Hello,
I would like to drop a little bit more my front suspension on a PK steering column. I have a already the scooter&service part on the rs24 but that's not enough.
Anyone knows the following dimension on the Stage6 part adaptor ?
A would like to gain up to 20mm, but the adaptor doesn't have to be to high if I want to keep the mudguard...
Here is a photoshop test: actual/modified
the main problem is, that the S&S kit wont fit into the stage six drop kit.But its possible to grind/turn it to reduce the diameter of the S&S kit.
The next problem is that the bolts of the stage six kit wont fit because of the upper spring ring of the rs24.
Yes I intended to mill the S&S part to fit it... for the bolt no problem neither, I will use FHC screw.
I found the information, the distance is 18mm, with 6mm thickness.
