keuk
    409
Alle Inhalte von keuk
  1. Hi, I'm a member of the french scooter forum Scootentole, here is a pre-summer project. It's a 28mm manifold that i made for my smallframe so that i can use 28er Koso carburetor on my polini manifold. I bought a 28mm PX intake made by polini that i have cut, i have welded it on a 12mm aluminium plate and then i began the machining work with my dremel. I use this intake with tassinari reed. Antoine
  2. True, thanks for the picture, it gives me a better idea of it. Actuality when i saw the scootRS picture, the interior of the seat seams strange.. I found another model a long time ago on ebay.uk, maybe a better quality:
  3. Hello, Has anyone tried this ancillotti seat ? ScootRS Ancillotti Seat I like the form but i don't know about the quality and what it will look like on a smallfame. Antoine
  4. Yes it seams to be a good idea... i will test that. W4AC is more for a plug and play polini. Thanx
  5. I ride a smallframe with machined polini (+5mm..), Malossi Gravediggerised cylinder head, pm40, Koso 28, polini manifold with tassinari reed, spark W4AC, HP4, 4th DRT, Cranck Mazzu anticipated, Ratio 2,86. I tried this setup Mainjet: 132 Slowjet: 38 Neddle: JJJ 2nd clip position from the top Air screw: 1,5 It works nice but the spark looks a bit white.... I tried 138 for main jet but i have to put the first position for the clip ans the sparks remain white..... Do you thing it could come from the slowjet, or i maybe should try the JJH needle ... Keuk Machine
  6. Damned... too late. It doesn't matter i'm gonna use the tassinari block. Antoine
  7. Ok, should i change this distance with my Koso 28 ? (measure called x on the following picture)
  8. I would like to use the malossi manifold with my pwk 28. If i keep the venturi part it creates a big break... would you use it ? Thanx Antoine
  9. Hello, Anyone knows the difference between the Koso 28 and the Koso 30 origine Needle. One is a 78-A for the 28 The other is a N68 - A... (Koso30) I only found "N68" models for my setup, maybe it isn't the good ones... Thanx
  10. Hello, i'm looking for a polini 24er reed manifold for my smallframe, if anyone has this part please let me know.. Thanx Antoine
  11. Thank you, on my 19 reeds i found 18mm, on my 24 i think it the same measure than yours.
  12. Someone could give me this measure ? Thanx
  13. Hello, Are there differences between the carbon part of the "colletorre lamellare reed manifold" 24 ans 19 ? Thanx Antoine
  14. Hi ! Anyone knows the size of the S1 used on this scooter ? Or the schwalbe on this one They look bigger than 90/90-10, isn't it ? Thanx
