Hello,
I am fitting a imola 185 cylinder to my li serie3. I definitely want to keep it inside the side panels without cutting holes in the side panels.
I already tried with the standard manifold and the standard reedvalve with a phbh 30mm and tino Sacchi air filter, but its way to big to keep it inside.
is there anyone who has this cylinderkit inside the sidepanels?
thx
The cylinder-kit is not part of the problem. Same same, as TS1.
You will need a special manifold and a short carb.
Bearbeitet von T5Rainer
hi lord sinclair,
Do you still use the toolbox? or did you have to remove it?
I also bought the manifold you posted, but then you have to change something with the reedvalve? or how did you did that?
which airfilter are you using?
is it possible to take a picture?
thanks
cedric
thanks!!!! Did you have to modify something on the cylinder to fit this reedvalve?
thanks
