edumegacc
    238
Alle Inhalte von edumegacc
  1. VMC explorer # VMC ranger = +-100 euros crank bgm 60/128 # crank bgm 60/110 = +-45 euros carburator (si 26/26r), exhaust (polini box), clutch, ignition is the same in engine 2000-2500 euros, 150 euros diference is small. i think that if explorer bring more 2/3hp and 2/3nm in same setup so the 150 is well spent
  2. Ranger versus explorer? is not big diference in prices
  3. Hi With plug and play, original crank, carbutor 24/24 what is the best exhaust choice? Polini box or bbt2? Thanks
  4. In photo look like pocket but i do just like you. Don't like to put more volume in transfers.
  5. The exhaust port have layout that allow port when start open don't give all area.
  6. Good morning Allready close engine with stelvio 2.0 The casing is from GTR125 With crank 60/105 from pinasco The transfer is: - 0.5mm gasket base cylinder = 118° - 1.0mm gasket base cylinder = 121° The exhaust( hard to read because layout) - 0.5mm gasket base cylinder= 176-178° - 1.0mm gasket base cylinder= 178-180°
  7. Hi What is the setup spring for engine that is between 35-40cv? 6 spring L 9 spring L 6 spring xl?
  8. New HR (High rev) Feedback?
  9. Hi By P.O.R.N.O. rules i have engine t5 rebuild to sell. Is mine, is in Portugal, is only selling here, 1000 euros plus shipment Have new bearings, new oil seal and gaskets Have original ignition,crankshaft and carburator Have polini 152 and sip head Have exhaust sip road Have less than 1000km after rebuild Thank you
  10. thank you the side stand is not in original place? have off set plate?
  11. in oldies like Sprint/GTR/rally can fit without offset system?
  12. hi can anyone tell me if POSCH resi can fit with central stand (without offset) best regards
  13. Hi I'm searching for mmw pump hidraulic for my vbb project. There is some store /user that can have it? Thank you
  14. Hi I see this in web using m210 cylinder in original casings. Is there more infos available?
  15. HI already test with new VMC Explorer 245? what goes better exhaust for mhr or for quattrini m244?
  16. hi this is new egig exhaust. not many to see. the photos that is available don`t show in chassi. anyone have photo? thank you
  17. Don't forget bgm carburator and bgm oil ;) . .. .. .. .. .
  18. even better with fensatronic
  19. Hi Bgm190 and bbt2 goes better with sip vape road or sport? Thanks
  20. how to order when Marco don`t replay to mensages? there is some store that have this exhaust? regards
  21. not fom sck. gsf source ;) allready bgm 177 with bbt v1.0 have 19hp... regards
  22. good morinig allready some dyno chart with bbt v2.0 and bgm 177?
  23. hi the APE is new for me. is possible to work with start and quattrini m1l60 same time ? regards
  24. New piston evolution. Specific for rb, rr and t5 cylinder.
