Hello all. Forum member roo made me register as a member of germanscooterforum.de as the price for the link to the GSF-Dyno.
I speak no German. My apologies.
Well roo, go ahead and laugh. You had your fun.
Thanks for the link to the GSF dyno!
there are worse things. :-D welcome!
building a dyno on your own? is there a vespa/lambretta scene in louisiana? got any images?
Welcome!
I think nearly all of us speak English and and are able to answer....
Maybe it will sound a little strange sometimes, but anyway.
Enjoy the GSF.
Dank für den gütigen Empfang
With the help of freetranslator.com, I'll try to learn a little German while I am here.
There is a small scooter scene near New Orleans and Baton Rouge. I live in a small town in central Louisiana and may have the only Vespa/Stella/Bajaj and Kymco in the parish (county) :-D
Hello,
First welcome in the GSF... and i think that you will not have any problems because i think nearly everybody speaks english. And if there still are a view problems, there are enough translaters in the world wide web. Its really good that there is also a little scooterscene in louisiana. Does there are a view people who have old vespas? I hope that you`ll find everything you need in our forum.
Best wishes, Hansi
    • Hmmm .... das ist so leider auch nicht ganz richtig!   GENAU diese Fälle hatte ich vor nicht all zu langer Zeit in der Diskusion mit der Regierung (Regierung! - nicht Zulassungsbehörde!)   Die (für Bayern) richtigen Aussagen:   - die 50 km/h (394500) gab es nur in der BRD -> das Fz muss für die Verwendung in der BRD produziert und bestimmt sein.   - die BE 60 km/h für DDR-Mopeds ist vom aaS/TD nicht mehr auszustellen! Diese wird ausschliesslich durch das KBA erteilt (https://www.kba.de/DE/Presse/Pressemitteilungen/Allgemein/2023/pm12_2023_KTA_Online.html?snn=3662144   bzw.   https://www.kba.de/DE/Themen/Typgenehmigung/Informationen_TGV/Auskuenfte_ABE/auskuenfte_node.html;jsessionid=389004A41E531261A872E4A18A70D708.live11313).   Den Nachweis, dass das FZ für den Gebrauch in der DDR prodziert wurde (denn nur für diese gilt die Regelung im Einigungsvertrag von 10/1989) hat ggfls. der Antragsteller zu führen ... das KBA hat übigens keine Listen von "DDR-Fahrgestellnummern" ...   Dieser Beitrag stellt nur das Fazit der Auskünfte und Anordnungen der Regierung des (meines) Bundeslandes dar und ist mit mir nicht zu diskutieren ...       ...
    • Moin und und frohe Weihnachten, an meiner P200E(Bj. 1982) ist ein Target Dropbar mit Lusso Abdeckung verbaut, im laufe der Jahre hat sich die Gewindehülsen der Abdeckung gelöst(habe ich im Sommer mit Epoxy Kleber repariert = hält!), jetzt gibt die obere Halterung vom Tacho auf. Hab die Risse heute mit Sekundenkleber repariert, bin gerade dabei einen SIP "Karacho" Tacho einzubauen. Auf Dauer werde ich wohl irgendwann eine neue Abdeckung brauchen. Habe schon versucht, die Adresse von Herrn Olaf Ernhuber(Target Erbauer) rauszufinden, leide ohne Erfolg. Da ich mir nicht zutraue, eine neue Abdeckung zu zerschneiden und dann irgendwie formschön zusammen zukleben, suche ich eine Abdeckung, bzw. jemanden, der mir eine baut. Der Target Lenker soll die gleiche Neigung wie der PM Lenker haben( PM kann keine liefern). An der Target Lenkkopfabdeckung  ist über dem Schnitten eine Art Klebestreifen geklebt, was das für Klebestreifen sind, keine Ahnung, Glasfasermatten etc. sind es nicht. Kann jemand helfen?? Beste Grüße, Thorsten
    • Mehr Bilder habe ich gerade leider nicht zur Hand und Roller ist eingemottet. Zum Rahmen würde ich sagen, die Struktur ist ok um damit TÜV zu bekommen. Optisch eher so 3-4.
    • Jo steht ja ganz gut da, ist aber kein O-Lack. Ich sehe die, gerade auch weil sie über 125ccm hat bei 1800-2000€. Und ich glaub selbst das wird ne Weile dauern. Es sieht generell gerade nicht so gut aus mit Teilen oder auch kompletten Kisten.
