tausche gerade die gabel meiner früher serie 1 (framebreather) gegen eine tv2 gabel und stelle fest das teil ist zu kurz.
oben fehlen ca 3mm. lagerschalen unten auf der gabel scheinen gleich.
ausser 2 mm bei der lagerschale unten abnehmen und dann wieder draufsetzen sowie oben die nut für den lenkerbolzen nach oben erweitern fällt mir gerade nicht ein.
hat wer eine idee oder kennt sich mit den gabellängen bei li1 tv1 / li2 / tv2 aus ?
tja, "sticky"..
da vertraue ich mal jem booth vom lcgb mehr:
Lambretta Forks
The subject of different Lambretta forks always appears as does trying to identify them.
Here’s a detailed list supplied by Jem Booth
Italian Series 3+ GP - has speedo/front brake cable support as separate piece - also has cut out for headset clamp at the side of the thread (in line with front wheel)
Chrome ring
From bearing track seat to centre line of steering stop = 361mm
From bearing track seat to bottom of thread = 413mm
From bearing track seat to top of fork stem = 467mm
Non chrome ring
From bearing track seat to centre line of steering stop = 355mm
From bearing track seat to bottom of thread = 405mm
From bearing track seat to top of fork stem = 458mm
TV 200 - Chrome ring
GP
From bearing track seat to centre line of steering stop = 330mm
From bearing track seat to bottom of thread = 380mm
From bearing track seat to top of fork stem = 438mm
Italian Series2 - has welded on "loop" for speedo cable/front brake support - also has the cut out for the headset clamp bolt at the rear of the thread (at 180 degree to front wheel)
TV175 S2
From bearing track seat to bottom of thread = 412mm
From bearing track seat to top of fork stem = 462mm
LI 150 S2
From bearing track seat to centre line of steering stop = 359mm
From bearing track seat to bottom of thread = 407
Spanish
JET 200 -Large damper type - have single damper stud of 9mm diameter welded to single plate at top of fork leg. Also has cut out for headset clamp at the side of the thread (in line with front wheel)
From bearing track seat to centre line of steering stop = 358
From bearing track seat to top of fork stem = 460mm
Das weiß bestimmt "inna_halle". Der hatte monatelang eine S1 Gabel zum Verkauf die er beschrieb mit "ganz früh" und "ist anders" oder so ähnlich. Ist länger her deshalb nicht mehr präsent bei mir, die Gabel scheint mittlerweile verkauft oder ich find grad das Topic nicht mehr.
hat vielleicht jemand eine späte li1 gabel ?
Ja.
Kann ich aber nicht messen, da ich auf ne S2 Gabel warte, die ich in die Erstserie reinbauen will.
Die liegt allerdings noch bei inna halle... ;-) / :wacko:
Bin aber für Angebote offen, da ich die wie gesagt einbauen will- dazu muss die leider geliefet werden und DAS passiert nicht
