I´ve just measured a Vespatronic at a 133 ccm smallframe.
Retards the ignition about 8° between highest (25° at app. 3500 U/Min) and lowest (17° at app. 8000 U/Min) figure.
Exactly, what the top curve says.
Edit: Why do You doubt?
Bearbeitet von T5Rainer
Hi T5Rainer,
thanks for the info;
But I can see that your figures are not exactly the same as the curve ! At 3500rpm, curve says 23°, and 15° at 8000rpm; That's 2° difference compared to your measurements !
I have some doubt because I do not really expect, for instance, a 225cc longstroke largeframe engine and a 125cc M1L Quattrini to have the same ignition timings... I think the varitronic manual tells you to set the ignition this way or this way and it actually shifts the curve according to the engine type.
I agree that with +/-5° every curve should be the same, basically, same shape; but in your case 2° difference at 8000rpm is really a lot !
Thanks again, your inputs are useful ! :-D
Bearbeitet von KTy
The curve with 23° to 15° is just an example.
You can give it every figure You want by turning the plate. Only the the retard of 8° ist fix.
The user of the smallframe wished 17° at high rev.
OK, I get it.
Of course the curve does not fit automatically.
You have to ajust the position of the curve, just as with the normal Ignition.
Meaning: You make your markings at OT and, let´s say, 23° and turn the base plate and check the ignition at the plateau (maximum angle b.t.d.c.).
So if Rainer would turn his igniton exactly 2° clockwise he would exactly get the ignition curve shown in the manual.
Bearbeitet von Brosi
Guys :-D
I understand that !
I was just wondering what is the "exact real" timing advance curve when you mount the stator ACCORDING to the "official" instructions.
I am working on this :-D
Sorry for making things confusing !
Bearbeitet von KTy
The "real" timing advance varies. (As long as one would try to measure timings with a stroboscope and rpm meter, that is. And I think most people here do.) Just because the air/gas mixture influences the "real" advance as identified with/deduced from ignition (impulse via induction lead attached to the plug wire).
