409 -
Alle Inhalte von keuk
Alles Banane? Sip Road, Malossi Powerclassic, BGM Banane?
keuk antwortete auf Basti_MRP's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
Hi, I looked closer at the BGM exhaust, the pipe goes from Ø26 at the exit of the cylinder up to Ø40 at the entry of the body . On the SIP road I have Ø28 / Ø36. (inner diameters) I hesitate to mount the BGM on my polini evo on which my cylinder outlet is a little over Ø28. An opinion ? -
Motovespa 160 + GT - Modellkunde, Motoren & Tuning
keuk antwortete auf Crank-Hank's Thema in Vespa Rally, Sprint, VNA, VNB, VBB, V125, etc.
Hi, I'm about to buy a 160GT and something intrigues me. Are there different versions of the front panel? I have the impression that there are narrow models and normal models as on Europeans models. For example on the 160 in the middle, a 1st serie then, the front panel look narrow compared to the two others. Optical illusion ? -
@wheelspin, what is the difference between the BGM PRO BANANE TOURING and the BGM PRO BANANE RACE? -
Das europäische Rollerforum -
Dope! Danke !
Befindet sich die Xyger-Platte für die PK XL2-Kupplung noch? Es gibt das Modell DRT bei 10pollicci, aber mit den Versandkosten kostet es ein Vermögen.
Top ! So it fits with 3.5 tires ? -
Have you ever tried the BGM PRO sport ? https://blog.scooter-center.com/fr/pot-dechappement-banane-de-malossi-pour-vespa-pv125-et3/?utm_source=newsletter&utm_medium=email&utm_content=MEHR+LESEN&utm_campaign=newsletter-classic-de I wonder if the inner tube at the cylinder exist is bigger than the Sip road.
Thanks for the advices, I will work on this points.
The spark looks great, but the floor of the scoot is really greasy. I can try something, but when throtling at max during big distances the behaviour was ok. I can test few points less. I will also test the mono reeds in the manifold. And in a second step, I'll try a bigger carb to see the difference, I have a Koso28 with a 28mm intake.
I haven't modified the wideness of the exhaust, original shape what like this, and already 70% I will control the timings to see, for the squich I have 1,1mm. I would like to keep a 19mm for a good fuel consumption, it was around 4,3L/100km this week end,with a lot of 3/4 gear in backcountry. I could test a PHB19 or remove the Polini airfilter and put a bigger mainjet. I have added the curves to compare with the original engine.
Hi, Here is my ET3 130 project, which has now only the stickers from an ET3. It works well on the road but there is still room for improvment, I hope you can help me. The main idea is to keep and original look/noise. So a banana style exhaust is what I would like to keep. On the road to the Rallye des Gones. I have the following setup: Polini Evo original timings, only bigger transfert ports, exhaust fitted to SIP road diameter Casing machined, from an old racer engine Polini intake manifold with SHB19 with polini airfilter Mazzu crankshaft PK 12v ignition with lightened PK flywheel (serie pro I guess ?), 17° Ratio 2,76 4th short BGM 48 teeth 3.5 tires I did a rotronic test last week end and get this before the hard disk crashed: 10,7 hp at 6700rpm 12,3 N.m (1,254M.kg) at 5814rpm (only the last one is good, we forgot to calculate the losses related to the gearbox on the others). There is a second peak after 8000 so I wonder if I could do something to optimise it. On an standard engine Sip did this dyno: 7,7hp / 5612rpm 10,5N.m / 3640rpm Is there any informations / threads / dynos with the sip road exhaust ? Thanks for your advices. Greetings from France Antoine
SF kupplung Hartz4 bzw. Hartz5...........
keuk antwortete auf gravedigger's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
What spring do you guys use for the primary cover disc ? Edit: Alright, I got my answer from Marco, Overrev green or BGM PRO. -
keuk antwortete auf Kotzerider's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
How come it is sliping in 4th and not on the other gears ? -
Hi, I have a problem on a daily evo / sip road / DRT tree / DRT 8 springs clutch, when in charge in 4th gear, there are small slippings, the 4th stay engaged but it behave like if I was pushing the clutch lever. The clutch cable isn't too tight (in each gear), I have clearance on the clutch lever. What could it be ? -
Hello, I have an old Hartz4 with a FAIO ECO christmas tree and FAIO primary with needle bearings, and the christmas tree goes too deep in the spider. The spider fits nicely on an original christmas tree Does a spider with smaller cone exist ? Right now I have a 13/15 cone. -
Innenrotorzündung für Vespa
keuk antwortete auf dr. vespa's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
Thank you, I will try this. Envoyé de mon iPhone en utilisant Tapatalk -
Hi, I have a 13° grad PVL for a racing scooter, what is the classic setup to use ? How much degres at 3500/4000 for example ? I have a Wforce58x54 with 127/193 timings. Thank your very much. Antoine -
AF Parts Achsaufnahme iVm BGM PRO SC/F16
keuk antwortete auf Lenki's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
Hi Lenki, What upper plate did you mount ? Do you have an offset of the center hole ? About the 1mm clearance, the largeness in the aria where you mount the shock should be the same than on the original piaggio. You can use a spacer to correct this. You can make your own or buy one from sip or sck, I think I saw this part, I have to check. -
Hello, Could someone give me the dimensions of the speedo gear in a LML hub ? Internal / external diameter & lenght. Thank you very much. -
Zündung Polini Evo digital
keuk antwortete auf salih's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
Here are the curves from the Polini website: http://www.polini.com/dep/PI454.pdf Curves fall between 8 / 9000 depending on the curves compared to the PVL with digitronic which curves fall at 7000. -
Hi, What is in theory the best thing to do when setting up the variable ignition ? dealing with the kick at 6/7000 or looking at the power pic arround 9/10000 ? I made an excel with the different ignition possibilities to try to understand. PVL 13° Ref 1443 PVL 22° Ref 1077 PVL 3° Ref 1442 + Malossi Digitronic Vespatronic I played with the offsets corresponding to the stator position on the casing, to bring the curves closer to be able to compare them.
