Sa. 21.5. Northern Soul Allnighter@Motte Hamburg
Wow, after a fantastic 2nd Anniversary we are back with a bang!!!!
As always, you can expect some TIP TOP 60's & 70's INDEMAND-CLASSIC-OBSCURE NORTHERN SOUL, CROSSOVER & RnB MONSTERS ON ORIGINAL VINYL +++ and dance the night away on a Fantastic Wooden Dance Floor!!!!!!!
DJs: Gerd Baum + Matu + Viphitman
...Special guest Dj for this event will be Gerd Baum form Düsseldorf, which many old timers will remember as one of the top Soul Dj's during the 90's in Hamburg!!!! Now he lives in Düsseldorf and has been playing at various Allnighters around the country. He really had the dance floor rocking at the the 2nd anniversary so we are so glad to have him back once again!!!
Also at the decks will by the mighty Matu who has been playing records @ the ‘’For Dancers Only’’ Soul Club Hamburg for many years. A top man with a huge passion for everything soul that shines through every set he plays!!!
Last but not least your host viphitman will introduce you to some obscure gems and entertain you with some great classics .....So, Put On Your Dancing Shoes It's Soul Time!!!!!!!!!!!!!!!!!!!!!!!
...Komme aus Hamburg, das bietet sich dann selbstverständlich an mal dort vorbei zuschauen.
Hoffe dass die Eintrittspreise wie immer in dieser Location fair berechnet wurden.... VG
Bearbeitet von t4.
Sachfremde Links entfernt.
Only a few days 2go!!!! As always you will hear some fantastic classic tunes but also some obscure ones!!! Like this one, first time to be played in Germany !!!! Keep On Soulin & c you @ Northern Soul Allnighter @ Motte
    • Dass der Zug strammer wird, habe ich noch nicht erlebt. Eher das Gegenteil, also dass man mitunter mal nachstellen muss, weil er sich mit der Zeit etwas längt.   Könnte allerdings sein, dass der Zug aus irgendeinem Grund zu kurz ist und beim Einfedern wird er dann jedesmal auf Spannung gesetzt. Ich würde da den Zug inkl. Hülle tauschen. Dann neue Kupplungsbeläge rein und das olle SAE30 rauskippen. Stattdessen ein modernes Öl wie Castrol MTX 75W140 oder Motul Gear Comp. 75W140 reinschütten. Etwas härtere Kupplungsfedern könnten auch nicht schaden, wenn da Tuning im Spiel ist.
    • So, hab jetzt auch den BGM Pro SC Competition drin. Sieht ok aus in der Grundstellung, oder?
    • suche originalen, funktionierenden sx tacho
    • Drehzahlschwankungen, ohne dass es sich nach Gehör verändert deuten auf ein schlecht abgegriffenes Signal hin. Achte darauf das Zündkabel ein paarmal eng zu umwickeln. Erst wenn das klappt kann du an die Messung und Einstellung gehen. Mein Drehzahlmesser von Amazon hat 15 € gekostet, aber funktioniert.
    • Hallo zusammen,   ich hab eine PK50 XL2 HP4 mit DR75, die komische Sachen mit der Kupplung macht.  Zuerst musste ich bereits zweimal in einem zeitlichen Abstand am Kupplungszug den Endanschlag vom Seilzug lockerer stellen, da die Kupplung durchgerutscht ist. Dann hat alles wieder einwandfrei funktioniert. Jetzt ist der Zug aber nicht zu stramm eingestellt und die Kupplung rutscht. Jetzt hab ich erstmal das Getriebeöl gewechselt, denn es war auch etwas zu wenig drin. Hab das richtige SAE 30 genommen.  Aber die Kupplung rutscht immer noch. Schalten lässt es sich noch einwandfrei.    Wieso wird der Kupplungsseil-Weg immer strammer?  Was meint ihr - Kupplung tauschen?   Vielen Dank!
