4 th gang 125 200 tauschen
Floorplay
welches motorsetup hast du denn? damit der den zieht bräuchtest du einiges an drehmoment...
aber rein mechanisch kann man den da rein bauen, wenn es beide gangräder von der px lusso sind, oder halt beide px alt.
Bearbeitet von vespaschieber
Does work, but why would you want to do that? Your engine might no longer be able to rev up properly. People usually tend to put in gears with an even shorter ratio, especially in 4th. What's your setup?
War der Schieber wieder schneller *g*
Bearbeitet von bigbene
Theoretically, yes-you still might want to leave the settings as they are in favour of a high number of revs. Especially when shifting from 3rd to 4th, your engine might lack the torque to accelerate properly any longer, do you know what I mean?
Offtopic: that's not the yankee seat on your scooter, is it :-D ?
