hi
can i use cosa2 200 aluminium cilinder on px200 engine?
i kno i have to make a modification to the exhaus port, to use px200 exhaust.
does anybody do it?it works good?
wich carburator 24/24E configuration have i to use?
thanks a lot
Marco
Ciao Tekko,
the Cosa aluminium cilinder fits on a PX 200 engine. I would prefer is to the original cylinder because of the material and the better rings. There should not be a performance increase, but its a good basis for tuning. First I would match the piston windows to the windows in the cylinder.
With further tuning it should be equal to a 213 Pinasco.
Greetings
Hannes
Ciao Tekko,
Greetings
Hannes
thanks
have you mounted it on px200?
do you make the modification to the exhaust port flange?
got images?
thanks
Ciao,
I will mount it and weld the exhaust flange of the cosa exhaust to the PX exhaust. If you use the Cosa head please note that the spark position is different to the PX head. I'll use a Rally 200 head (higher compression).
Greetings
Hannes
Ciao,
Greetings
Hannes
hi
il'' use a mormal px200 USA head.lower compression than rally head, but i think higher than cosa2 200 central sparkhead (troncoconical desing chamber)
i have used in the past the cosa2 central spark head, but i dont like that
i'll use a normal px200 exhaust, so ill make a flange to be screwed on the cilinder.
do you use a normal px200 air filter?wich jet configuration carb? 24/24E?
thanks
the same like a normal Cyl. for a PE 200.
you say that alu cylinder has same configuration (160-BE3-118 55/160) of px200 cylinder?
but here i see tha cosa 12PS cylinder has 160-???-96 48/160 ; and it seemsme that 96 main jet on 200cc engine is crazy...what can you say me about that?
Search in Ebay for an exhaust for the aluminium cilinder.
how can i search it on ebay.de?
the exhaust, exept the cylinder flange, is the same of px 200 or not?
thanks a lot!!
hi
i think you mean this exhaust "mit flansch"
link
but exhaust for alu cylinder, mit Flansch, can be mounted without modification to the px200 engine case, or not?
sorry for toooooooooooooooooooooooo questions!! :-D:-D
bye
the cosa has a double airfiltration system that restricts the airflow somewhat , hence the smaller jets....
with the normal airfiltration or even better a improved system the jetsizes should be adapted to the increased airflow to prevent leanburning.
:-D:-D
ok thanks!
    • Ich hab das schwarze Massekabel weggelassen und hinten an der Rücklichtverschraubung nen blanken Massekontakt mit Zahnscheibe und Ringöse ! Bin normal ja jemand der überall am liebsten noch ein zusätzliches Massekabel setzt, aber bei dem dünnen Röhrchen gehen bei größeren Kabelquerschnitt beim besten Willen keine 3 Kabel durch.
    • Und nochmal Sorry   Ich weiß nicht was für Dich jetzt eine Bastelbude ist. Aber wie gesagt, ich habe noch nie nen Motor abgedrückt, einen Zylinder vermessen (lassen) oder das Kolbenstoßspiel geprüft. Klingt irre, ist aber so. Da sind jetzt Motoren von Ende 10 bis Mitte/Ende 20 PS dabei, LF, SF und sogar Lambretta Motoren. Alles gondelt seit Jahren durch die Gegend. Nicht nur zur Eisdiele, sondern auch gern mal 400km ab Stück zum Run.   Und ja, das KANN alles passieren was Du sagst, da gebe ich Dir ja Recht. Ich find die Darstellung von Dir nur Unglücklich gewählt.   Aber Gott sei dank kann ja jeder schrauben wie er mag, ich bin auch gern fasziniert, welch Aufwand bei dem ein oder anderen Projekt getrieben wird.
    • Wenn es sich hierbei um eine Eintagsfliege handelt, umso besser
    • Da das Personal hier auf zack ist und nicht schläft und auch Nachtschichten schiebt, sind diese Threads immer ganz schnell wieder weg. Da musst du schon recht fix sein, um das mitzubekommen.   Der nigerianische Prinz war gestern ...
