keuk
    409
1 Benutzer folgt
Über keuk
  • Geburtstag 02.10.1979
  • Geschlecht
  • Aus
    FRANCE
  • Scooter Club
    S.P.R.T
4.845 Profilaufrufe
Leistungen von keuk
pornstar
pornstar (5/12)
105
  1. Printed with solid / reliable et airproof MJF technology out of PA12. For 160GT or Spanish models with intake on the casings. Shipped from France. 10€ extra for shipping. Or available in Magnycours Endurance race or if you pass by Bordeaux 30€
      • 1
      • Like
  2. I made a batch of modified PX caliper carrier. This model has a 8mm offset for the shock absorber so it's easier to fit it on small and largeframes. The area where you fix the shockabsorber is also twisted of 2° so the shock can doesn't touch the caliper. CNC, aluminium 5083, sandblasted and anodized, speedo plug like original. Designed to fit perfectly with BGM pro SC shock asbsorber for PK (the clamp measure is 23mm, it's 22,5 on the PX model so you would have to modify the carrier a little because it's 22,8) Price 220€ + 6€ shipping from France screw Available in black or warm grey
  3. @karren77 yes that's it, what a pain to remove clutch basket and spider to get access to the shaft. I'm interested of course. @Das O Apparently there were advantages using it, so probably the access, don't know about the ON/OFF issue which was supposed to disappear with ProX plates.
  4. Marco doesn't have this limited edition any more, and Gravedigger doesn't reply.
  5. Hi, were can I get a Liedolsheim edition basket ? Greetings
  6. And the + 4 version of the FALC works also ? Just for my knowledge. I ordered the CR. This one: One more Time thanks Heizer bezeichung falc 58mm vertex kolben: 23384400 ktm sx / exc 144 pro BB 58.00mm
  7. Ohhhhhhh sorry misanderstood, you are right, like Tim said, D400 4mm is the overisize of the 54 not +4mm high...sorry !
  8. their reference is the D400, +4mm double rings, I think you use the DA
  9. Do you have a problem with your keyboard or are you very hungry ? Yes there is a dealer, BIHR, retailer for the shops, but the reference is not available on their website. I need to investigate more.
  10. I think I will create an Without custom fees furthermore
  11. Argh, 45£ shipping for a Wossner.
  12. If I make a 1/100 chamfer, they will remove everything with the honing tool before plating, won't they? I mean the actual scratches look deeper than 1/100.
  13. 58mm first generation piston BY SCAURI with centered pin.
