Yeah, fair call. I’ve never dynoed the scooter as here in Australia most of them are setup for powerful road bikes and they aren’t interested in scooters.
Don’t get me wrong, I have struggled with this setup for over a year a couple of things that made a big difference was raising the squish from 0.9 to around 1.2mm
retarding the timing from 18 degrees to around 16 static.
then I was able to lean my jetting on phbh30
120main
6.5G float
300 float valve
av266
x7 needle 3rd clip
55pilot
55slide.
sorry I haven’t mentioned my gearing
Standard px200 gearbox with Malossi 23/64 straight cut primary
im also running the laser welded Worb5 flowed reed valve crank, wasn’t sure if this was a good choice and would have preferred a full circle but there was nothing available at the time.
I have a friend with a fully worked quattrini M232 and the 187 is very similar in power, he had his dynoed and it’s peak is around 30hp,
this is nothing really special in today’s world but what I like is that it’s very reliable and I can run for hours on the freeway with no overheating issues with my cht temperature maxing out at 135degrees celcius.
