1. Int. Schaltroller-Cup Nürburgring 13.09.2009
  • Antworten 619
No worries bringing the beers to the track.
I'll see more difficulties in organising one of these nice blond chicks.
But lucky me I just advertised one crate of beer as a reward.... :-D
See you in May 2010!
Dirk
check in should be saturday evening, training and "race" should be sunday...
only one race! less track time!
BUT: "real" start refering to the laptimes from training session...
cheers!
momo
by the way, is the May event 2 days or 1 like September?
as the padocks are usualy open on saturday morning it is more or less a 2 day affair. and this one is very different to the reinoldus sprint as its a classic bike event with more than 350 starters. not one to miss.
and a handicap system - means you will have to carry some 50kg additional weight and a granny windscreen I am afraid :-D
Ok thanks.. a little more relaxed maybe? More social? More beers! :-D
Sounds good
I may even bring 'Marion' with her plate of beers :-D
Sounds good
and more social means even you have to mix with the german bunch :-D
Sounds good to me guys. But I feel a little awkward because I dont speak German and somehow it feels wrong to expect you all to talk in English as you kindly did. However... if you are ok I will practise my 'dankes' for the tall blonde girl that you will supply holding my beers! :-D:-D
Bearbeitet von tony englander
Sorry Marcus. I dont have a granny windscreen but I will bring my bike in the same form as I use it for work.... see below! icon1.gif
Schaltrollercup die 2te ist bereits in Planung. Der derzeitige Termin ist aber eher unglücklich......ich arbeite daran..... etwas Geduld noch Mädels :-D
    • Egal welche Bremspumpe: Der Hebel muss IMMER in Ausgangsstellung zurückgehen.    Ich würde mal die Pumpe zerlegen und schauen ob da Verunreinigungen drin sind.   Ansonsten hilft Folgendens beim entlüften der BGM-Bremszange (und aller anderen 4-Kolben-Bremssättel):   -Zu zweit entlüften -Pneumatisches Bremsenentlüftungsgerät verwenden -Eine Person hält den Bremssattel in einer Hand, und zwar so das das Entlüftungsventil an der höchsten Stelle ist. Mit dem Daumen dieser Hand den Gumminippel  vom Entlüftungsgerät auf das Entlüftungsventil drücken  und festhalten. Entlüftungsventil öffnen.   -Nun fängt der andere an das Entlüftungsgerät zu betätigen und füllt dabei dauerhaft die Bremsflüssigkeit nach. Das ganze ruhig mindestens 30 Sekunden entlüften. -Person 1 klopft während der Prozedur mit einem Kunstoffhammer immer wieder auf den Bremssattel um Luftblasen zu lösen und schließt anschliessend wieder das Ventil. -Nun den Bremshebel ziehen und für 5 Sekunden halten. Die Bremskolben fahren nun Stück für Stück aus. Einen 4mm Flachstahl zwischen die Beläge legen um die Kolben zu begrenzen. -Jetzt alle Schritte wiederholen bis oben am Hebel ein gescheiter Druckpunkt ist.   Das funbktioniert IMMER (wenn der Bremssattel dicht ist!)
    • Die Ausrede ist natürlich auch eine kreative Möglichkeit eventuelle Bußgelder zu umgehen.
    • Na dann mach doch unten 1mm und oben 1,5... oder fährt der Kolbenring oben schon raus?
    • @KickSt@rter Das E-Zeichen ist auf dem Glas. 11 & 12 - also für vorne und hinten zugelassen
