512 -
Alle Inhalte von Svint1
BGM Big Box on SS180 with Polossi 220 engine
Svint1 antwortete auf Svint1's Thema in Vespa Rally, Sprint, VNA, VNB, VBB, V125, etc.
Yes, it is mostly about the layout. I'll probably rather put it on my sidecar-PX. -with a 57mm alu-Polini... [emoji6]- 10 Antworten
- BGM BigBox
- SS180
(und 2 weitere)
I'm currently using a SIP Road, and it is ok. -but the BigBox is supposed to give some more ooohmp. I could probably use the Silentbox and achieve the same output, but the design of the Silentbox is too bad...- 10 Antworten
- BGM BigBox
- SS180
(und 2 weitere)
Hi Deichgraf and Happy New Year to you too! I'm aware of the S&S sollution, but does a main stand for PX fit a SS180 frame? If so, a swap would solve the case. I already have a Pipedesign exhaust, but a Silentbox220, as Marco recomended that for a Polossi engine. But I'm very dissapointed with the exhaust... -the layout on it makes it hard to turn Right without grounding it, and the sound is allmost like Shito+... And it has the same conflict with the main stand. My impression of the BigBox is alot better. But I need to sort the main stand, so I can continue to tow my PAV...- 10 Antworten
- BGM BigBox
- SS180
(und 2 weitere)
Any suggestions for the New Year??- 10 Antworten
- BGM BigBox
- SS180
(und 2 weitere)
Hi All! I have a 1965 SS180 with a Polossi 220 engine for touring... And for next season I want to upgrade from SIP Road to BGM BigBox... But I can't fit the BigBox, as it conflicts with the mainstand on the SS180 (spring and attachment on spring on the stand...) Any suggestions for how I can have my BigBox fitted on my SS180? (PS, Sidestand is not an option, as I very often have my PAV41 trailer along with it...) Thanks! Ø
- 10 Antworten
- BGM BigBox
- SS180
(und 2 weitere)
12V battery for SS180
Hi, and thanks for the tip! But I might be stupid, cause I can´t find any suitable for the SS180... Looking for something with max dimensions of 165X83X93 Any suggestion where I find it in the link or other places? -
Hi all! Any suggestion for what battery to use on my 1965 Vespa SS180 now as it is converted to 12V? I can´t find any batteries at SIP nor at SCK... Any suggestions? Thanks!
Lucas 576 on Vespa SS180
Har lagt ut noen følerer i UK og, men tenkte det var noen tyskere som kanskje også kjørte ekstra lys.... Men håper fortsatt noen har en god patent... -
Hi all! I got two original Lucas 576 lamps to fit on my 1965 Vespa SS180. But I got some repro rubber mounts that doesnt fit at all. The angle on the rubber is way to steep, so I'll be lighting up the woods and not the road... Anyone knowing how or where to get rubber mounts that fit the legshield of a Vespa SS180? Thanks! Øyvind
Briefkopien-/Gutachtendatenbank
Svint1 antwortete auf Sedor's Thema in Vespa Rally, Sprint, VNA, VNB, VBB, V125, etc.
Hi! Can anyone help me with TUV-papers or similar for my Vespa T4 (VGLA1T)? I need papers for; PX200 engine (with tuning if possible) Bitubos Grimeca Widetyre Thanks! Ø -
Hi, First of all, sorry for writing in English, but my german sucks... Anyway, I have a long-range tank (11,5L) in my vespa and therefore using a mikuni (20l/h) to feed my Keihin 35 on my S&S reed and crank. But somehow there are air in the system and I can only get fuel as long as it is leveled above the carb (just as standard tank) Can someone please help me and tell me how I'll get the pump working properly and get the extra 5 liters out of my tank with the pump? Thanks! Ø
Px200 acting like clutch-seal is broken, but it isnt.
Svint1 antwortete auf Svint1's Thema in Vespa PX, T5, Cosa etc.
Hi, No, I haven't checked the reed-plates. yet. But I haven't been clear; the engine do rev up, but even on high revs, it splutters and doesn't go "clean". But as there was no trace of gas in the oil, I was wondering if there could be other reasons than the clutchseal, as I might try that before i split the engine again... PS! The engine has run only 60kms since last change of seal on the clutch-side... Rgrds, Øyvind -
Hi guys! Thanks for advice! -I'll test with the brake cleaner. I'm using a Keihin PKW35 with RamAir filter. And Dellorto 55l/h fuel-pump due to big gas-tank... Rgrds, Ø -
Hi, No, I haven´t changed it. Would like some suggestions before I start splitting the engine. -again.... Rgrds, Ø -
Svint1 erstellte Thema in Vespa PX, T5, Cosa etc.
Hi everyone! I'm running this specs; PX200 casings and gearbox Malossi 211 + MMW head S&S 60mm crank S&S reed S&S clutch Vespatronic (24-17 Pipedesign Charger But suddenly the scooter behaves like the clutch-seal is broken. (easy going when cold, but when warm it splutters and hardly doesn't go at all) When I checked the gear-oil yeasterday, it was nice and fine, without any trace of petrol. The sealing on the flywheel side is checked and found to be ok. Why does my scooter suddenly act like this? Rgrds, Øyvind -
Hello! Anyone having a silenzer for JL RZ righthand for sale? Not only the end can, but the whole last part of the exhaust... Rgrds, Øyvind
verkauft? Habe interesse.
Hello! I'm looking for a Dellorto PHBH28 or PHBH26 Rgrds, Øyvind
24er SI Vergaser ovalisiert neuwertig
Svint1 antwortete auf kurbelwelle77's Thema in Verkaufe Vespa Teile
Erster! Bitte nach Norwegen. Rest bei PN Rgrds, Øyvind -
Hello! I'm interested in; How much would that be to Norwegen? Rgrds, Øyvind
Hepp! Looking for a Sip Evo exhaust for my Polini218 engine. Rgrds, Øyvind
Hello! I'm currently running my Polini218 engine with a Delly PHBH BS 30mm But to get some better response in lower revs, I will try a 28mm. But the 28mm is a PHBH FD. Beside to plug the intake for the oil-pump, is there anything else I have to do to use the PHBH FD 28mm? (any suggestion for jets, as I'm using a SIP Evo pipe?) Best Regards, Øyvind
HEpp! I'm looking for an standard Vespa T5 exhaust. Rgrds, Ø
Hello! I'm looking for a Cosa Clutch, 23 teeth... Rgrds Øyvind
