Svint1
    512
Alle Inhalte von Svint1
  1. Hi, Sorry for asking for something that has probably been asked numerous times before.... Can someone please guide me to someone who is building/modifying PK-forks for SS180 that actually fit the fender and rideheight? Thanks!
  2. Hi, currently building my Explorer-engine, but I’ve run into a problem with the flywheel. It’s a ele-start flywheel that has been machined down, but apperantly not enough as you can see in the picture. My question is if I can remove some material from the cylinder without breaking through?? rgrds øyvind
  3. I've already rebuilt the engine with a new gearbox, and the noise in 4th is now gone. Just have to mount it in the frame and test it on the road.
  4. Hi, Newly built Polini130-engine with full circle crank, Egig clutch, PHBH24 on reed and original gearbox. Engine runs very very good in 1st and 2nd gear, but jumps in and out of gear when in 3rd. And very bad noise in 4th. -big «clunks» like someone is hitting the casings with a hammer. The same noise in 4th without engine running, also with clutch engaged.
  5. Mines a Polini XL2. Guess it is Dremel-time then to rectify...
  6. Hi, Just fitted the complete Egig one-finger-clutch in my Polini130-engine with Polini XL2 cover.... But the clutch touches the clutch cover (similar as it would on a normal V-cover), So I had to fit a 1mm spacer to make it spin free... So apperantly something wrong. -any tips? Rgrds
  7. El Sidney lives in Norway now, in my workshop. -awaiting a full rebuild. 😉 And potentially for sale… 🫣
  8. Hi all, First, sorry for english, aber mein deutch sind sehr slecht.... I've got a M244 (60mm quatt crank, 24/63 on original gearbox, keihin28 standard ignition and SB sport3) for the moment in my SS180 Going to build a M265 on VR-one with MRP cnc reed with Vape static. (hope it is ok to ask even if not 260 but 265...) Either the SB box or a Polini box (going to try both) Will a PHBH30 be sufficient? (trying to get great milage) A lot of my touring is with my PAV41 behind the scooter, so I'm not looking for peak horsepower, but tourqe for steep Norwegian hills and mountains... Rgrds Øyvind
  9. Yes, that is absolutely an option as well! Do you know how the Vespa color codes translate into "modern" color codes? Ø
  10. Thanks! Sorry, forgot to mention; it is a 1994 PX200.
  11. Hi, Can someone please advise me on this color? Need the code to be able to order touch up paint... Sent from my iPhone using Tapatalk
  12. Thanks madmax! At least I/we've narrowed down to two tones... I'll see what I can find out.
  13. Hi! Anyone who can help me with the color code on my 2007 Vespa PX125? Need to paint the floor due to sand blasting alot of rust... Thanks in advance! Ø Sent from my iPhone using Tapatalk
  14. Ok, thanks! Very usefull information! -I have been thinking of that myself, but wasn't sure... I might try with a SIP Road to check....
  15. Haven’t tried to push it to far above 7k, as it vinrates so much. Sent from my iPhone using Tapatalk
  16. Tried 135, and same vibrations... Sent from my iPhone using Tapatalk
  17. Hi! I have a Polini221 engine that rides very smooth. -never had so little vibrations in a Vespa engine... But that is only as long I don't push it over 7000rpm... -then it starts to vibrate heavily... I'm suspecting that the pick-up isn't all good, and can't deliver proper sparks above 7k rpm. -does that makes sence? Setup; PX200 casing matched to sylinder 60mm crank (unknown brand, bought here on GSF) SI24/24 autolube with nd3,33 and hd128 Standard ignition on 19" Polini box exhaust. Rgrds Ø
  18. Ok, I’ll do! But CHT is around 90, so might not be lean? Anyway, I’ll try Sent from my iPhone using Tapatalk
  19. Original airfilter with drilled holes above main jet and low jet. PS! I've now running 128Hd and 3,33 on slow jet, but still stutters on low throttle....
  20. Hi! Newly built my Polini221 engine... Setup; Polini221 60mm crank Polini box pipe Ignition 19’ SI24/24 with nd48/160 and hd135 My problem is that it still four-strokes/stutters on low rev and a bit in the lower midle.. -even with a 3,33 slow jet?!? The ignition is spot on 19 degrees. Anyone who can help me solve this? Rgrds Ø Sent from my iPhone using Tapatalk
