This is a bit off topic, but as this topic was a little widespread from the start, please forgive me.
First of all I don't think that a big and involving cylinder transplantation is the most reliable you can do to your motor, but when it first is to be done, I would use the PX80 engine case as a starting point. The crankcase is small, with a welded on reed housing you can get a high compression. I think fitting a mal210 would be easy compared to many of the other transplantations done. Capacity 177ccm. Off course weld on and spindle out to the cylinder spigot, fit M8 studs. Not sure about the connecting rod length, but the cylinder can be shortened 10mm from top, set 1mm higher at bottom, increasing the durations of the ports to some very nice numbers. Raising the exhaust port 0,5mm widen it 4mm provide a time-area often only achieved by motocross engines. Exhaust duration 200,1 degrees, main transfer duration 132,4 and blowdown of 33,8. The engine would probably be able to rev to 13000 and with max power at 10000, 30 hp would be no problem. Maybe the gearing would come to short, but then again, a tuned t5 engine reach almost the same revs. Off course this transplantation would be involving in making a purposeful exhaust, and expensive to the cost of decent components like crankshaft, carburetor etc but not much more expensive than normal high level tuning. I think the most favourable issue is that the cylinder kit is cheap and quite easy to replace compared to f,ex an aprilia cylinder and other foreign cylinders. Then fit this engine in a smallframe and you have probably the ultimate thrill!!
  • Antworten 63
I don't think such an engine would ever see more than 10+k rpm. With only 48mm stroke there would be far too little time area, wouldn't it?! Wouldn't fitting a complete P221 engine be much easier with even more fun? It is already pretty hard to get into the 30 bhp range with 60mm stroke, why would it be easier with only 48?
But nice idea anyway... get's one into thinking outside the box :-D
Bearbeitet von Gerhard
With 48mm stroke there is more duration of the ports letting it rev higher. the area of the ports are still the same and the time area is less for the shorter stroke, there is less time for the gasses to flow and they flow faster making more power.
Off course the 221 would make most power of the two at 10000rpm. But with a 221 this would mean a lot of working with the porting layout, changing areas and durations, I don't think the basic design of the cylinder and piston would let this happen. At 12000 with a 221 the piston speed would get too high and the rings will start to flatter when maximum power is achieved at more the app. 9000 rpm. the stroke is the only determinating factor for this to happen.
For me it seems that when combining 48mm stroke with a malossi 210 the proportions become what is more similar to a modern motocross cylinder.
Can somebody else do some calculations around this and see if we get the same results. In the logic theory it's not that far off the line??
why should they flow faster? There is less time for them to flow, so they flow less! Simple is that. :-(
Modern MX Cylinders with about the bore of the Malossi (=250cc mx cylinders) have longer stroke than bore. Well, why is that? With the bore becoming bigger displacement increases ^3 whereas cylinder wall only increases ^2. They need the long stroke because they run out of cylinder wall for ports!
Optimum displacement for a two stroke cyl is 125cc with bore=stroke.
Gast
    • Ich rate jedem Anfänger von einem Venturi ab. Die Abstimmung ist deutlich schwieriger im Vergleich zum originalem Filter. Zumindest habe ich es nie vernünftig hin bekommen. Hier sieht man auch mal wie viel ein Venturi wirklich bringt:   Also meine Empfehlung, nimm den originalen Filter dann sollte deine montierte Bedüsung passen, eventuell die ND etwas fetter.
    • @Merolino Und was deine HD-Bedüsung angeht, sieht es nach meinem Dafürhalten so aus.   Dein Setup: Motor:  rennkurbelwelle Sip kurz 57 Vmc stelvio Venturi LuftfilterSchlauch montiert Polini Box Vergaser: 24er (schwimmerkammer/Düsenstock auf 3mm aufgebohrt) BE 3  HD 128 ND 55/160 HLKD 160 BE9ES Zündkerze Luftgemischschraube 2.5 umdrehungen raus     Für den Zylinder wird bei einem Standard-Setup (also ohne Venturi, ohne Polini-Auspuff und statt dessen mit Standard-Auspuff) von SIP eine HD zwischen 125-130 empfohlen. Das ist natürlich nur ein grober Anhaltswert und der Vergaser muss richtig abgedüst werden!   Unter der Berücksichtigung, dass du einen Venturi am Vergaser und den Polini-Auspuff verbaut hast, wird die HD wahrscheinlich etwas fetter sein müssen.    Was nun nicht gut wäre, einfach eine HD zwischen 125-130 reinzuschrauben und mal zu sehen, wie das läuft. Das kann erst mal gut laufen und trotzdem die falsche Bedüsung sein, wobei zu mager schlechter als zu fett wäre.   Daher ist die Vorgehensweise immer gleich: Schraub eine HD rein, mit der der Roller beschissen läuft und viertaktet. Könnte z. B. eine HD138 oder 140 sein.   Dann suchst du dir eine ebene, sehr lange Strecke und fährst die Strecke Vollgas. Und nun düst du, immer nur die HD verändernd, sukzessive herunter in Richtung mager. Jedes Mal nach Veränderung der HD die Strecke mit Vollgas fahren. Und wenn du die HD gefunden hast, mit der der Roller am schnellsten läuft (GPS hilft dabei mehr, als ein ungenauer Tacho mit heftig ausschlagender Nadel!), dann gehst du wieder 1 HD-Düsengröße (max. 2) nach oben. Und das ist dann die richtige HD für eine Straßenabstimmung für dein Setup.   Für die ganze Aktion musst du dir mal 1-2 Stunden Zeit nehmen.
    • Matzmann hat es ja über mir bereits ähnlich geschrieben, ich würde jedoch noch einen Schritt weiter gehen und einem „Sammler mit 20-30 Modellen“ etwas mehr Fachwissen unterstellen. Oder - wenn ich etwas deutlicher werden darf - mit diesem Fachwissen einem begeisterten (Wieder-)Einsteiger wie Guido264 gegenüber etwas ehrlicher zu sein.   Für mich klingts derzeit (und wie immer bei diesen Geschichten) einfach nur nach nem Vertreiber von nem Container voll übergejauchter Spachtelreusen, der nur auf den inzwischen durchaus wohlsituierten Alt- oder Neurollerfahrer lauert, der dank fast abbezahltem Eigenheim über das nötige Kleingeld verfügt und vor lauter Begeisterung, sich so etwas „mal gönnen zu können“ spontan erblindet ist.   Nichts für ungut, Guido, du hast es ja rechtzeitig rausgekriegt. Hier gabs auch schon welche, die bereits gekauft hatten und voller Stolz hier ihren vermeintlichen Schnapper präsentieren wollten und relativ unsanft auf dem Boden der Tatsachen gelandet sind. Ist dir erspart geblieben.   Hier geht es immer mal rauh zu, richtig, aber du findest hier auch zu jeder boch so bescheuerten Schraube, die jemals in einer Vespa oder Lambretta verbaut wurde einen, der sie kennt und dir was belastbares dazu sagen kann. Nutz das.      d.
