Hi every body !
I have a question about lowering front shock absorbers :
I've seen on SIP website a lowering part (Art:72000FA) for their Sip performer.
It realy looks alike with S&S lowering part for RS24.
As the principles are the same, do you know (or d'you think) the SIP part could be mounted on a Malossi Shock ?
:thumbsdown:
Thanks for your help,
Julien
Hi Julian,
we have tried the S&S part on 2 scooters and it works fine.
the german description of the sip-part tells me that you will disable the rebound adjuster.
But I'm not sure, maybe someone who really tried it will answer this question properly.
rgds
Thanks for your answer, I've also tried the S&S part on a RS24, it was not easy to take the original head off : finally, I've heated a bit... :thumbsdown:
But now I'm using my RS24 on another project and I need to lower it a little bit more. That's why I was wondering if the SIP part could help me. :crybaby:
