saby
Members-
35 -
Alle Inhalte von saby
Open Source Prüfstandssoftware auf Basis von Arduino Mega und LabVIEW
saby antwortete auf chili023's Thema in Vespa Lambretta Projekte
Roller you can use an ac motor roler -
Yes -
But in most cases i put it to pickup wire -
No, works ok -
Yes -
Pin 48, 49 is rpm pins, need a hall sensor and a pullup resistor, a koso rpm adapter and an optocoupler becuae it workson 12v That's it -
Works verry good! -
I told five times buy a koso rpm adapter an finish the trying with capacitive pickup, it changes fom engine to engin, and even hot and hotter, never works good! A question for chili I measused a piag 4t iget, and i get half of engine rpm, i need to write 0.5 to rpm signal, but i cant, what to do? -
U must use a resistor plug and a resistor cap -
I use a charger for a makita 12v drill -
Racing-planet.de Koso rpm adapter Optocuples is 1 euro in electro store -
Rpm adaptes signal goes to an optocoupler then to arduino -
I use a hall honeywell from a fiat punto, and a koso rpm adapter works without any problem. The phenomen i hawe earlier like you that works first time, and second time not, how the bike warms uses smaller energy from spark and you get interference, when i buy the koso adapter problem gone -
You can use a car hall sensor like punto or corsa, itp honeywell -
What is mv value? Yes its repeatable, its a scooter, blocked variator in half way, like in 3 rd gear -
@chili023? -
Hello, i have a problem, a kymco agility scooter i work, when i measure in vario mode it shows 5.3 hp but when i blocked the variator to half it shows 3.2 hp, why? Regards -
the last ver is 2.091 -
Interesting. What kind of signal does the part deliver? So in the exit? TTL or 12V rectangle? 5v squere wave signal -
you have scooter mode in software and if you have rpm pickup you will see the vario its a stock yamaha aerox -
Clamp it to hv cable, hv coil input, even to pickup wire -
I told you download the visa drivers
