like the vespa a lot. looks very nice :-D, but I'd be interested in knowing where it's stationed, in the netherlands. could you also post a picture from the front, so i can fully see the headlight and everything else.
Bearbeitet von speedaholic
It is stationed near Utrecht in the Netherlands. From Dusseldorf it is about 190 kilometers to get there.
I will make some more pictures to post, I will try to post them tomorrow.
Bearbeitet von scumbag
Well, i would say 450? sounds allright.
But I don´t know, how much trouble it makes to import it to Germany and to find a Insuarance-Company.
An other Issue is the Warrant of Fitness and that you need a Motorcycle driverlicense.
Michael
The rear end cut looks like there is no longer an original frame number. That will lead to some trouble getting it legalized on german roads.
Heeft uw het nummertje afgesneden? Een Duitser weerd daarom last hebben met de TÜV.
I thought the frame number was still there....but now I am in doubt. I know what you mean, because normally it is at the engine site in the back. I will check it and get back on this one. This scooter is from Italy and was checked at a dutch import company so I believe the number should be there. Anyway, when I know more about this, I will tell.
Further import from Germany to Holland is easy as long as we have the original papers with it. My guess is that it works the same the other way around.
