Sticky
    20
Alle Inhalte von Sticky
  1. I only tested every kit (except those supplied with longer stroke cranks) with 58mm stroke because that is the stroke that most kits are designed for so this issue did not crop up for me. Many 58mm stroke kits work worse with 60mm depending on how you set them up, and whether or not you adjust the port timings to suit. I'm not sure my wife would notice an extra 2mm stroke if the timings were all off. Sometimes it's better to let it rev.
  2. Quick update. I suggested an update to the RLC crank puller tool because it was a bit of a pain to use as the crank always wanted to turn when you were pulling it. They've now added a bolt in the side that rests against an exhaust stud to stop the tool and crank turning. There is still movement to 'wiggle' the crank enough to get into the oilseal but the tool works much better. It's really nice to deal with a company who listen when you suggest updates and improvements. If you want one I'm sure you can find it without me adding a link.
  3. Champ, the reason I said nothing is because I try not to be boastful. If you show me your product and I say "yes I made something like that in 1994", how does that make me look? If I then also say "but now I helped RLC make a better version of that tool last year so you had better stop making it" then that makes me look very small-minded. I thought the most polite way to deal with the situation was just to say that I liked it and to wish you well with it. I see no reason why you can't sell and make money with your version. Good luck with it. The only thing I have a problem with is being called a thief in public but I understand why the confusion arose and why you felt like you did. Anyway it's no problem, I accept your apology. PS I hope the time machine is a 2-seater. If it is please take me back to Holiday in Holland in the 1990s as suggested because I seem to have left a lot of my brain cells in Borculo :) ---------------------------------------------------------------------------------------------------------------- Scheiße Google Übersetzung folgt .... Champ, der Grund, warum ich nichts gesagt habe, ist, dass ich versuche, nicht prahlerisch zu sein. Wenn Sie mir Ihr Produkt zeigen und ich sage "Ja, ich habe so etwas 1994 gemacht", wie sehe ich dann aus? Wenn ich dann auch sage "aber jetzt habe ich RLC letztes Jahr geholfen, eine bessere Version dieses Tools zu erstellen, damit Sie besser aufhören sollten, es zu erstellen", dann sehe ich sehr kleinmütig aus. Ich dachte, der höflichste Weg, mit der Situation umzugehen, war nur zu sagen, dass es mir gefallen hat und Ihnen alles Gute damit zu wünschen. Ich sehe keinen Grund, warum Sie mit Ihrer Version nicht verkaufen und Geld verdienen können. Viel Glück damit. Das einzige, mit dem ich ein Problem habe, ist, in der Öffentlichkeit als Dieb bezeichnet zu werden, aber ich verstehe, warum die Verwirrung entstand und warum Sie sich so fühlten, wie Sie es getan haben. Wie auch immer, es ist kein Problem, ich akzeptiere Ihre Entschuldigung. PS Ich hoffe, die Zeitmaschine ist ein 2-Sitzer. Wenn ja, bringen Sie mich bitte wie vorgeschlagen in den 1990er Jahren zurück zu Holiday in Holland, da ich anscheinend viele meiner Gehirnzellen in Borculo zurückgelassen habe :)
  4. Champ, I like and respect you but please don't accuse people of theft in a public forum without good evidence because it's not a good look. Please find attached a cover of Scootering magazine from 1994 with an article on a puller tool I made with a old Sundance grip to extract gudgeon pins. I think you may have given me the idea in 1993 when you were visiting in your time machine. Best regards Sticky ---------------------------------------------------------- Bitte entschuldigen Sie die folgende Google Übersetzung Champ, ich mag und respektiere dich, aber bitte beschuldige die Leute nicht des Diebstahls in einem öffentlichen Forum ohne gute Beweise, weil es nicht gut aussieht. Im Anhang finden Sie ein Cover des Scootering-Magazins aus dem Jahr 1994 mit einem Artikel über ein Abziehwerkzeug, das ich mit einem alten Sundance-Griff zum Herausziehen von Kolbennadeln hergestellt habe. Ich glaube, Sie haben mir die Idee 1993 gegeben, als Sie in Ihrer Zeitmaschine waren. Freundliche Grüße Sticky
  5. The image is dated in the file name. October 2017 is when I got the first example of this product to test, but they first produced them in January 2017. I have video files from January 2017 of the tool in use. I came up with the idea over lunch with the RLC guys in 2016 when I was with them in Italy. Champ, you did show me your tool at Meltdown but I can't remember which year it was, probably 3 years ago like you said. It was certainly wasn't 5 years ago. I didn't publicise your tool because it was another version of a tool that already existed. The Casa Performance product was originally a drift tool to fit the outer oilseals into the Casacase with a solid end. I suggested that if they drilled a hole in it and used a large bolt with the end machined down to have an M8 fine thread then the same tool could also be a crank puller. So Champ, it is possible that I copied your crank puller idea, but only if you have a time machine and travelled back in time to 2016 in order to show it to me. If you have invented a time machine as well as a Lambretta crank puller made from a handlebar grip I suggest that you put your energies into promoting the time machine because the market for time travel is probably bigger. If you haven't invented a time machine then perhaps you should accept that I didn't copy your invention. Since you didn't know about the RLC tool perhaps we'll have to accept that it is possible for two people to have the same good idea. This isn't the first example of that happening and I'm sure it won't be the last. -------------------------------------------------------------------- Bitte entschuldigen Sie die folgende Google Übersetzung Das Bild ist im Dateinamen datiert. Im Oktober 2017 habe ich das erste Beispiel für dieses Produkt zum Testen erhalten, aber sie wurden zum ersten Mal im Januar 2017 hergestellt. Ich habe Videodateien des verwendeten Tools vom Januar 2017. Ich kam 2016 beim Mittagessen mit den RLC-Leuten auf die Idee, als ich mit ihnen in Italien war. Champ, du hast mir dein Werkzeug bei Meltdown gezeigt, aber ich kann mich nicht erinnern, welches Jahr es war, wahrscheinlich vor 3 Jahren, wie du gesagt hast. Es war sicherlich nicht vor 5 Jahren. Ich habe Ihr Tool nicht veröffentlicht, da es sich um eine andere Version eines bereits vorhandenen Tools handelt. Das Casa Performance-Produkt war ursprünglich ein Drift-Werkzeug, um die äußeren Öldichtungen mit einem festen Ende in die Casacase einzubauen. Ich schlug vor, dass, wenn sie ein Loch in das Loch bohrten und eine große Schraube mit nach unten bearbeitetem Ende verwendeten, um ein M8-Feingewinde zu erhalten, dasselbe Werkzeug auch ein Kurbelzieher sein könnte. Also Champ, es ist möglich, dass ich Ihre Idee mit dem Kurbelabzieher kopiert habe, aber nur, wenn Sie eine Zeitmaschine haben und in der Zeit bis 2016 zurückgereist sind, um sie mir zu zeigen. Wenn Sie eine Zeitmaschine sowie einen Lambretta-Kurbelabzieher aus einem Lenkergriff erfunden haben, empfehle ich Ihnen, Ihre Energie in die Förderung der Zeitmaschine zu stecken, da der Markt für Zeitreisen wahrscheinlich größer ist. Wenn Sie keine Zeitmaschine erfunden haben, sollten Sie vielleicht akzeptieren, dass ich Ihre Erfindung nicht kopiert habe. Da Sie nicht über das RLC-Tool Bescheid wussten, müssen wir vielleicht akzeptieren, dass zwei Personen dieselbe gute Idee haben können. Dies ist nicht das erste Beispiel dafür und ich bin sicher, dass es nicht das letzte sein wird. Regards Sticky
  6. I hope we can add some useful information https://www.scooterlab.uk/max-quattrinis-new-lambretta-smallblock-210-kit-news/
  7. Meanwhile, back in the world of classic Lambrettas, SLUK is innovating again. Available now direct from SLUK https://www.scooterlab.uk/product/sluk-clip-lambretta-bridge-fitting-kit/ or very soon from your main scooter dealers.
  8. XL5, now also for GP http://www.scooterlab.uk/product/sluk-xl5-gp-screen-lambretta-gp/
  9. Diejenigen, für mit kurzen Armen und tiefen Taschen, wir ook machen viel billiger Bildschirme für SX-GP und PX, aber die XL5 und SXL5 erfordern viel mehr Arbeit so dass sie mehr kosten. Diese sind von Hand gefertigt und fertig in Großbritannien , nicht in China. http://www.scooterlab.uk/product/coast-coast-lambretta-screen-sxtvspecial-type/ http://www.scooterlab.uk/product/coast-coast-lambretta-screen-gp-dl-type/
  10. http://www.scooterlab.uk/new-lambretta-sx-vintage-vespa-sluk-screens-news/
  11. Ich habe ein paar Fotos von deiner Großmutter jetzt gesehen und sie ist wirklich nicht mein Typ
  12. Let me put it as simply as possible The idea for a free reunion meeting is a good one - we have no problem with that and would like to come there too. The idea to use the name "Holiday in...." is a bad one, because when the rumours spread people will get excited and will expect a rally organised like before. I don't think that is the idea if I understand Tobi's intentions. The point of the post was not to say "we own that name and you can't use it". There are good reasons why we don't want the name HiH used. What is being organised is not HiH, but if you get people excited about an event with that name then things will get out of control. Many people will arrive with the wrong idea, rumours will start in Holland and before you know it the police and council will want to know what is happening. you don't need all that trouble, so just keep it cool. I did not mean to "piss on your chips" and I apologise if my post has left a bad taste. ----------------------------------------- Lassen Sie es mich so einfach wie möglich Die Idee für eine freie Vereinigung Treffen ist eine gute - wir haben kein Problem damit und möchte es auch kommen. Die Idee, den Namen "Holiday in. ..." ist eine schlechte, denn wenn die Gerüchte Leute aufgeregt erhalten und wird eine Rallye wie vor organisiert zu erwarten. Ich glaube nicht, das ist die Idee, wenn ich Tobi Absichten zu verstehen. Der Punkt, der Beitrag wurde nicht zu sagen, "wir selbst diesen Namen und Sie können es nicht verwenden". Es gibt gute Gründe, warum wir nicht wollen, dass der Name HiH verwendet. Was wird organisiert ist nicht HiH, aber wenn man die Menschen über eine Veranstaltung mit diesem Namen zu begeistern dann werden die Dinge außer Kontrolle geraten. Viele Menschen werden mit der falschen Idee ankommen, werden Gerüchte in Holland starten und bevor Sie es wissen Polizei und Gemeinderat wollen wissen, was los ist. Sie brauchen nicht all die Mühe, so dass nur diese zu kühlen. Ich wollte nicht "auf Ihre Chips pissen", und ich entschuldige mich, wenn mein Beitrag einen schlechten Geschmack hinterlassen hat.
  13. Many people loved your grandmother. They had a good time with her and they miss her. Is it ok for us to dig up her corpse and fuck with it without asking you? Why then do you think it's ok to dig up the corpse of our rally without at least getting in touch? Do you not think the Inselaffen might have something to say about this - or indeed the German Speed Demons. Please don't treat us like we don't exist. GOOGLE TRANSLATE BELOW - I HOPE THE MESSAGE IS STILL CLEAR Viele Menschen liebten deine Großmutter. Sie hatten eine gute Zeit mit ihr und sie sie vermissen. Ist es ok für uns zu graben, um ihre Leiche und ficken mit ihr, ohne zu fragen Sie? Warum glaubst du, es ist in Ordnung, graben die Leiche der Rallye, ohne zumindest in Berührung kommen? Glauben Sie nicht, die Inselaffen vielleicht etwas dazu zu sagen haben - oder auch der deutschen Speed Demons? Bitte nicht behandeln uns wie wir nicht existieren.
  14. Sorry for posting in English. The track that Marco has seen is in the middle of England which is not ideal for people coming from the continent. Also the facilities there are not perfect for a rally. We are also looking at another site in the south east of England, much closer to the ferries which would be better for a rally. It also has a kart track, but with a bar that can hold 400 people and is near the sea with a sand beach. This might not be on the usual date of Holland but maybe one week before or after. It depends if we can get the track and it is good when we go to see it. In answer to some earlier comments: 1. We are sorry if the German scene will miss Holland this year, but it needs a break so it doesn't become the same every time and boring. Also we need a new site. Too many problems in Borculo. 2. Sorry if you think the door rules are hard, but that is what they are. Speed Demons SC has always tried to put on rallies for dedicated scooter riders. If you were a dedicated scooter rider who wanted an event to meet people like you, then you would not care if car entry in HiH last year was 50Euro. FUCK CARS! 3. If you think that it is too far to ride to England on a scooter then we feel sorry for you. Every English person at HiH on a scooter (probably 900 people) had to ride AT LEAST 250km to get there, many ride around 500km and have to pay for a ferry as well. Does that stop them coming? 4. The statement about stopping back-up vans coming on site is aimed at the British people. We have a theft problem in the UK at the moment so we don't want vans on site. If a club we know from the continent wanted to have a van to back-up a large group of scooters and we knew about them in advance then we could maybe arrange something. NO FUCKING CARS THOUGH! 5. If you think that this event is not for you then simply go somewhere else! We aim to do something different and there has not been a race meeting combined with a rally in the UK since 1985! Also there has never been a european scooter race in the UK before where everyone can race together. 6. For the racing the rules would be more like those used in Germany than in the UK. We want to avoid all the problems and expense for German and Austrian riders having to get race licences etc.
  15. noch eine bilder http://www.holidayinholland.org.uk/_Pages/...lery%202005.htm Cheers Speed Demons SC
  16. Thank you for your support fellas Sti(n)ky www.lambrettabook.com
  17. Hans, Sorry for writing in English - I may be the member of a German scooter club (Speed Demons SC) but my German is not too good. However I do have many friends in Germany. My name is Sticky and I am the author of the book you intend to rip-off by producing a PDF version. I am not a big publisher who wants to rip off the scene. I am a scooterist who worked on that book for 9 months of my life. It contains all the information I and other people have learned about Lambrettas by riding and working on them for years. You might consider it very clever to create a PDF of the book - a bit like being a hacker? It is a lot of work to scan all those pages, but not as much as to write it in the first place. Personally I see no need for a PDF copy to be produced except to rip-me off. The book states clearly in the copyright information that any such act is illegal. If you need another copy then buy another copy - we can sell you as many as you need. You know as well as I do that if one PDF is produced it will quickly escape onto the internet where it will be free for everyone to have for nothing. You haven't produced a German translation so people all over the world will get it for free and I will get nothing for my work. If you consider it to be right and fair to rip-off another scooterist then maybe you shouldn't be part of this scene. . .
