vansantvoort
    23
479 Profilaufrufe
Leistungen von vansantvoort
talent
talent (2/12)
  1. ok..thanks.. (tjsa ik heb me eenmaal ingelogd hier onder vansantvoort en das lekker makkelijk..maar hoe heb je opgemerkt dat hjalmar = van santvoort) so Erik, you think gearbox oil doesn't do the job?
  2. Hi, Im restoring my VGLA1t and as unexperienced as i am do not know what the best way is to install the gaskets. Do you oil them with the same oil you put in the pertol? or dou you grease them with bearing grease? or dou you use liquid gasket sealer? I think my casings are in a good condition but what do i need to do to make a good resto? thanks
  3. mm..tsja zo zijn wij hollanders he? nou ja.. thanks all you guys!
  4. mm.damn I was afraid of that.. so what price category are we talking about ? when is it a 'good one'? and as to the damage caused by cheap ones; is that because they're not accurate or for another reason?
  5. ok thanks! the thing is that I don't have the oney to buy a real expensive one..you often hear that buying cheap (30 Euro) ones aren't really accurate and that you can just the same use a normal wrench if you can't spend a lot of money.. what do you think about that?
  6. I'm restoring my 1960 VGLA1t and I don't really know if I should buy a torque wrench for all the bolts and nuts on my scooter..To do a very professional restoration it's very handy ofcourse but I haerd on scooterbbs that unexperienced people that use torque wrenches often do more harm than good..and how necessary is it? Do you guys use them to tighten the nuts exactly like the factory settings? what's your experience? thanks!
  7. ok..so now you say to put the bearings in the case first; it doesn't really matter how to do it I guess .. What do you meanby "ordinary greaese" for the seals; the same bearing grease you use on the wheel bearings? And when putting the crank in the casings with the bearings in first; does it need a lot of force to put it in? And when you just tap it in; will it go in straight or is that kind of difficult? I saw on the internet that you can buy a crank pulling tool..is that very handy or is tapping it in just as easy.. you probably noticed I'm very unexperienced :) Thanks!
  8. OK Thanks!! - when putting the bearings on the crank; do you tap them on with a little hammer and a piece of wood or something or do they just slide on? and how do you know if they are seated coorectly on the crank; in other words; how much space must the be between the crankhalve and the bearing or do they just go on as far as they can go? - another question; what kind of grease do you use when rebuilding a vespa engine; I have vasline or copper gease, bearing grease..and do you use grease on the other parts in the engine as well; the other bearings, the gears and shift rods?
  9. I'm rebuilding a 1960 VBB engine (actually a VGLA1T but I thinks thats the same) and have two questions: 1. When putting the crank in; do you put the bearings on the crank fisrt ( I do not have a special tool for this) and then put the complete assembly in the case halve; or do you put the bearings in the halves first and the put the crank in? 2. Do i need special factory tools? Especially the tools that go on the crank to protect the oil seals when putting the crank in. Do I realy need these? and where can I but them on the inet? I have a special factory manual that shows about 50 very handy tools but I don't know anyone ho has them. I.o.w.: can I rebuild this engine without special tools? Thanks
  10. entschuldigung guys..I am indeed from Holland and my german is very very bad.. thanks for the answers! I guess nobody knows an adress where i can buy an exact replica of the shock?
  11. ok thanks! I could use the extended nut ..but then the spirng is still shorter and thinner than the original one..isn't that a problem; won't there be less shock absorbing power?
  12. Im restoring a 1960 VGLA1T (same frame as VBA/VBB but with 10 inch wheels) and need a new shock. I just can't seem to find the correct one anywhere on the net..i bought one at SIP scootershop but its too short. The pic shows my original one and the "wrong"one.. anybody has an idea wehere to find the correct sized shcok for my scoot? Thanks!
  13. so just heat up the right hand side housing? i mean the one on the flywheel side?
  14. I'm restoring a 1960 VBB but I just can't succeed in splitting the casings. I loosened all the bolts and applied heat to the main bearing housing (around where the crank protrudes) but I can't seem to get any motion in the damn things! This is my first time doing this; does anybody have a good hint?
  15. I'm restopring my 1960 VGLA and want to clean my carburettor. AFter I have taken it apart, can I just clean all the parts with a degreaser? Or can you damage the parts that way? I read something about using compressed air i the Haynes manual but i don't have that kind of facilities and am a very unexperienced vespa-fan.. can somebody give me some usfull tips? Yhanks!
