...ich bin doch hier im 166er ?!  :blink:
Ja und? Meinst du im Polini Topic wird das Wort Malossi nicht auch stehen?!
hab dein setup iwie in dem link nicht gefunden!
Gesendet von meinem GT-I8190 mit Tapatalk
Dann schau mal auf Seite 189, das ist der 3.letzte Beitrag.
Das Setup steht über dem Leistungsdiagramm.
Das ist ein auf Sito-Plus T5 Basis umgebauter Auspuff wie Pep, Sip Road, usw.
Leider wird er nicht mehr hergestellt.
Hello,
My setup
Malossi 166 MK2 orig.
RD350 reed valve
28-30 carburator
P200 clutch
23/65
PM EVO exhaust
1600gr flywheel
Should be absent crankshaft
I think the engine will be 18 to 20 HP
yes?
Which would be good?
Which one to choose?
http://www.scooter-center.com/product/1620016/Crankshaft+RACING+reed+intake+60mm+stroke+lip+type+Vespa+PX125+PX150?meta=?cat=C_V_VNX2T&catmatch=CAT_KURBELWELLE_KURBELWELLE
http://www.germanscooterforum-shop.de/en/products/flowed+crankshaft+serie+pro+_46030000
http://www.germanscooterforum-shop.de/en/products/full+circle+crankshaft+mazzu_45050000
Someone else thought??
(There is a maximum of EUR 200)
best regards
Szasza
Hi Szasza,
I would go for a "bell-cut" fullcircle mazzu crankshaft made by s&s. That should be a great choice and durable.
The price maybe a bit higher, don't know.
Or you ask GSF member Polinist . He sold manifactured MecEur crankshafts for reedvalve. Problem there is, that you need a conversion bearing for the piston and a spacer cause of a longer conrod.
Thanx,
Please give me link the conversion bearing.
S & S bell crankshaft pretty good, but 300euro,plus post
For me it is now much
Therefore, looking at the other
Hello,
My setup
RD350 reed valve
28-30 carburator
P200 clutch
23/65
PM EVO exhaust
1600gr flywheel
yes?
best regards
Szasza
Hi!
crank 1 & 2 are the same.
They are very good and reliable! I bought a new one some weeks ago because my old had some space in the bottom bearing after thousands of kms, about 10 destroyed pistons, atomized LIMA bearing, atomized cylinder footer, broken Flywheel during driving, opend clutch, loose clutch ....
There are much more expensive cranks which would not take that "heavy load" ;).
So go for it ....
reg
Bearbeitet von Schneckerl
Hello,
My setup
RD350 reed valve
28-30 carburator
P200 clutch short 4.gang
23/65
PM EVO exhaust
1600gr flywheel
60mm crank
I think the engine will be 18 to 20 HP??
yes??
Szasza
What carburetor would be good for me?
I think 28 or 30
But there is no difference or the difference be?
What brand would be good?
Mikuni TM or TMX?
Dellorto phbh? Dellorto which would be even good?
I Keihin very good, but expensive
Best regard
Szasza
Need of Fuel pump depends on the Reed valve System and intake manifold, and also on the choosen Carb. I think of you take a Keihin, you will defininitely need a fuel pump!
I would go for a 30mm Dellorto PHBH or VHSA if you don't want to port the cylinder...
erstmal vielen Dank ans ganze Forum, habe hier sehr viel gelesen und gelernt.
Über den Winter hab ich mir eine PX restauriert und mit neuem Motor versehen.
Das ganze lässt sich super fahren und geht gut nach vorne.
Aber, nach dem ersten Prüfstandslauf stellt sich mir doch die Frage, was verursacht den Einbruch bei 8000 u/min? Lohnt es sich da jetzt nochmal bei zu gehen um das Tal in einen Hügel zu verwandeln?
Daten zum Motor:
Malossi 166 (Kanäle, Fenster und Auslass leicht bearbeitet)
1,5mm FuDi und 1,6mm QK
Malossi Membran
Primär 23/65
80er Getriebe
60er LHWelle
Steuerzeiten 127/184 VA28,5
Zündung 18°
Vergaser VHST 28 red edition
Auspuff Atom M1X
Leistungsdiagramm1.pdf
Hi,
verringere deine QS auf 1,2 – 1,4mm und bring deinen Auslass auf 68% Breite sowie einen VA von 32, dann solltest du schon einen deutlichen Unterschied merken. :rotwerd:
Ciao
Offi,
I would be a good VHST carburetor?
Sz
The VHST is a good carburator.
But the PHB´s do a very good job, too.
In both cases there is no gasoline pump necessary.
Good / very good
PHB to be better than vhst?
I am looking at data from the net, I think to be a better vhst
Tach zusammen!
Ich soll für n Kumpel einen 166er Motor bauen. Bisher habe ich hauptsächlich an 200er rumgetunt, daher fehlen mir bei diesem Projekt einige Infos zu passenden Komponenten...
Viele Teile liegen schon hier, einige fehlen noch, und dazu brauch ich noch ne Entscheidungshilfe.
Leistungsmäßig sollte das Ganze so grob bei 22-25PS mit einigermaßen fahrbarem Band auskommen. Ich denke, das sollte machbar sein, oder?
Vorhandene Teile:
- PX 80 Lusso Elestart Motor
- 166er vom SCK für PX80 (Fuss abgedreht??)
- 200alt Getriebe mit Lusso Nebenwelle/Tannenbaum mit 65Z
- MRP "Shorty" Membran Ansaugerblock
- Keihin PWK 33
Fehlteile:
- Kurbelwelle ???
- Membran --> geplant ist BGM RD350 o.ä.
- Ansauger --> geplant ist MRP Ansauger in Einzelteilen kaufen u. passend zusammenschweissen
- Kupplung ???
- Auspuff --> geplant ist Elron vom Falkr, auf P4 angepasst
- warscheinlich Benzinpumpe nötig
- evtl. KYTronik mit abgedrehtem orig. LüRa
Was kommt da so grob auf mich zu?
Lieber ne 60er Welle?
Welche Primär/Kupplung?
So, ich hab dann mal wieder was getan...
Motor ist zusammen, mit folgenden Komponenten:
80er Lusso Gehäuse ungeschweisst
200er PX alt Getriebe/4.Gang Z36 v. 125er
BGM Superstrong Kulu m. 22z/65er Primär
60er Mazzu Membranwelle
MRP Shorty Ansauger
(33 Keihin PWK, Elron)
Nach Rücksprache mit Falkr hab ich dann den Zylinder auf 186/125 mit QK 1,3 (1mm FuDi) gebracht...
Vorher:
Nachher:
Finish:
Gibt's noch Vorschläge? Evtl. Kolben bearbeiten? Überströmer?
Bearbeitet von OFFI
Also nach unten hab ich nenn Auslass noch nie gefräst! Eher nach oben und in die Breite, zu dem nicht nur vorne wie ne Trompete sondern bis nach hinten zum Krümmer durch.
Wie man im ersten Foto erkennen kann, bleibt da einiges an Auslaß-Querschnitt auf der Strecke, durch den runtergezogenen Auslaß gibt's bei UT ungefähr 72grad mehr Auslass...
Ich hab den Auslaß natürlich auch nach oben (und in die Breite) gefräst, sonst wäre ich ja nicht auf 186* gekommen...
Was die Trompete angeht: ja, da könnte ich tatsächlich nochmal bei, da haste recht!
Bearbeitet von OFFI
Tach zusammen!
Es geht nun um die Kolbenbearbeitung...
Ich hatte da schon folgendes Feedback:
am kolben sollte eigentlich nur das übliche machen.
cvf komplett öffnen und das bp fenster an zylinder anpassen.
Wo genau soll da was weggefräst werden?
CVF Kanäle können bis zu den gegossenen Verstärkungen geöffnet werden? Oben und unten?
BP Fenster passt eigentlich auf den Ausschnitt im Zylinder...!?
Bitte die Fotos bekritzeln, und posten,wenn möglich:
post-31024-14001482512791_thumb.jpgpost-31024-14001482652699_thumb.jpgpost-31024-14001482804076_thumb.jpg
Das nach unten ziehen (richtung UT) des Auslass, bringt dir im oberen Drehzahlbereich vielleicht 1PS, kostet dich aber untenrum bestimmt 2-3 der guten Vierbeiner :thumbsdown:
Bearbeitet von MadDoc
Ich hab die angedeuteten Stege auch noch weggefräst, so dass es "flush" ist, also nicht tiefer, als dort im Guss schon angedeutet ist, aber einfach so, dass das kühlende Gemisch hinderungsfrei nach oben steigen kann (so stell ich mir das mindest vor) ... Und, der Kolben verliert nochmals einige Zehntel Milligramm an Gewicht... :-D
post-47366-0-06100300-1400156111_thumb.j
Okay, dann mach ich das mal...
Ich were aber die "Stege" an den CVF Fenstern unangetastet lassen, da mir das Vergrößern der Fenster schon genug an Stabilität nimmt.
Das Ding soll ja nicht schon nach 5 Läufen auffe Rolle den Kolben zerbröseln...
Ja, dann wäre ich ja (nach der Kolbenbearbeitung) soweit mit der Fräserei durch, oder gibts dann noch irgendwelche Sachen, die angepasst/gefräst/geöffnet/zerspant o.ä. werden müssen?
Hier 2 Läufe auf dem 166er (alte Version) von meinem Kumpel Frank.
rote Kurve BigBox
blaue Kurve alter PM24
Setup:
Malle 166er(185°/125°,MMW Kopf Qk 1,2mm)
RD Kasten mit VF4
30er PHBH ( 266,55,125,x2)
Langhublippe 60/105
Cosa 200 Getriebe Z68/Z22
kurzer 4.er Gang Z36
post-34997-0-97305300-1400234967_thumb.j
    • Wenn das so weiter geht ist bald die 2. platte angebissen!
    • Man nehme gebackene Austernpilze vom Vortag und mariniere sie in BBQ-Sauce, Chili und Srirachasauce und gebe sie nochmals in die Heißluftfritteuse - et voilà: herrliche pseudo Wings. Ich habe zwar noch nie tierische Wings gegessen, aber nicht nur moralischer ist die Variante einfach viel, viel geiler! Yummy und vegan!
    • 50-55 Nm   Aber wenn das Ding so festgeht, würd ich annehmen, dass nicht das falsche Anzugsmoment das Hauptproblem ist
    • Nicht umsonst gibt es das> GSF weiss Alles Topic< , wenn sich hier keine Lösungen finden lassen, sind wir zum Untergang verurteilt !   In der Bildzeitung war heute wieder ein grafisches Highlight ! Eine Statistik, welche  " Belegen " soll das Deutschland noch nie so am Arsch war wie jetzt!   Neben der optischen Hauptschüler-Grafik-Aufbereitung hat die Bild auch keine Erklärung für das maximale DAX-Hoch geboten... Irgendwo müssen diese Antworten ja versteckt sein.   Und mit Wolfgangs Arbeitsbeobachtung gehe ich voll d`accour, das Selbstbewusstsein kombiniert mit Arbeitsverweigerung wird inzwischen hoch geschätzt.   Das liegt vielleicht daran, das wertschöpfende Arbeit einen Scheiß wert ist, aber Werte zerstörende "Arbeit" belohnt wird. Eine Thematik, an welche eine zukunftsorientierte Gesellschaft arbeiten könnte und sollte.   An anderer Stelle schon formuliert, es gibt simple Lösungsmöglichkeiten.   Zum Beispiel würde jede Diäten-Erhöhung der Bundestagsabgeordneten an eine Erhöhung des Bürgergeldes und Tarifvereinbarungen gekoppelt.   Pensionen und Renten koppeln wäre das Simpelste.   Und dann die tollste Lösung das sich selbst Zerstören das Kapitalismus zu verhindern, Geld endlich eine Endlichkeit zu geben, also ein Verfallsdatum, damit die selbstzerstörerische Akkumulation beendet wird.   Alles nix Neues, und im Mikrokosmos schon ausprobiert, hat leider immer zu gut funktioniert...   Um beim Titel zu bleiben, warum sind wir so dumm, das nicht umzusetzen ???
