stuart
    28
Alle Inhalte von stuart
  1. Noosa is much closer!! Have you been there?
  2. @500 Miles what's your clutch/primary gear combo? I've currently got 23/64 straight cut but I think it could be longer?
  3. So M232 quattrini, Malossi X360 reed intake and SIP 3.0, standard igniton. Need to set timing.. is it static to 18deg?
  4. Yes, I did think that, I have a bucket of washers which I can search through... maybe find something in there if not.
  5. Uluru is waaayy too far away from me, I'm in Brisbane!! Okay, noted. Maybe still need to fine tune... back to 2nd clip and up the idle to 56 - 57, see how that goes, just to play safe. Will defo try the 0.5 clip though once I source one.
  6. So, not a bad session... scooter now runs very well, better than it has. Settled on the following for now but will still need minor tweaks... 40 slide 55 idle AS264 X2 3rd clip 135 main no pump I think I will try a half spacer with the 2nd clip or settle with the 2nd, but good results MB Developments have an X13/2 needle, sounds interesting https://www.vespaclassic.co.uk/spares/phbh-range-only/dellorto-needle-set-(kit)-x7-x7__13-x13-x13__x2-x2-2-clips-phbh-mb/mbd9993k. html
  7. PHBH 35/58/AS264/X2/2.vo/125. thanks @500 Miles 35 Slide 58 Idle AS264 X2 2nd clip 125 main That correct from what I'm reading? Day off today so maybe get some jetting done... got the vespower set to 24deg @ 1500rpm, see how we go.
  8. I'll start with that jetting, thank you for sharing :)
  9. Yes, I'm running that 300 carb float valve too. What is the jetting you are running on the PHBH? I've only finished building on the weekend so still getting jetting organised
  10. It is a fairly simple 244 build, nothing exotic... VR1 cases, Q 60mm crank with vespower igniton and extra weights, 30mm PHBH and box pipe, currently sip 3.0 but will be replaced with polini soon. normally street riding and hwy each day at 100 - 105kmh so not super fast, i think no pump is okay though? I normally have fuel pump on the kangaroos that we ride to work but they have vforce and expansion pipe
  11. How many of you run pump? I see some don't and some do...
  12. what is your carb jetting with the TMX 30mm? are you running a fuel pump too?
  13. untouched from factory.. 2mm base and 2.5mm head packers
  14. I should have the viper box by the end of the week for me to try on my 260.. and also just got the megadella XL compact 8 cone to try too.
  15. just finished building a new performance engine and have got oil leaking out of the clutch cover breather. it's not just a little, it's enough to trickle down and hit the brake backing plate within minutes. so it's an S&S cover that's been milled out and an MMW basket, nothing unusual. gearbox oil level is also correct. anyone else had to deal with this issue?
  16. it's probably on this page but lots of pages to go through .... just finished building a M260 with VR1 cases and polini box. is there ballpark jetting for 30mm phbh please?
  17. Anyone have cylinder temp readings on their M232? I am running one one my PX with 24/24SI and SIP performance pipe...I'd like to get an idea of what CHT you guys are getting?
  18. Yes Nick. Standard air filter and air bellows. I have tried the polini venturi and pinasco carb box lid but I think I need to get it all running smoothly first before I delve into more performance bits!
  19. I understand. They are a helpful tool for setting up a motor and also I find them a good tool for highway riding as to keep a check on the motor, especially in Australia where summer can be quite hot.
  20. Cylinder head temperature
  21. PolifkaRudl, are you running a CHT?
  22. Fantastic. I will start at 18deg and work towards the recommended...and yes, kytronic has a vespatronic curve...7 from memory. Thank you guys.
  23. PolifkaRudl....That's great advice, thank you. What about ignition timing? Any advice on that?
  24. Thanks for the reply Truls221. I'm running a SIP XL. The jetting is good...I've just been on a 300km/h trip last weekend and it performed well except for that little stutter at light throttle. Looking back on the weekend, it does just keep up with well tuned Malossi 210s but going up long hills, it'll leave them for dead. I will look into doing the rotary pad. Is there anyone on GSF who is running a similar setup that would share their specs?
