Hello,
Anyone knows the difference between the Koso 28 and the Koso 30 origine Needle.
One is a 78-A for the 28
The other is a N68 - A... (Koso30)
I only found "N68" models for my setup, maybe it isn't the good ones...
Thanx
I wouldn't give too much on what needles are originally in the carburettors.
Perhaps you could buy or lend some leaner and richer Koso /Keihin / Bgm needles and just try what will work the best on your setup.
As far as I know there aren't needles that only fit on the 28 or only on the 30.
Bon courage!
cheers
Hello,
Thanx
Bearbeitet von tobuid
