Benjamin25
    25
Alle Inhalte von Benjamin25
  1. https://youtu.be/T7mWmQT_Mcs
  2. Yes, available from Smartcarb EF 26/27 50$
  3. Hi there, I have my 28 smartcarb spitting gas into my air filter while driving. The carburettor is well adjusted. If anyone has had this problem, what is the solution to solve the problem. Thanks
  4. I have also installed it on vr-one engine cases
  5. Yes, Polini 158 mm
  6. Hi there, I'm looking for a metering rod EK-29, if anyone has this, it's cool
  7. How much have you leaned out the clicker. Normally for the E-k series metering rods the baseline setting is around 108 clicks from full rich, for a length of 2.760 inches. There are 150 total clicks.
  8. I have just replaced my Pierbourg pump with a Hardi self-regulating pump
  9. This is the exhaust brigade of the 206
  10. J'ai installé une pompe Pierbourg E1F. Je l'ai connecté à la batterie DC 12v, via un interrupteur à clé
  11. I have just installed an electronic fuel pump on my engine and the Smartcarb works like a charm, it doesn't spit out fuel anymore.
  12. For those who use a 28, what metering rod did you use
  13. for what uses a 28, what metering rod did you put on it?
  14. Hi, I just fitted a Pinasco Touring kit 206cs on Malossi vr-one crankcases, I did my first test drive today, despite some problems with my smartcab and that it is in break-in, the engine pushes hard.
  15. Hi, I have a smartcarb 28, it spits gas in the air filter and I have a lot of trouble to make a good adjustment from 2/4 to 3/4 throttle opening.I read that there was a float adjustment, where is it possible to find the technique.Thanks for your help
  16. Hi, I asked a few questions to Pinasco and they answered me, I'll share that with you. have a good day
