Danke.
bin mir allerdings nicht mehr ganz so sicher ob das alles wirklich zur TV Serie 2 gehört.
Hab hier die Auflistung der Abmessungen. Passt allerdings nicht so exakt.
Wie kann man das sonst noch feststellen?
Chrome ring
From bearing track seat to centre line of steering stop = 361mm
From bearing track seat to bottom of thread = 413mm
From bearing track seat to top of fork stem = 467mm
Non chrome ring
From bearing track seat to centre line of steering stop = 355mm
From bearing track seat to bottom of thread = 405mm
From bearing track seat to top of fork stem = 458mm
TV 200 - Chrome ring
GP
From bearing track seat to centre line of steering stop = 330mm
From bearing track seat to bottom of thread = 380mm
From bearing track seat to top of fork stem = 438mm
Italian Series2 - has welded on "loop" for speedo cable/front brake support - also has the cut out for the headset clamp bolt at the rear of the thread (at 180 degree to front wheel)
TV175 S2
From bearing track seat to bottom of thread = 412mm
From bearing track seat to top of fork stem = 462mm
LI 150 S2
From bearing track seat to centre line of steering stop = 359mm
From bearing track seat to bottom of thread = 407
Spanish
JET 200 -Large damper type - have single damper stud of 9mm diameter welded to single plate at top of fork leg. Also has cut out for headset clamp at the side of the thread (in line with front wheel)
From bearing track seat to centre line of steering stop = 358
From bearing track seat to top of fork stem = 460mm
Definiere "das alles"
Du kannst eine S2 Gabel von einer S3 Gabel unterscheiden aber nicht S2 TV von LI?
Im Zweifelsfalle Fotos einstellen. Hört sich aber alles nach einem Aufwand für nichts an (einfach mit einem höheren Preis ins Rennen gehen)
