So here are the curves first is made at noon with a hot weather and the last one at the end of the day...
Both with 24/14°
Timings are 126/191
Bearbeitet von keuk
Noooooo. :wacko: that just 1hp more than my old iron polini which was a 51 stroke and Koso 28. I need 2hp more to be satisfied for the work done...
The soft engine is more strict and give 1,5 hp less than the P4.
I will try dicreasing the main jet a little bit more, the spark is still more black than brown.
I didn't touch the needle yet but it won't modify the max hp, isn't it?
Yes I'm gonna increase a little bit the ignition timing, right now I have 15° at 8700rpm (at the best hp)
For the carb setup the nicest curve is with the 135 jet, the blue one, I have two curve with the 135, blue and orange, but the orange one is not realistic because that's the second shot on the 135 test, so the temperature is not good.
So I have 10 points less than the "standards", amybe the flowing inside the casing / intake has an impact, everything is really smooth.
Bearbeitet von keuk
:wacko: where had all the horses gone ? *sing along*
that is the engine we're talking about a few times?
so I think I had to get my dremel and we hook up at mirecourt :wacko:
nope, needle and main, they'll go together and change a little bit. But I think that's not your problem, there is something else wrong.
it looks like a intake or exhaust duct problem - I don't know...
I'm serious, let's check the engine at mirecourt...
Yes, that's the same, that's weird, like if it didn't fill in correcly ( it doesn't need more that 135/138)..
Here is a photoshop with your SCK curve with almost the same setup (EDIT: except that I'm with a 53 stroke......)
In french we said "il marche comme une patate"....
Bearbeitet von keuk
:wacko: ouch! now I get you. please try a bigger main. 138 must be way too lean!
try a 150 at first and after that, try it together with the 1st or 2nd needle (CGL?) position from top.
my evo with 27cv like to have a 158 / CGL pos.2
any modification to the reed? 2 petal conversion? 0,35 or 0.33mm?
Two petal conversion for the reeds with the green polini sheet. I kept the metalic U parts that maintain the reeds. (?)
For the test I didn't modify the clip which was always at the 3rd position (middle) on the CGL.... damned I should have tried :wacko: this, I don't have access to the bench now until the race.
So first try was 153 / CGL 3rd and I get 18,5..... then I put 148 that's gave 20 then 145 20,7 then 140 and 135 to finish at 21,5hp...
ok, the green is .35mm
keep the stoppers! otherwise the petals will die instandly.
uh... sounds like the needle thing..
so gestern erste Ausfahrt mit dem Polini gemacht. Ging schon ziemlich gut!
Jedoch nicht lange! :wacko:
Beschichtung ist in einem großen Bereich von der Zylinderoberkante ausgehend nach unten abgeplatzt :wacko: Keine Reibspuren im gesamten Zylinder zu sehen!!!
Ist das ein bekanntes Polini Problem?
Bearbeitet von bodybuildinggym
abgedreht ja, aber von innen nach außen und dann noch mit Schleifpapieraufsatz entgratet. Danach kontrolliert.
Ich habe aktuell auch in anderen Karren keinen Aluzylinder, der nicht von mir abgedreht wurde. Keiner hatte bisher das Problem. Nur zweimal ein neu beschichteter Zylinder (1xhonda RS 250 und 1xAprilia RS 250). Beide waren schlecht beschichtet und auf Kulanz repariert worden.
das fräsen machte mich nicht besonders glücklich (abplatzer selbst mit SCHLEIFROLLEN)
feine oder grobe röllchen?
Bearbeitet von maccoi
Ich würde mich einfach mal an den Händler wenden, wo ich den gekauft habe. Klingt ja nicht so, als sei das ein bekanntes Problem und somit liegt die Vermutung nah, dass du einfach einen schlecht verarbeiteten erwischt hast.
So rein rechtlich gesehen, müsste der dir ja im ersten halben Jahr der gesetzlichen Gewährleistung sogar beweisen, dass dein Schaden nicht an einem Produktionsmangel sondern an deiner Bearbeitung liegt. Oft ist aber ein Pochen auf sein Recht garnicht nötig, weil einem eh genug Kulanz entgegengebracht wird. :wacko:
grob
ja hatte auch mit groben röllchen am fuss getestet - kommt schnell zu ausbrüchen,
mit feinen röllchen hat dass dann aber 1a funktioniert - ist halt eine geduldsaufgabe
Hallo
Ich baue in den nächsten Tagen für eine Freund ein Drehschieber-Motor auf!
kurz das Setup
Evo 130
Mazzu-Welle 51/97 leicht geschnitten
Keihin PWK 33 + Parmakit ASS
Vespatronic
Big Bertha
XL2 Kulu mit Xyger Deckscheibe (hier die Frage welche Federn?)
Übersetzung 2.56 mit kurzen 4. von DRT
Motor wird bei den Überströmern und am Einlass geschweißt
Auf welche Steuerzeiten soll ich mit dem Auspuff gehen? Sollte ja ein Straßenmotor werden und nicht ganz so auf Spitzenleistung ausgelegt sein.
Und ich hab das Problem mit der Beschichtung beim fräsen gelesen! Hatten das schon viele hier oder waren es Einzelfällen wegen schlechter Beschichtung?
Muß man sonst noch auf irgendwelche Dinge aufpassen?
Tja, da ich in der Nähe von Köln bin, betslle ich immer dort.
Der Zylinder ist oben, unten abgedreht. Der Auslass gefräst und die Überströmer im Zylinder vergrößert. Ob da Polini/SCK Bock drauf haben :wacko:
Vielleicht kann der wheelspin mal etwas dazu schreiben... :wacko:
Hallo
kurz das Setup
Evo 130
Vespatronic
Big Bertha
der auspuff muss da angepasst werden !
warum kein franz oder feuerzauber .
die bertha wurde mal für nen sp09 mit 128/192 gebaut +/-
dachte mir nur, dass die Bertha gut passen könnte! ok Franz wäre auch ne Lösung! Steuerzeiten 126/186-188?
    • Mein Beileid!  Danke für alles! Es tut mir so leid!
    • Gibt es Immunrezeptoren? Ist das die kombinierte Immuntherapie? Wenn ja, kann ich Dir berichten, dass die meine Frau ziemlich sicher gerettet hat und das war vor zwei Jahren, was soweit ich weiß in der Krebsforschung schon wieder eine halbe Ewigkeit ist. Die Zulassung der Immuntherapie war wohl noch ziemlich frisch, aber sie hatte auch schon Leber- und Lymphknotenmetastasen. Die waren nach der Immuntherapie verschwunden und die Zelluntersuchung des operativ entfernten Gewebes hat keine lebenden Tumorzellen mehr gefunden. Sie hatte allerdings HER2neu triple positiv und keine Hormonmarker. Es könnte also auch die Chemo gewesen sein.  Die Mediziner in meiner Familie haben mir von einer damals laufenden Studie in Luzern zur Laboranzucht eigener Antikörper berichtet. Wie weit da die Zulassung ist, mussten wir dann nicht mehr verfolgen.  Was Dir die Entscheidung wahrscheinlich zusätzlich noch schwerer macht, ist, dass Du diesmal weißt, was auf Dich zukommt und das ist nunmal ein echt hartes Brett. Ich kann Dir nur wünschen, dass das Ergebnis auch so eine positive Überraschung wie bei meiner Frau sein wird.
    • und das kleine I blinkt und blinkt... sagt "schreib doch was!".. schreib was du fühlst, denkst. Ihm noch sagen willst... Tod du bist ein ARSCHLOCH! Du nimmst, schneidest weg, machst das Licht aus.  Wie kann ich jemanden danken, der nicht mehr hören kann? Könnt ich malen, so wär es der kleine Mann auf seiner VBA. Sein alter Rucksack weht im Wind wie er gerade um eine Kurve fährt.  Könnte ich ihm nochmals danken, so wäre es für die Stunden in der Werkstatt. Er fluchend, weil diese rebellische Mutter nicht ihren Gang fand. Ich genervt, weil er fluchte... Was würde ich geben, nochmals genervt zu sein.   Rainer hat der Szene so viel gegeben, mit seinem Einsatz, seiner Arbeit (vor und hinter der Bühne). Rainer war mein Freund, der Stammtisch, war unser Tourguide, unser Organisator, unser Flyer...    Mit nicht nur einer Träne...    machs gut
