Swap 1962 Vespa 150GL for 15+bhp sf engine
Hi!
I´m swaping my italian 1962 Vespa 150GL for a smallframe engine with 15bhp+
It is in Norway, but I´m able to deliver in Hamburg for a litle fee, or we agree on something.
As said, it is a italian Vespa 150GL sold new in Norway and with Norwegian papers in my name
As you can see from he pictures it is built as a Rust Rod now.
The frame is an original VGLB except for the cut-out for the PM Up´n Over. (the cut-out is bent under, so it is just to weld back in place)
  • PKXL2-fork
  • APE-steering
  • Re-welded tank to be able to mount seat that far back
  • Malossi 210-engine: Worb5 57mm crank, Malossi Reed, Dellorto PHBH30, PM Up´n Over (this is not included in the swap!)
  • VL rear light
  • Yellow fog light.
  • 120/70 rear tyre on SIP wtk
  • 3.00-10 front tyre
In addition all the parts to make it original comes along;
  • Original tank
  • original steering
  • original fork
  • original front fender
  • original side cowlings (right and left)
  • brand new electric harness
  • There are missing some parts as lights, speedo, but nothing major.
For the moment the lights doesn´t work due to homemade electric harness, but should be easy fix.
As said, it comes without the Malossi engine. Then you get a 3 speed 150ccm VGLA1T engine instead
I want to swap for a smallframe engine to have in my 90Racer.
Let me know what you have, and we might agree on it.
Rgrds
Øyvind
    • 200er ist eigentlich recht simpel - hier mal eine Bildergeschichte mit Bauerntechnik - der Trick mit der abgeschliffenen Mutter, die durch das Silentrohr passt, aber nicht durch die Beilagscheibe zwischen den Rohrenden:
    • Hi, verkaufe meine Sprint 150.  Zustand m.E. Top. Soweit ich das beurteilen kann O-Lack. Die Karre hat einen 177er Parmakit, 30er Mikuni Crimaz Scheibenbremse vorn und Crimaz Geberzylinder unterm Lenker. Bremst gut und hat einen cleanen Look. Sip Vape Zündung Motogadget m.Unit mit m.button, Verkabelung komplett neu Vorne und Hinten Sip-Dämpfer, vorne mit verkürzter Feder.  Streamline Sitzbank mit Alcantara und Scharnier, Custom Verriegelung Das Windschild ist Custom   Der Motor wurde vor 2 Jahren komplett gemacht, mit Kurbelwelle und Zylinder. Momentan ist die Batterie platt und Die Bremse schleift vorne irgendwo. Das würde ich noch richten und dann einmal neu TÜV bei bedarf. Zustand siehe Bilder. Wenn wer noch weitere Bilder oder Infos benötigt einfach fragen.   Standort 21521   VB € 6800,-
    • Suche für meine Px 80 Lusso Bj 90   Eine intakte Orginal Kurbelwelle, Eine Orginale Kupplung und eine Sitzbank mit Griff. Dankeschön
    • Meine,91126 Schwabach, Versand DHL, Zahlung Paypal, gebraucht, funktioniert einwandfrei   Zündung VESPATRONIC für Vespa 125 GTR 2°/TS 2°/150 Sprint V 2°/Super 2°/200 Rally 2°/PX80-200/PE/Lusso/Cosa mit mmw Alu Lüfter  1690gr   Teile wie auf dem Foto   Preis mit Versand 225 Euro                 Malossi 221cc bearbeitet  (60HUB) 4630 km   top   Auslass Höhe ca45mm Auslassbreite ca 44mm 1mm Fudi 0,5kodi ca 190° /128-129° Kopf: 10,5:1   Kolben offen mit GS Ringe   Preis: 280Euro   Kurve: mit der Vespatronic RD350membran und dem Zylinder Vergasertest TMX35 KEIHIN35 PHB30  (Viperbox)
    • ja, Lochrohr nur gesteckt. Das wird auf Dauer nicht halten -> so meine Erfahrungen Das Lochrohr deckt auch nur ca 20 cm ab im ESD. Da wäre noch massig Platz für mehr. Da hat sich einer wirklich Gedanken gemacht 🤔😆
