Svint1
    512
Über Svint1
  • Geburtstag 20.10.1978
Contact Methods
  • AIM
    Svint1
  • MSN
    Svint1@hotmail.com
  • Website URL
    http://www.roughnecks.no
  • Geschlecht
  • Aus
    Norway
  • Scooter Club
    Roughnecks Scooterclub
6.275 Profilaufrufe
Leistungen von Svint1
pornstar
pornstar (5/12)
32
  1. Hi, Sorry for asking for something that has probably been asked numerous times before.... Can someone please guide me to someone who is building/modifying PK-forks for SS180 that actually fit the fender and rideheight? Thanks!
  2. Hi, currently building my Explorer-engine, but I’ve run into a problem with the flywheel. It’s a ele-start flywheel that has been machined down, but apperantly not enough as you can see in the picture. My question is if I can remove some material from the cylinder without breaking through?? rgrds øyvind
  3. I've already rebuilt the engine with a new gearbox, and the noise in 4th is now gone. Just have to mount it in the frame and test it on the road.
  4. Hi, Newly built Polini130-engine with full circle crank, Egig clutch, PHBH24 on reed and original gearbox. Engine runs very very good in 1st and 2nd gear, but jumps in and out of gear when in 3rd. And very bad noise in 4th. -big «clunks» like someone is hitting the casings with a hammer. The same noise in 4th without engine running, also with clutch engaged.
  5. Mines a Polini XL2. Guess it is Dremel-time then to rectify...
  6. Hi, Just fitted the complete Egig one-finger-clutch in my Polini130-engine with Polini XL2 cover.... But the clutch touches the clutch cover (similar as it would on a normal V-cover), So I had to fit a 1mm spacer to make it spin free... So apperantly something wrong. -any tips? Rgrds
  7. El Sidney lives in Norway now, in my workshop. -awaiting a full rebuild. 😉 And potentially for sale… 🫣
  8. Hi all, First, sorry for english, aber mein deutch sind sehr slecht.... I've got a M244 (60mm quatt crank, 24/63 on original gearbox, keihin28 standard ignition and SB sport3) for the moment in my SS180 Going to build a M265 on VR-one with MRP cnc reed with Vape static. (hope it is ok to ask even if not 260 but 265...) Either the SB box or a Polini box (going to try both) Will a PHBH30 be sufficient? (trying to get great milage) A lot of my touring is with my PAV41 behind the scooter, so I'm not looking for peak horsepower, but tourqe for steep Norwegian hills and mountains... Rgrds Øyvind
  9. Yes, that is absolutely an option as well! Do you know how the Vespa color codes translate into "modern" color codes? Ø
  10. Thanks! Sorry, forgot to mention; it is a 1994 PX200.
  11. Hi, Can someone please advise me on this color? Need the code to be able to order touch up paint... Sent from my iPhone using Tapatalk
  12. Thanks madmax! At least I/we've narrowed down to two tones... I'll see what I can find out.
