415 -
Alle Inhalte von keuk
Polini EVO 130ccm - was kann er wirklich?
keuk antwortete auf wheelspin's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
Hello, Can I cut the base of the barrel to fit with the casing intake ? Is it ok if the lower part of the piston goes a little bit further than the blue line ? (Transfert ports are not yet ajusted)- 3.925 Antworten
- Polini evo
- steuerzeiten polini evo
- (und 3 weitere)
keuk antwortete auf Kotzerider's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
Hello! I have a curious thing on my et3...I have the original electronic ignition, but the timing change ! The timing should remain the same but when I throttle it increases of 5/10 degrees to a new stable value...Is it normal ? ( I use a stroboscopic light connected to an external battery) -
Hello, What is the good torque to tighten the nuts of the cylinder head on this aluminium cylinder ?- 3.925 Antworten
- Polini evo
- (und 3 weitere)
Hello, I hesitate between two kind of crankshaft for my Polini Evo racer with engine casing intake. I hesitate between a plug'n play crankshaft or a full circle one that I would have to modify. At the beginning I was interested by the DRT Sprinter model, but I realise that the shape is very different of the reworked models that I have seen on the Polini Evo thread. Here is a scheme of the DRT model, it lets the full access in the casing maybe a bit late. Here is the model from the Polini Evo thread: It allows to open the access sooner than the DRT one, but I would have to reworked and then to adjust the balance of a full circle one... I'm still undecided.. -
So for a daily use, is it better to have 185 or 180 with 30* blowout ( with pm40 / koso 28 / lighter flywheel...) ?- 3.925 Antworten
- Polini evo
- (und 3 weitere)
It's gonna be thick !!! Even without touching the transfert ports of the cylinder.- 3.925 Antworten
- Polini evo
- (und 3 weitere)
Original flywheel, and even reduced Sip flywheel don't pass !!! I should have known !! I wil have to machine a chamfer...... Timings without any gasket: 180/120 Timings with base 0,5mm gasket 182/123- 3.925 Antworten
- Polini evo
- (und 3 weitere)
I would like to adjust the timings to use it with a PM40, If I remember rightly I should have 185 to the exhaust.- 3.925 Antworten
- Polini evo
- (und 3 weitere)
Thanx for the advices guys !- 3.925 Antworten
- Polini evo
- (und 3 weitere)
Thanx ! -
The original is already 68/69% (56,7mm barrel with 43mm width)- 3.925 Antworten
- Polini evo
- (und 3 weitere)
Hello, For a daily use, and a good torque, is it better to keep the original Polini EVO exhaust shape and just add a few millimeters (to increase de blowdown to 185°) or to change the shape as the third one ? Maybe the third is better for a race use ?- 3.925 Antworten
- Polini evo
- (und 3 weitere)
Hello, What is the connecting flange diameter on a PM40 exhaust ? -
No no these are all the dimensions I took on the cylinder, exhaust hight, laterals hight, and cylinder hight, I deduced the squich with these values and the theorical "64" "64,5"... Next week I'll know the truth. By the way, is it better/easier to machine the cylinder head or the cylinder to adapt the squich ?- 3.925 Antworten
- Polini evo
- (und 3 weitere)
Das ist sehr richtig.- 3.925 Antworten
- Polini evo
- (und 3 weitere)
I have checked the timings of my Polini EVO cylinder on solidworks. I'm not really close of the timings in the Polini assembly instructions notice... There are two versions, one with 64mm between the crankshaft axis and the base of the cylinder and one with 64,5... I don't know yet how much I have on my engine but in both case I haven't use the gasket (I have added 0,1mm for the Dirko / Loctite for the gaskets). I think in any case I will have to use the 0,5mm copper gasket because there is no clearance between the matting surface of the cylinder head and the top of the cylinder... So the squich will be 0,3/0,5mm higher.. Well, it just a simulation, it will be probably different once I will put it on the engine casing. But the squich is very very secure.- 3.925 Antworten
- Polini evo
- (und 3 weitere)
[Smallframe] ENgine casing dimension
keuk antwortete auf keuk's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
Thanks ! -
Sure, I'll take more or less this measure and adjust it to find the same timings annouced by the manufacturer, (here the 126/178° of the Polini EVO) then I will check how many millimeters I have to increase the exhaust port to have 30° blowout. (that's just a simulation I'll take the correct timings once I have access to my engine). I think it should be 1/1,5mm. Thank you ! So when the manufacturers annouce the timings of their cylinder it will differ on each engine casing right ? -
Meine winterprojekte: Before: Jetzt: I have added spot weldings to the clutch basket to fit the DRT clutch without having to bend the last cork discs... But maybe the fitting of the clutch will be harder. We'll see. More coming soon.
keuk erstellte Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
I would like to work on my cylinders' timings on solidworks. There is one dimension I don't have. Any one knows the distance between the crankshaft axis and the original upper surface of the engine casing ? Thanx. Antoine -
[Smallframe] Polini oder Parmakit oder M1
Eine neue frage: Now that I have both cylinders.... M1 and Polini EVO, is the M1 a good choice to replace my old full machined Polini iron cylinder on my racer ? I have to choose between a upper size for my GS piston or something else...so maybe the M1 should be a possibility. -
Alles klar, danke ! -
One more question, I just took a look on the official manual, the Polini EVO has the same timings than the M1, 178/126, is there a big difference between both cylinders ? Of course the price, but for the performances ? -
Thanks for the advises guys ! So it will be a Polini evo to stay in the Polini family with my racer ! I will try to get rid of the M1 then... -
So it would fit like that ? (That's a Photoshop)
