Hello,
Sorry for speaking englsih, I don't speak any German.
I'm about to start the restoration of a GS150 VS5.
Engine is a puzzle, I have already collect a lot of parts, but I know for sure that the carb is really out of order, too much play everywhere.
Anyone managed to make a modification to fit a newer carb on the original cylinder ?
Thanks for your help.
Hello,
I recently saw a conversion to a 24 or 25mm Dell'Orto PHBL carb using a self-built manifold (pipe elbow welded to a flange plate) at a local Vespa store.
I saw this at Kudlicka & Radakovics', looked exactly like in Latzek's post.
Ku-Ra is a legendary Viennese Vespa Garage run by a ~70 year old Croatian-Italian misanthropist.
They don´t have a webshop, if you are business fluent in Viennese German with an element of Croatian, you might want to give him a call: http://www.kura.at/kontakt.htm :wacko:
Hello,
Yes, No problem there is no hurry, I'll have to rebuilt the engine before. Lots of work and parts needed I think.
Yes about the manifold and if you can get the info about jets and needle used in which carb, that would be a great help.
Thanks a lot.
