Hello,
I'm about to shorten my PK XL steering column.
Could anyone give me the original angle of the lever ? (wheel in the air)
Right now the lever is too horizontal, so the wheel is about 1cm backwards.
I have the S&S part (-18mm) and a own plate (-18mm) so -36mm on the RS24.
Here are few tests to see what the angles would look like.
Steering column 19mm shorter:
Steering column 30mm shorter:
Steering column 35mm shorter:
Bearbeitet von keuk
Hi Keuk!
I think, that the angle to the street is more important!
While damping, the wheel is rotating around the fork. When you are shortening the damper to much (so that the lever is parallel to the street) you will get in trouble because your getting less castor while breaking.
This will cause a very nervous braking behaviour.
In your position, i would check for the angle of the lever to the ground, not to the fork.
:cheers:
Tim
P.S. (measured on my shortened PK fork with shortened damper ~110°)
Bearbeitet von Tim Ey
Thank you for the answer Tim,
Now, with the wheel on the ground and me on the scooter, the angle is almost 90°.
Bearbeitet von keuk
Have a seat on your handlebar :-)
When the lever is allmost parallel to the ground - I would take 1-1.5cm out of the fork. I dont with how much g you can brake, and how the force on your frontwheel behaves, but i think it must be round about the weight you get while sitting on the handlebar.
Any other opinions?
Ah, ok. Wrong translation. Yes, I am talking about trail.
When you have an other point of view on this, please let us know. Whats wrong about my thoughts?
I think the points you made are perfectly valid, I just couldn't makes sense of "castor". Plus I think it possible to decelerate with more than one G.
Maybe it would be possible to do a dummy setup to check which starting angle would be the best for the full suspension travel to chance trail the least? I mean with the trailing link in a line with the fork leg the wheel elevation curve is likely to change trail quite a bit, whereas with the link starting around 90° or thereabout it would have comparatively little effect in that respect. I'm to thick to check that without resorting to the dummy setup solution. Does that make sense?
Question is how much effect you really notice in practical track use. This summer I mounted a SIP damper for PK to a std PX fork. It looks almost like your fork now. About parallel to street level when driving - trail is biggest possible, running very stable. When braking or having bumps trail gets smaller but steering is getting not nervous (at least i don't notice). I guess the shorter you make the column, less directional stability you get. I wouldn't expect too much effect on damping behaviour.
Well I'll try the 30mm first as a dummy. The 35mm looks a bit too much.
Perfect, I have just cut the column, now I need to make machine a part to put inside, what thickness are you guys usually using ? 2mm? 3mm? More ? There was a thread talking about that but I'can find it...
Bearbeitet von keuk
It's only there to centre the whole thing, so 2mm is plenty, I'd say. Best chamfer the cut ends so that you end up with a V-groove which is easy to fill with weld then.
Hello,
I think you're asking for the wrong angle in this context. The more interesting position is the angle with zero travel of the shock left. After your modification, that angle should be about the same as stock, or at least not that far from it. If you should happen to overdo things, your lever might get pulled to horizontal when braking thus pulling on the shock, and you don't want that as it diminishes braking efficiency.
Interesting point of view. So I should compress the shock at the maximum, and ensure that the lever is just before horizontal position (arround almost90°/column) to have a good breaking effixiency right ?
I think you can go a little beyond this point without running into negative effects. Unfortunately I lost my notes from when I shortened my fork and shock a couple of years ago. In most of these cases, the shock travel will be reduced a little if the shock is shortened.
I did the following:
  • stock fork and shock, shock mounted in stock position, compressed to maximum, took a picture of the angle, took a test ride (brake)
  • stock fork and shock, shock mounted in the above position, again compressed to maximum, took a picture of the angle, took a test ride (brake)
this setup showed to be less likely to dive when hitting the brakes hard without negative effects that I could feel. It became the setup of my race scooter (and many others are driving like that as well)
  • stock fork and shortened shock, shock mounted in the above position, again compressed to maximum, took a picture of the angle, took a test ride (brake)
that was too much, felt like you're on a ship in stormy weather when braking. also, braking performance suffered quite a lot.
So, for my shortened fork, which was to be run with a shortened shock with shorter travel than stock, i calculated how much the fork had to be shortened to end up in the position I liked when the shortened shock was fully compressed. If you lose shock travel by shortening it, it is never the same amount that you have to shorten your fork if you want to end up in the same position.
    • Hallo.  Ich hätte einer Frage an die Profis hier. Und zwar geht es um  einen Wideframe Grauguss Zylinder. Dort ist ein Yamaha Kolben verbaut. Leider habe ich jetzt erst bemerkt, dass der Ringstoß sehr knapp am Boostport verläuft.  Es sind ca. 2mm Platz (Markierung  oben  auf dem Kolben zeigt die Position des Pins). Der Kolben Ring kann sich auch noch 0,8mm nach links u. rechtes in seiner Nut bewegen. Somit trägt nur ca. 1mm die ganze Spannkraft des Ringes. Ich haben Angst, dass das auf Dauer einläuft. Mache ich mir da umsonst Sorgen?  Und, kann ich den Kolben am unteren Hemd noch an die Überströmer anpassen, oder verliert er an Stabilität, weil ich die Strebe in der Rundung durchbrechen muss.  Ganz lieben Dank für eure Hilfe
    • Hi zusammen, ich überlege mir eine Vespa zu kaufen, primär als Alltagsfahrzeug um täglich 2x6km zur Arbeit und zurück zu fahren. Da ich mich nicht wirklich gut auskenne, hatte ich überlegt eine Vespa Px125 von einem Händler / Vespageschäft zu kaufen und nichts von privat. Auf Kleinanzeigen habe ich folgendes Model gefunden: PX125 von 2002 für knapp 2800€ mit 18.000 KM. https://www.kleinanzeigen.de/s-anzeige/ ... 4-305-6041 Alternativ hat der gleiche Laden auch noch eine PX125 in schwarz für €3400. https://www.kleinanzeigen.de/s-anzeige/ ... 5-305-6041 1) Was haltet ihr von den Preisen? Sind die fair? 2) Wie gut eignet sich eine Vespa PX125 als Alltagsfahrzeug für ehr kürzere Strecken (5-6km einfach)? 3) Was sind aus euren Erfahrungen die durchschnittlichen Wartungskosten pro Jahr für eine PX125 in dem Alter und den KM (15-20K)? 4) Es scheint so, als wären beide Modell aus Italien importiert. Hat jemand Erfahrung hiermit? Es gibt noch eine deutsche ähnlich wie die ersten beiden, in welche aber vermutlich mehrere hundert investiert werden muss und der Lack an einigen Stellen ab ist: https://www.kleinanzeigen.de/s-anzeige/ ... 9-305-6041 4.1) Würdet ihr eine deutsche etwas heruntergekommene Vespa gegenüber einer italienischen bevorzugen? Wenn man die Differenz in eine technische Aufarbeitung investiert, weiß man wenigstens was man hat? Oder kann man bedenkenlos auch bei italienischen Modellen zuschlagen. Ich bin über jede Unterstützung dankbar!
    • ist schon richtig, da hat jemand seinen durch zertifizierte fachkompetenz gegebenen spielraum glücklicherweise weiträumig genutzt. gibt es leider immer seltener. wenn das mit licht und kennzeichen aber tatsächlich auch gegenüber der unbedarfteren exekutive so durchgeht, dann eröffnet mir das halt für bestimmte vorhaben neue horizonte, daher die frage. verstehe aber auch, wenn die nachfrage unbeantwortet bleibt...
    • trotzdem zieht das Gemisch unter dem Kolbenboden ein, wird im Kurbelwellengehäuse, also unteres PlLager verdichtet, schmiert schnell und wird über die ÜS nach oben gedrückt.Ich seh da kein Problem..   Quattrini M1XL sowie einige SF Zylinder haben da meiner Erfahrung nach auch nie Probleme gemacht. Lamy kenn ich mich nicht aus
    • Bei mir geht’s ja um gs4?! also nix drehschieber!  deswegen finde ich die Lösung total gut!
