Hi Neil,
I guess you got something wrong. Chris is not claiming that he developed something. He just wrote that the whole thing is a self developed exhaust and cylinder. He did not claim that he did it. He also wrote at the end that every question regarding cylinder exhaust should be asked to you / rollerfabric.
You need a better translation tool. Nevertheless - it was quite rude of you was it?
cheers schlingoe
  • Antworten 349
i'm a bit confused too. some guys told me that you're not working anymore for the rollerfabrik...
I don't.
There was interest in the new cylinder, and for that reason I thought it prudent to write a little. I am only stating facts. The exhaust is a very good one, not EXACTLY what the new Cylinder was developed with (but reasonably close).
I have seen 3 PS gains on Plug and play Quattrini cylinders (compared to other exhausts), and 2 PS on well set up Mallossi's.
They are quite noisy, but certainly a good "sports" expansion chamber.
  • 8 Monate später...
It is a fairly small market there, but I can sympathise with the taste it leaves in ones mouth.
Some rather prophetic words were written on here a few years ago.
I can't imagine too much more coming from 'nam going through there, but I'm "not in that loop"
Bearbeitet von scootergangbang
After talking to the man himself on the phone and having to listen to his weird definitions of "original" and of a "small batch for himself and a select number of friends" it did indeed leave a rather lasting impression (actually it was more of a confirmation of a previous impression mainly based on a number of other similar demonstrations of a truly unique "style"). This horse has been ridden to death and beyond though, as far as I'm concerned I think I have learned my lesson. 'nough said, I'd say.
You're back in Newzealand than?
Austria actually, I was home for a holiday recently, but there are too many people to "show my gratitude", for their "outstanding honesty and friendship" over this side of the world.
    • @alter Wikinger fänd ick jut! Dann muss @der.guen mal die Dateien raustun ...   Wg. next Lokation: wir waren heute mal Sauerteigpizza bei Antonella essen. War lecker! Ich könnte die Tage nochmal hin und fragen, ob wir die Außenbestuhlung kapern können. Ist allerdings direkt an der Podbi. Aber vielleicht kommt noch die Nachbarin vorbei und verliest die aktuellen Nachrichten ...     Soll ick?   @Alberto: was machst du am ollen Fluchhafen?
    • Hatte das gleich Problem, wie du und mich zu Tode justiert an den neuen Schaltzügen! Wie du es jedoch beschreibst, war das Problem bei der Kupplung bzw. dem Kupplungszug. Kupplung trennte zu 95% aber eben nicht zu 100%, wie ich anfangs dachte.   Meine PK 50S lief problemlos nach einer Motorrevision und bei höherer Geschwindigkeit war das klacken auch weg, wenn ich aber einen Gang drin hatte und die Kupplung gezogen habe, hat es bei niedriger Geschwindigkeit und laufendem Motor "geklackt" … Wohl gemerkt im Auszustand kein Klacken!   Lösung war bei mir: Kupplungszug nachziehen. Habe ich die Kupplung nun 0,5 bis 1cm losgelassen, kam das klacken wieder beim Schieben, habe ich sie aber nach dem Nachziehen nun ganz gezogen, war das klacken weg!   Schönes Wochenende 2025
    • Hallo, die Sitzbank hab ich vor Jahren mal verkauft aber die Radzierkappen hab ich noch. Die kannst mit dem Roller erwerben 😁. Gruß
    • Ich verstehe das so dass das ein 65er für die 125er Motoren ist was logischerweise einen grösseren Durchmesser haben muss eben wie die 68er. Du hast aber einen 22er für die 200er gekauft und das ist folglich nicht passend. Dein Glück dürfte aber sein, dass Du einfach ein 22er oder 21er von einer 125er verwenden kannst.
