  Am 23.2.2014 um 17:31 schrieb Motorhead:
sind aber verschiedene, oder? einmal SILBER und einmal SCHWARZ...
die schwarzen sind die, die ich meine. die silbernen sind noch härter und für meinen persönlichen geschmack zu hart. die brauch man höchstens wenn man mit alu scheiben und irgendnem zauber-öl fährt...
Hello,
I need to mount the primary and the repair kit alone in the engine casing ( the bell doesn't pass), but it's very touchy to make the springs fit, so I can't imagine in the casing.
It's very hard to keep the spring in place when I remove the two screws.
Do you have a trick ?
I use DRT spings.
Dammit ! The answer is in front of me, I have machined the primary for the DRT repair kit, so the housing in the primary is bigger than is the Hartz plate and bell... so it is a pain in the ass to mount it, I'll try to find another primary gear to check.
Bearbeitet von keuk
Hello even with another primary it doesn't work, the springs don't stay in place when I remove the 2 screws.. Anyone has a tip ? With a bit of dremel in the casing would it fit all together ?
Bearbeitet von keuk
if your primary gears don't have to bear more than thirty horse, you don't need the yellow springs.
you can use the red ones as well. wich will make it also easier to fit this tiny nasty springs.
you have to machine the pockets of the hartz backplate a fraction wider than the window of the gaer. so the spring will stay inside in the window of the primary gears
Edit:
I've noticed that you will start this year in class K2 - ok than - take the yel. ones :-)
Bearbeitet von wheelspin
Hello,
What is the minimum clearance I need to have a correct running ? Right know I have between 1,8 and 2,2mm between the last disc and the bell.
I have a 0,5mm spacer behind the christmas tree and I have one more that I can add if necessary.
Greetings.
Kein Keil zw. Kupplung und Nebenwelle???
Wie erfolgt die Kraftübertragung dann?? :wacko:
Also einfach auf die Nebenwelle bauen und festziehen??
Was versteht ihr unter einschleifen??
Sorry für meine NOOB-Fragen....
MFG ALEX
ahoi.
so. heut mal begonnen sicherheitshalber nach ca.4500km unbarmherziger falcpower die beläge zu wechseln.
kommen pro-x beläge rein.
wirkt, als hätt ich sie gestern erst zusammengebaut. ich bin begeistert. :-)
post-13165-0-78954000-1398106545_thumb.j
post-13165-0-05201600-1398106549_thumb.j
post-13165-0-79664700-1398106552_thumb.j
post-13165-0-31490500-1398106556_thumb.j
post-13165-0-02802900-1398106560_thumb.j
post-13165-0-84113500-1398106564_thumb.j
mal etwas ot:
hatte meine weelee-gepimpte xl2kulu letztens auchmal begutachtet nach ca. 6.000km. da waren im bereich ölleitblech und andrucklager üppige rückstände von metallischem abrieb zu sehen. soll das so? von den nasen der beläge oder dergleichen? oder bedenklich?
hi hab gerade n bisschen probleme den schraubnippel an die richtige stelle zu bringen. hab den hebel immer 2 - 3 mm mehr gespannt weil sie nicht trennen wollte. (kickstarter hat bei gezogener kupplung noch den motor angetrieben). jetzt hab ich noch mal nachgestellt und kurioserweise is es jetzt so das der kickstarter ohne kupplungziehen schon durchgeht. wenn ich dann die kupplungbetätige greift er n bisschen. kann man die kupplung auch zu weit zusammendrücken das sowas dann passiert? kann es sein das sie am anfang nicht trennen wollte weil die beläge irgendwie zusammengehaftet sind? (der motor is jetzt 4-5 monate nicht gelaufen) :blink:
so.
bin heute das erste mal mir den PRO-X belägen gefahren.
kann man nur empfehlen!
gehen super zum einschleifen. rupfen ist gar keines mehr zu spüren.(obwohls vorher auch nur minimalst war)
material wirkt zwar, als ob es nicht ganz so lange halten würden, wie das der ,,originalen,,
aber dafür fährt sichs (noch) schöner.
öl: louis 10w40 MA2 teilsynt., ca. 550ml.
Bearbeitet von simonB.
haste mal nen link zu den pro-x belägen? einschleifen ist bei mir im moment eine einzige katastrophe...
  Am 1.5.2014 um 19:19 schrieb pfupfu:
also wenns momentan eine katastrophe ist, weiss ich nicht ob diese beläge ein heilmittel sind.
meine war ja vorher schon mehr oder weniger ,,rupffrei,,.
denke da passt irgendwas anderes bei dir nicht so ganz.
  • 2 Monate später...
hallo zusammen
bin gestern mit dem roller zur nachtschicht gefahren. heute früh angeworfen über den firmenparkplatz gefahren. beim pförtner geschaltet. auf einmal oh hab wohl den leerlauf erwischt. dem war aber nicht so. ok. musste also 3 km heim schieben. und alle von der tagschicht grüßen. voll peinlich.
hab festgestellt das der kickstarter durchgeht und der kupplungshebel die ersten 5 mm locker ist. kupplungsseil am kupplungsarm is nicht mehr gespannt. also meine vermutung die kupplung is irgendwie verklemmt. nach den 5mm fühlt sichs ganz normal an. hab immer wieder gezogen und den hebel springen lassen. leider keine besserung. kennt das jemand. was denkt ihr was da is? werd wohl heut wenn ich ausgepennt hab wohl oder übel mal den kuludeckel wegschrauben müssen und schauen was zum vorschein kommt.
  Am 16.7.2014 um 05:34 schrieb Schnee83:
hallo zusammen
hört sich irgendwie eher nach durch gerutschtem zug im nippel oder aussenhülle im lenker an.
  Am 16.7.2014 um 05:47 schrieb wheelspin:
Konnte den Zug am Motor ohne Werkzeug aushängen. Keine Spannung mehr...
    • Beschreibung: 225 Rapido Race 27 Mikuni, 60/107 Sip Welle, Vape Zündung DC, Lth Membran, 150 LI Getriebe 16/46, PM 28 Auspuff MMW Kupplung, Casa Kettenspanner. 18,7 PS wegen Umstieg abzugeben. Kurve leider nicht mehr vorhanden. Preis: 2050 Standort:Tirol [Bitte Durchlesen und anschließend den diesen Erklärungstext löschen, wenn ihr eure Verkaufsanzeige fertig habt]   Verbindliche Regeln für den GSF-Marktplatz ab September 2024 Wir bitten wir euch um die Einhaltung der GSF-Marktplatzregeln, insbesondere der P.O.R.N.O.-Regeln: Preis angeben! Inserate mit Auktionscharakter werden ausgeblendet. Ort angeben! Selbst wenn ihr im Profil einen Wohnort stehen habt, der genaue Artikelstandort (gemeint ist die Stadt) ist Pflicht.  Richtig und vollständig beschreiben! Idealerweise mit Bildern, eventuelle Mängel müssen deutlich im Text ausgewiesen werden. Keine Links auf andere Verkaufsplattformen. Nur sachliche Diskussionen! Destruktives Runtersprechen von Anzeigen und Preisvorstellungen, Runterputzen und Stammtischgerede ist nicht erwünscht.   Ohne klare Eigentumsverhältnisse kein Verkauf! Der angebotene Gegenstand muss Eigentum des Topiceröffners oder der Topiceröffner muss durch den Eigentümer beauftragt sein, den Artikel im Auftrag zu verkaufen. Bei Verstoß gegen diese Regeln werden Inserate ohne Vorwarnung ausgeblendet, ebenso unseriöse oder grob unvollständige Inserate! Pro Mitglied und Rubrik (Biete/Suche/Tausche) ist nur ein aktives Inserat im GSF-Marktplatz erlaubt! Ausnahme: Für Artikel über €1.000 (z. B. Komplettmotoren) oder Teilesammlungen darf ein weiteres eigenständiges Topic eröffnet werden. Im Fall von Teilesammlungen jedoch nur, wenn diese ausschließlich en bloc zu einem Paketpreis über €1.000 angeboten werden. Hinweise für Inserierende Das pushen/hochschieben von Inseraten ist nur alle sieben Tage gestattet. Wenn ihr Infos nachtragen möchtet, macht das im Startbeitrag. Hinterlasst nach Abwicklung euer (hoffentlich positives) Feedback. Um Topics schließen zu lassen, ändert ihr den Titel im Startbeitrag auf "ERLEDIGT: alter Topictitel". Damit werden die Moderatoren aufgefordert, das Topic zu schließen. Allgemeine Hinweise Fair use! Wiederholungstäter_innen werden verwarnt bzw. temporär gesperrt. Achtsamkeit ist angebracht! Nicht alle Blechrollerfahrer_innen handeln redlich, anständig, und nach Treu und Glauben (gilt bei Kauf und Verkauf). Lasst euch stets eine verifizierbare Telefonnummer und Anschrift eurer Geschäftspartner geben. Schafft Transparenz, kommuniziert per Privatnachricht! Wann wurde überwiesen? Ist das Geld angekommen? Wann wurde versendet (Link zur Sendungsverfolgung)? Ist alles angekommen und im erwarteten Zustand? Der Betreiber des GSF ist nicht verantwortlich für die Richtigkeit der Angaben über die angebotenen Gegenstände. Wer private Geschäfte über das GSF abwickelt, gewinnt daraus kein Recht, die Plattform GSF für seine privaten Probleme, Strafverfolgung, Zeugenschaften und/oder Meinungsmache gegen Mitglieder oder Shops zu missbrauchen. Grundsätzlich sind dem Betreiber des GSF Realnamen, E-Mail- oder Postadressen nicht bekannt. Mit der Nutzung des GSF-Marktplatzplatz gelten diese Nutzungsvereinbarungen als anerkannt.
    • Und mit was wurde der Auspuff lackiert bzw beschichtet?
    • Jup, hat Spaß gemacht!   Und nachdem ich @t4. auf seinen auffallend roten Kopp hingewiesen hatte, musste ich zu Hause feststellen, dass meine Platte nicht minder rot war. An das helle Ding da oben am Himmel muss ich mich erstmal wieder gewöhnen...
