Outstanding Venue !
The historical "Kulturgut Eltzhof" is located in Cologne (Porz-Wahn)
Since 2005, the Eltzhof (former estate of the castle "Schloss Wahn") has been converted into a cultural center.
In addition to the Customs care available here year-round venue for a range of artistic performances and exhibitions.
In addition to the medieval facade, a brewery with 200 seats distinguishes the Eltzhof a large hall with modern equipment, bar, WOODEN DANCEFLOOR, acoustic and gallery.
The location has a excellent infrastructure:
Parking lot behind the house with S-train station and direct connection to Cologne Hauptbahnhof (10 minutes).
The Elzhof is next to Schloss Wahn, and is near the train station in Cologne-Wahn away. Here are the lines: S 12 and S hold 13th The descent is also possible with bus routes: 160, 162, 163, 164, 167, 185, 508th
Location on the main road, highway access in 5 minutes time!
Eltzhof Gastronomie & Veranstaltungs GmbH
St. Sebastianusstr. 10
51147 Köln
http://www.eltzhof-k...dex.php/anfahrt
http://www.eltzhof-k...dex.php/theater
Begin =
21.00 p.m. Start of "Rocket Soul Allnighter Cologne 2010"
2 x Floors Northern Sou, Modern, R&B, Crossover, Popcorn Soul, Trojan SKA (Arne Beykirch / London)
DJ Line Up:
- Dave C. (Hanseatic Soulful Society Lübeck)
- Nico de la Renta (Hanseatic Soulful Society Lübeck)
- Martin Ollmann (Hanseatic Soulful Society Hamburg)
- Jens Lücking (Hanseatic Soulful Society Hamburg)
- Martin Crout (Hanseatic Soulful Society Hamburg)
- Sir Matthew Fox (Cologne)
- Dave R. (Cologne)
- Marc-Werner (Cologne)
- Arne Beykirch (Greater London / Nürnberg)
- Tom (Nürnberg)
- Zippe (Cuxhaven)
Bearbeitet von Marc-Werner
Eigenwerbugn stinkt...aber
dieses DJ Lineup ist schlagkräftig.
"nochwas zur Info...FÜR ALLE DIE BEDENKEN HABEN SOLLTEN VON DA NICHT MEHR NACHHAUSE ODER
ZUM HBF ZU KOMMEN, RUHIG BLUT VORORT IST DER S BAHNHOF!" (Alkoholpegel)
Anbindung zur Autobahn, sagenhaft! Parkmöglichkeiten in rauhen Mengen!(Park & Ride/Bahnhof)
so die letzten Vorbereitungen sind quasi abgeschlossen und wir freuen uns auf Euch!
Parkplatzsituation ist wie gesagt sehr gut vorhanden. (direkt neben dem Eltzhof gibt
einen eigenen Eltzhofbesucherparkplatz sowie Supermarktparkplatz und P&R Parkplatz der
DB-S-Bahnstation)
anbei: im Eltzhof, ist Brauhaus/Restaurant vorhanden!
Getränke/Bar wird auf dem Nighter natürlich auch nicht fehlen!(in der Veranstaltungs
-halle)
Eltzhof
Sebastianusstr.10
51147
hier nochmal die Adresse...die eigentlich nicht zu verfehlen ist und eine sagenhafte Lage
hat. (Erreichbarkeit mitm Auto, S.Bahn(HBF ist 5 - höchstens 10 Minuten(dank der Stops)
entfernt) zu erreichen über die S.Bahn Linien S12(Fahrtrichtung Au/Sieg) und S13(Fahrt-
richtung Troisdorf)(beide von Köln kommend!)
Haltestelle: Porz/Wahn
´Fränky
...mist, mein Rücken.....
Aläng, jeff Gaas :thumbsdown:
Marc irgendwie erinnert die Eltzhof Location an das Wigan Casino....
Zufall oder nicht?
Bearbeitet von schlubbi
Ja Marc, auch wenn das Wigan Casino "über allem" steht und stand, so ist die Ähnlichkeit des Saals mit seinen Emporen und der Bühne frappierend !
Unter anderem deswegen waren wir so begeistert von der Lokation.
Das wird ganz großes Kino.
P.S.
Alain ist ein super Tänzer, als Veranstalter, genau wie ich, aber leider aus der Wertung für den schönen Pokal.
Cheers !
Marc
P.S.
Cheers !
Marc
alter ich werde alles geben um den pokal nach porz zu steppen,haha :))
Markus super !!!!!!!! Alles geben ! :thumbsdown::crybaby:
so Leude, dann schonmal im Wohnzimmer üben !!
    • Dito. Bis auf den nicht wirklich "besten" Duft absolut bedenkenlos zu empfehlen für "normale" Motoren (für high end Motoren kann ich keine Empfehlung aussprechen, da ich keine Erfahrungen mit dem Snowpower darin habe).
    • danke euch.    Also muss ich das wohl beides bezahlen.
    • Guten Morgen,   Vor einigen Wochen bin ich ja von Heilbronn nach Ingolstadt mit meiner PX gefahren.   Nach 30km Dauergas kurz vor meinem Ziel habe ich bemerkt, dass die PX zu vibrieren begonnen hat.   Die Vibration findet in jedem Gang statt, je höher sie dreht desto weniger spürbar.   Nun kam mir der Gedanke, ob sich die Welle verdreht haben könnte. Ist das heutzutage eigentlich noch ein Thema?   Motor hat keine 800km gelaufen, neue BGM Langhubwelle mit Malossi 210 drauf. Es gab keinen Klemmer oder so, auf einmal hat es nur ordentlich vibriert. Mittlerweile sind die Vibrationen bisschen weniger...aber dennoch merklich da. Die Glockenwelle meiner smallframe 154cc läuft dagegen seidenweich...   Gibt's ne Möglichkeit das im eingebauten Zustand zu beurteilen? Auch für Laien wie mich? Ist das überhaupt heute noch relevant?
    • Achso, naja nur um die Steuerzeiten zu messen, muss der Zylinder ja einfach nur an Ort uns stelle bleiben, da fallen ja keine Kräfte an. Beim Alu Zylinder machst du dir natürlich viel schneller Abdrücke mit den Muttern auf die Dichtfläche, wie beim Stahlzylinder. Aber ohne Kopf verteilt sich der Druck halt nicht auf die ganze Dichtfläche, sondern nur auf die 3 kleinen Auflageflächen bei den Muttern.   Beim 16er SHA fahre ich nun eine 80er Düse. Die scheint gut zu passen. Kerzenbild Rehbraun wie man es gerne hat. 78er & 75er Düse hatte ich auch mal ganz kurz ausprobiert. Bringt nix an TopSpeed, läuft dann so mager, das die Leistung einbricht und die Beschleunigung einiges schlechter wird. 82er war dann auch schon wieder ein wenig auf der fetten Seite.
    • Bin zum Schluss nimma so ins Detail gegangen   Aber danke für die Blumen!
