409 -
Alle Inhalte von keuk
Ok, thanks. So once you have the STL file, there are softwares able to recreate basics geometries, like plan, radius, // between axis, screw hole etc.. right ?
Hello, Do anyone knows how Quattrini, Falc and SIP proceded to make their engine casings ? Did they use a 3D scan of an original casing and then make changes on a 3D model or did they recreate a full new and editable 3D model ? Maybe each one add a different technic ? It would interest me a lot to understand the process. I don't know if the 3D scan technology is able to recreate plane surface, cylindric shape with axis (for the correct position of each elements of the bearings ...) that you can use after in a 3D software like solidworks to make sketches and new geometries. I found this picture of the SIP model on google, the model is so close to the geometry of an original one that I have doubts and I would like to understand.
Results are there: http://www.chronolux.net/classements/2013/SCOOTENTOLE/index.htm
Polini EVO 130ccm - was kann er wirklich?
keuk antwortete auf wheelspin's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
Damned even with a CGN (2nd position from top) and 48 iddle jet, I still have the problem. Anyone is using a leaner that 45 jet on a Keihin33 ? However, after a little google search, when checking the float level, the float should not be depressing the spring loaded float valve pin, that the mistake I did above. I should have titled a little bit the carburator until the float tab just makes contact with the valve pin.- 3.925 Antworten
- Polini evo
- steuerzeiten polini evo
- (und 3 weitere)
Ok... the float level wasn't good, I had 14mm instead of 16mm, so I have modified it. But I still have the same symptom. I'll try the CGN tomorrow. Is it normal that the float needle spring is fully compress by the weight of the float ?- 3.925 Antworten
- Polini evo
- (und 3 weitere)
So the idle jet was a Keihin48, I tried a Unknow44 one without touching the air screw, and the engine is still able to start without the choke. It's a choke with lever at carburator. The setup (Evo adjusted/Franz/Keihin33(150/CGL)/Polini mono reeds/Stroh intake).- 3.925 Antworten
- Polini evo
- (und 3 weitere)
Keihin33 with 48 idle jet.- 3.925 Antworten
- Polini evo
- (und 3 weitere)
Guys, my evo starts without the choke, what should I adjust first ? Iddle screw , iddle jet, neddle ?- 3.925 Antworten
- Polini evo
- (und 3 weitere)
Ausfälle Smallframe (2010 bis heute)
keuk antwortete auf dorkisbored's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
outch ! -
CNC gefrästes Smallframe Motorgehäuse...
keuk antwortete auf v31's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
keuk antwortete auf Patricks's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
Oh that was exactly what I was wondering today unmounting my evo, the shape isn't optimum but I hesitated to make it smaller to reduce the deformations. So the main idea is like this right ?: -
What is a Knubbel ? -
You are C.R.A.Z.Y !!! -
10h Scootentole at Magnycours 2012... teeth party ! https://www.facebook...152864961419492 -
It seems that the pin is angularly moving in his housing, so the overlap sounds plausible ! -
Ausfälle 2011, the piston pin doesn't look brocken though... -
Angle on PK steering column's lever
keuk antwortete auf keuk's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
Interesting point of view. So I should compress the shock at the maximum, and ensure that the lever is just before horizontal position (arround almost90°/column) to have a good breaking effixiency right ? -
Perfect, I have just cut the column, now I need to make machine a part to put inside, what thickness are you guys usually using ? 2mm? 3mm? More ? There was a thread talking about that but I'can find it... -
Well I'll try the 30mm first as a dummy. The 35mm looks a bit too much. -
Thank you for the answer Tim, Now, with the wheel on the ground and me on the scooter, the angle is almost 90°. -
I have the S&S part (-18mm) and a own plate (-18mm) so -36mm on the RS24. Here are few tests to see what the angles would look like. Steering column 19mm shorter: Steering column 30mm shorter: Steering column 35mm shorter: -
Hello, I'm about to shorten my PK XL steering column. Could anyone give me the original angle of the lever ? (wheel in the air) Right now the lever is too horizontal, so the wheel is about 1cm backwards.
Polini 130 Mono Sommer-/Winter-/Sommerprojekt
keuk antwortete auf Jonas B.'s Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
Good idea, are they homemade plates ? -
Membranwellen: Umarbeitungsmöglichkeiten
keuk antwortete auf undis racing team's Thema in Vespa V50, Primavera, ET3, PK, ETS etc.
Anyone is using the AMRacing model? It should be a good alternative to those who aren't at ease with a grinder or a saw ? http://www.amracingitalia.it/e_scheda_articolo.asp?idarticolo=257&InVendita=True
