tekko
    25
Alle Inhalte von tekko
  1. ok tanks!! but how can i identify a meceur crankshaft with the bad TYPE B rod? -Type A (good rod) has "made in italy" printed on the clutch side of the rod? no marks printed on the flywheel side of the rod?? -Type B (bad rod) has no mark printed on both rod sides?? can i see other differences beetween typeA and typeB ?? thanks a lot marco
  2. hi all i'm writing from Italy and unfortunally i cant understand deutch! BUT using google translator i think to understand that you are talkin about problem with meceur 60mm crankshaft. so: there are 2 different type of crankshaft? type A is good type B is bad, has a bad rod and can broke ?? where did you buy good meceur crankshaft, and where bad one? unfortunally picture on the first page of the post is unable, can some one re-upload it?? thanks a lot, Marco...
  3. hi sorry but i can't understand deutch.... you are talking about some polini 208 piston broken.... BUT you are talking about the new polini aluminium cylinder, or the old cast iron??? thanks marco
  4. you got an mp. please reply!! interessed to Vertex Pinasco Kolben
  5. hi im searching a sip performance exhaust, for px200, the one with carbon or kevlar muffler tha fits with spare wheel, lije the one below (but for px200) send me personal message or email balducci81@libero.it http://www.sip-scootershop.com/EN/Products...erformance.aspx thanks
  6. hi i know that there is a GSF project for px cylinder head. i've serched here and in project forum, but i can't understand deutch, so i didn't find nothing. i'm serching gsf kopf for polini 210, either 57mm hub and 60mm hub. can you please tell me the best head for this configuration? and, there is a commercial head (worb,sip,...) equal or similar to this? because i'm not sure that here i can make modification to original head, so it's possible is simple for me to buy a new modified head. thanks a lot
  7. ok thanks have you got a photo of you acewell on vespa handlebar? thanks
  8. hi thanks patrick. vespa fuel sensor gose 0-300 ohm, but if you take a resistor of 150 ohm in paralle, you have 0-100 ohm, but it didn't work correctly yet. how much have you to modify acewell sensor to fit vespa tank? and, how have you fitted the acewell on vespa handle bar?have you made an adapter ring?wich material? thanks a lot Marco
  9. hi i got a problem with the tank level of my acewell 2853. the level signal is not fine, and when gasoline level in tank is above 1/3 the signal on acewell is not stable and jump up and down... what can i do? i see that in the forum are other post with this problem, i think, but i can't undestand deutch i got other question about leds: in this schematic you see that "oil" "neutral" and "triangle" led are connected to negative/ground. does it mean that this leds went ON when you connect them on ground? and if i want to use, for example, "oil" led like tank reserve led, that come ON with positive 12V, what can i do? have i to make a circuit with a diod? thanks
  10. hi can you please tell me if cosa 200 and px200 oryginal crankshaft have differences? and inlet port on the engine block? and cosa2 200 crankshaft (the one with alu cylinder) is different from the other one? thanks a lot
  11. hi what about the alu zylinder ignition timing? i foud here http://www.germanscooterforum.de/index.php...amp;hl=alu+cosa i think they wrote the 12PS alu cosa zylinder, ad to be setted to 18 degree (IT) it's correct or not? if the zylinder is same ad px200 (but is the same?) why have to change ignition timings? thanks
  12. hi i think you mean this exhaust "mit flansch" link but exhaust for alu cylinder, mit Flansch, can be mounted without modification to the px200 engine case, or not? sorry for toooooooooooooooooooooooo questions!! bye
  13. you say that alu cylinder has same configuration (160-BE3-118 55/160) of px200 cylinder? but here i see tha cosa 12PS cylinder has 160-???-96 48/160 ; and it seemsme that 96 main jet on 200cc engine is crazy...what can you say me about that? how can i search it on ebay.de? the exhaust, exept the cylinder flange, is the same of px 200 or not? thanks a lot!!
  14. hi il'' use a mormal px200 USA head.lower compression than rally head, but i think higher than cosa2 200 central sparkhead (troncoconical desing chamber) i have used in the past the cosa2 central spark head, but i dont like that i'll use a normal px200 exhaust, so ill make a flange to be screwed on the cilinder. do you use a normal px200 air filter?wich jet configuration carb? 24/24E? thanks
  15. thanks have you mounted it on px200? do you make the modification to the exhaust port flange? got images? thanks
  16. hi can i use cosa2 200 aluminium cilinder on px200 engine? i kno i have to make a modification to the exhaus port, to use px200 exhaust. does anybody do it?it works good? wich carburator 24/24E configuration have i to use? thanks a lot Marco
  17. ok thanks yes..... why?
  18. i'd like to optimize original 200, because 200 piston as toooo big ring, so.... i'd like to try to make a 208 "pinasco style" cylinder, cast iron... very gooooood work!! but for me it's the first time i rework a 200, and first time on longstroke...so i'd like to make things "step-by-step" is not so orizontal like it seems, is not a good photo! your right, but now i can't buy a pinasco or malossi, too expencive for me, and polini is not so reliable.... thanks!! PS: Any idea about scorpion carburator setting? bye
  19. now i've run 100 km with this config: -160-BE3-128 -55/160 min and 24 original valve -original filter, with 2 hole, 1 on max jet and 1 on min jet -spark fix time 22° and linear decreasing spark delay -original exaust the engine run good, it seem to have a good torque and good reliable, seem to have a good carburation, a bit too fat, but for the first kms is good. after 3-400 km i'm going to use scorpion exaust, wich carb config can i use?wich maximum jet?
  20. hi (sorry if my english is not so good...) the name is not so coll....but: -it's an original Piaggio 200 cilinder -polini 68mm 2-ring piston -cilinder and piston reworked in pinasco 213 style.... so we can call it Piaggiolinasco, or PPP, or P-cube.... i've made: -Original piaggio 200 cilinder, refinisched inlet port, outlet port enlarged to 39mm, 3-rd inlet port enlarged onthe gasket base and on the boost port, bored to 68mm, -Polini 2ring piston, reworked on all 3 port to work with piaggio piston-ported inlet port -Central spark head cosa2 200, bored to 69mm, and reworked to have 1.5mm squish,50% squish area, 10:1 RC. -60 mm crankshaft MecEur, laserwelded . -rotary valve enlarged on the "opening side" and closed (filled with epoxy) on the "closing side" to prevent blowback. Now the timing is: valve open 119° before TDC, and close 50° after TDC, total 169°. -cilinder timing is 167° outlet port, 123° inlet port. -24SI carburator, with enlarged to 2 mm max-jet tube. -orinal exaust, after 300km ill use scorpion! -delayer variable spark timing unit -23/65 original gearing, with 7 spring clutch with reinforced ring. I would like to have a tourer engine, with a lot of torque, that can run at 90 km/h for a long time. some photoes: ENLARGED VALVE(opening side): FILLED VALVE, IN BLU ORIGINAL VALVE, IN RED FILLED VALVE. ENGINE CILINDER PISTON CENTRAL SPARK HEAD, 60 MM MECEUR CRANK, LASER WELDED
