Hannes
Wärmeleitung! genauso seh ich das auch.
bei den kleinen ist der Wärmehaushalt wohl besser geregelt! eventuell mehr Kühlfläche im Verhältnis zum 208er bei gleichem Luftmassenstrom usw.
und wieviel läßt sich mit einem GS Kolben im Polini holen?
bei unter 24-25PS sind auch keine allzu großen thermischen Probleme zu erwarten!
ihr könnt fahren was ihr möchtet, meine Meinung zu dem neuen Kit ist einfach, dass wenn da wieder GG verwendet wird, keine haltbare Mühle draus wird, wenn ich Richtung 30 Ps gehe. bzw. auch mal ne gescheite Verdichtung zu realisieren die ich auch beim Kicken spüre usw. davon bin ich einfach enttäuscht.
für störungsfreie 20 Ps langt auch das bisherige Material, denn Nacharbeiten wird man auch beim neuen Kit machen müssen. so wie bei nahezu allen Sachen an der Vespa.
Kann man das Topic nicht mal in ein "allgemeines Largeframe Neuheiten der Intermot- Topic" umnennen? :-D Will gerade kein neues Topic aufmachen:
Bei meinem Rundgang am Sonntag fiel mir ein Federbeinhersteller namens I.M.C.A. auf, der neben dem originalen Geraffel für Vespa auch Gasdruckfederbeine herstellt, die ähnlich den Bitubos aussehen.
Farblich sind die Blau gelb.
Hat da einer Preis / Leistungsinfos zu???
Fotos hab ich mitm Handy gemacht, könnte ich die Tage hochladen.
Gruß Dirk
In Italien wardie 200er nie interessant - daher hat sich auch Polini nie viel darum gekümmert! Erst recht nicht um besondere Nachbearbeitung, einen besseren Kolben,...und schon mal überhaupt nicht um die Beseitigung der Konstruktionsmängel: solange sich der Hef´n verkauft, ändert Luigi nichts!
Der 208er hat nie hohe Stückzahlen (im Polini-Maßstab!) erzielt und Wachstum ist nicht zu erzielen damit..., also kein Handlungsbedarf...
Ihr glaubt doch diesen Dampfplauderern hoffentlich nichts: Der Hef´n kommt wie die meisten anderen Gußzyl. aus der gleichen Bude wie seit ewigen Zeiten, mit der gleichen Technik...! Seit jeher wird immer von einem neuen Guß erzählt - war aber nie anders, nur immer noch mieser verarbeitet für noch mehr Kohle!
Auch das Märchen vom neuen Kolben geistert nun seit gut 15 Jahren herum - gesehen hat den bis heute niemand, oder?
Den Pinasco-Kolben hatten sie schon ´94 bei Messen dabei, der paßte nicht mal in den Zyl..
:uargh:
Ich laß mich immer gerne überraschen, aber an den Weihnachtsmann glaub ich nimmer... :wasntme:
die ansage von herrn polini, dem alten dampfplauderer, war, so ich ihn den recht verstanden habe nicht dass der zylinder sich ändern würde sondern dass der kolben ab fühjahr 2007 bei gleichbleibender bestellnummer durch einen neuen ersetzt werden würde. mir, und mutmaßlich auch ihm, fehlt natürlich die lange, bis ins vorgeburtliche zurückreichende befassung mit dem thema. einen märchenerzähler wollte ich ihn aber trotzdem nicht schimpfen. bis auf weiteres würde ich ihm das einfach mal abkaufen was er da erzählt hat.
chris 69 und stoffi haben ihn gesehen auf der messe und
letzterer sagt lt mail von heute daß er bald welche bekommt :-D
schauma einfach mal
schauma einfach mal
dirk und ich etwa haben ihn auch gesehen, ich meinte das mit der information direkt aus dem munde von herrn polini im übrigen durchaus ernst.
wobei, die frage ist ob der gesehene kolben auch in den zylinder passt ggg
Der gesehene Kolben kam aus dem Mund von Herrn Polini persönlich? :-D
Da gilt wahrscheinlich, wie bei der 54er Mazzu Welle für SF: chi vivrà vedrà!
    • Ich würd gern meine Beton-Aussentreppe an der Hauswand mit Holz verkleiden, also hauptsächlich die Stufen.   Ich hätte einfach Terrassendielen mit Gummipads drunter hingespaxt. Wegen mir mit Abdichtung oder Spezial-Aussendübeln vom Wüath.   Jetzt findet man da erstaunlich wenig Anleitungen und Infos zu in diesem Internetz, vor allem aber irgendwelche Statler und Waldorfs, die laut „lebensgefährlich weil rutschig“ und „niemals in den Beton bohren“ krakeelen.   Macht man das wirklich nicht?
    • Hallo Ich habe noch was... Der 1/2 LC Twin von Lambretta-Lutz läuft... und hier die erste Kurve... (bitte nicht die Delle um 6000 diskutieren) Das ist 100% geschraubt und gesteckt, nix geschweißt - wenn ich wollte könnte ich den Motor wieder in 2h komplett auf die 6PS -125ccm LI 2 bringen, wie der Motor mal 1960 sein Leben gestartet hat - aber wer will das...? Das mal Faktor 1,9 habe ich nun schon 66PS LC Twin auf dem Smallblock - nicht geschnitten, nix versetzt... Dann hat man bei 6000 auch wieder mehr als 20PS...  In 14Tagen werde ich mir den Zylinder vornehmen - und dann auf max Leistung trimmen... mal sehen... wo die Reise hingeht... Beim Monza bin ich bei 27PS gestartet und auf ü40PS gekommen - hier starte ich gleich bei 35PS -> Da waren bei Monza schon x Stunden, porting und testen notwendig.  Die Kurve da oben, war die 4. Kurve nach dem Zusammenstecken. Gestartet bin ich mit 27PS und einer "Scheißkurve"... mit einem 35mm Mikuni... Dann habe ich den Keihin von meinem Chimera runtergeschraubt und 'ne neue Zündkerze - da waren es schon 32PS. Noch 1-2 Änderungen und das wars... wie gesagt - da oben ist erst die 4. Kurve...! Die "Adapter/Spacer bold-on Lösung";  die 58/125mm Welle (noch nicht mal verschweißt) halten also auch bis 10500rpm - zumindest ist ja weder was abgerissen, noch mein Knie vom beschleunigten Zylinder zertrümmert  (stehe ja immernoch vor dem Motor, wenn ich die Dynos mache ;)  Restlichen Infos auf meinem Kanal...
    • Farbenraten auf digitalen Fotos, aufgenommen mit unbekanntem Weißabgleich, betrachtet auf nicht kalibrierten Monitoren und nicht unter Norm-Licht-Bedingungen, ist wie Topfschlagen im Minenfeld... kann funktionieren, muss aber nicht.
    • Hab das nun auch auf 9,0mm aufgebohrt und der Kabelstrang ging mit etwas Flutschi sogar mit Hülle durch.
