Für alle die, die Facebook nutzen ist das hier mal ganz informativ! :-) was haltet ihr davon?
https://www.facebook...92221864&type=1
für alle anderen hier der text dieser seite...
VESPA TIME AGAIN ......... MB T5190 KITS
am Donnerstag aktualisiert
These old MB T5 kits have started to become demanded again. They lost favour for many years because the Italians brought out big bore kits which we couldn't match in price, today these kits are growing in price making our one off big bore kits more acceptable. I've lost count how many I've done, I think it's in the hundreds, but may just leave that for a completion like I've just done on the TS1 Facebook site for a free coat to the nearest who could guess how many TS1 cylinders I've tuned. I've been doing these T5 kits from the 1980's where I developed the MB T5 Suzuki 170 then offered a Yamaha 180 version and a Kawasaki 190 version which these photos show. Every now and then a liner question pops up on the forums and a few say how great a certain company is at doing liners! Personally I think they are a load of crap and refuse to do work on cylinder done by them, only last week someone had sense and said how poor they are! I've been having liners done from the 80's from the same person and have never had a complaint from work my man has done for me or the work I have carried out after the liner was fitted. Whether you like them or not they have the place in repairing and converting Scooter cylinders. As I've said this is my MB 190 Kawasaki kit using a Jet Skis over sized piston at 68.50mm, the cylinder is bored out, some welding is required to the boost port, the liner is fitted and modified to suit the piston and port timings we use, a head is machined to suit and fit the top hat spigot to centralise the head to the bore. As this is the big bore version the casing needs boring out to suit. This casing came with a damaged inlet pad so it's been converted to a MB Reed valve with the casing welded in the rear to allow the inlet port to be tuned correctly. And rebores are plentiful........"
Bearbeitet von meiermachine
wooohoo, ich würd mal sagen, im ersten eindruck, ein richtig gut gemachter
oldschool steel liner mit großem kolben!
Aber leider mit kleinen Querschnitten.
Die Kanäle sehen mir auch sehr "gerade" aus, als wenn
das Gemisch hier nicht geführt wird im Kanal, sondern voll aufs kanaldach knallt
und sich dann einfach im Zylinder verteilt.
Aber das ist ja das altbekannte Problem der BB Steel liner
Mal abwarten ob es weitere Infos gibt wie der läuft.
Gehe aber davon aus das es mit Malle und drehschieber bessere Motoren gibt
und die dann auch nicht diesen Membran Krach von sich geben.
Bearbeitet von CaptCaracho
Mit dem Fräßer in der Hand könnens was. Schaut sehr sauber aus die ganze Geschichte...
:cheers:
Max
nicht nur fräsen kann er wie ein gott, auch die schweissgeschichten sehen richtig geil aus - wenn ich da an die würste von anderen läden denke ... das war aber schon früher so, ich hab anfang der 90´iger einige teile von ihm gekauft ( u.a. alle 3 conversions für t5 ), auch da sah das schon alles so sauber bearbeitet aus.
Schaut richtig gut aus. Nur Gehäuse aufschweißen is uncool
Warum er das Gehäuse für den Zylinderfuss nicht angepasst hat versteh ich nicht
Mark lässt (auch) die Divider im Gehäuse stehen! Mein Reden
Membran hat er ja nur gemacht weil er den Kobold nicht kennt....
Und passt plugnplay.
Seine 180er und 190er Kits benötigen ausgedrehte Gehäuse
Unbedingt die Kommentare lesen. ZB zu den Dividern
:inlove: (Ich habs immer gewusst!)
das 180 kit passte damals so, ob es heute anders ist weiß ich nicht.
@kunna
nein, er nimmt orig. piaggiozylinder und pflanzt eine stahllaufbuchse ein. einen umgebüchsten malossi habe ich bisher noch nicht gesehen - wahrscheinlich, weil er weniger kühlrippen hat.
Der hat auch Pinascos und geklemmte Malossi verabeite. Rein finanziell ist das halt nicht, ein Malossi kann ca. das Gleiche.
so isses - die sache mit dem aufbphren bei klemmern ist zwar nett, aber ansonsten läuft ein malossi bzw. polossi leistungsmäßig auch nicht schlechter.
malossi als basisi habe ich bisher noch nicht gesehen, soll aber nix heißen.
Steht gleich im 1. Kommentar: Malossi kann/macht er auch als big bore kit .... aber er bevorzugt dafür das OT5 Kit
Man darf davon ausgehen weil die Überströmer größer sind wie bei Malossi und diese auch richtig sitzen
Hinterher schreibt er jemanden er kann vergessen dass es einen 180er plugnplay geben wird
Ich gehe davon aus seine Kits werden so teuer werden dass man für das Geld einen Malossi und eine 56.5er Welle ordern kann
Er ist aber von dem 190er Kit schon überzeugt und schreibt das Teil ist "für Tourendrehmomentpower, schiebt wie eine Dampfwalze und wird den 4. Gang aufbrechen" (mal frei ins Deutsche übersetzt)
    • Sehe nicht, warum er was anderes bräuchte in dem Bereich an Leistung. Würde das freie Geld lieber in einen guten Deckel investieren...
    • Das ist ja eine ganz tolle Geschichte.
    • So...mal einmal ne leichte Nadelumsetzungs-änderungsrunde gedreht. Der PHBH rotzt echt bißchen im Stand an der Ampel zu. Da ist dann ein oder zwei Gasstöße gut zum Anfahren.    Ansonsten lief der PHBH jetzt schon ok'ish.   Hab dann aus der Laune heraus den VHST28BS draufgebaut. Der lief erst mal doof. Dann gemerkt, dass der Choke leicht gezogen wird. Der war zu stramm. Dann wars besser, aber schlechter als der PHBH. Dann mal einfach nur die D29 Nadel eine Kerbe weiter nach oben. Das Ding fährt nun ziemlich fies. Mit 2.62er Primär geht der ohne Gasgeben einfach im zweiten Gang hoch, wenn der in Reso geht. Bertha ist echt ab ca 6-6.500 U/min immer noch ein geiler Auspuff! Das hat mich echt beeindruckt. Hatte vorher nen Parmakit non-SP09, VHST24, Drehschieber und PM40 drauf mit GSFDyno 17PS. Das hier mit dem ET7 ist deutlich fieser. Werde ich hier auch mal checken.   Was mir an dem VHST einfach immer wieder super gefällt, ist das Ansprechverhalten und das weniger bis kein zurotzen an der Ampel. Klar...ist nur ein 28er, aber der läuft einfach wirklich immer fein. Leerlauf fällt super schnell wieder auf 1000-1100 runter. Das finde ich einfach super geil!   Wie @alfonso schon immer schreibt, passt beim VHST, egal ob das der 24er (HD kleiner dann) oder 28er ist, folgendes mit nem guten Reso (Franz/Bertha/etc...) gut:   Nadel D29 2 Kerbe v.O. Schieber 45 HD140 gemessen (Dellorto 130 steht drauf) - Kein Luftfilter AQ264 Leerlauf S35 Chokedüse 60   Setup ist:   Zylinder VMC ET7 (190,4/131,6/VA 29,4) QS 1,15mm Kurbelwelle DRT 53/105 ETS Vergaser VHST28BS mit MR Ansauger Drehschieber 207°(140°v.O.T./67°n.O.T.) Zündung Ducati 1350g 17° geblitzt abgedrückt und dicht Big Bertha mit Aprilia RS Dämpfer MV PK75XL Gehäuse   Damit mach ich jetzt weiter und geh jetzt in die Feinabstimmung. Den PHBH bau ich nicht mehr drauf  Ich schätze mal, dass ich mit nem Luftfilter bei irgendwas gemessene 130-135 landen werde.    Ich berichte
    • Du hast die Kolben ausgebaut und dann wieder eingesetzt?    Die Kolben bzw. Zylinder sollten vor dem Einsetzen "geschmiert" werden. Dazu gibt es Bremszylinderpaste z.B.:  https://techmol.de/Bremszylinderpaste-Techmol-Tube-50g-DOT3-DOT4-DOT-51-bestaendig
