Hello,
Last year I was in Monticelli.
There was a reunion of Vespa owners. Incredible experience !!
What a 'normal' German or Belgian owner NEVER would do, you can find in the land of Vespa : someone overthere was present with his PAPERINO !!! Do you believe that ???
Greetings
Belgium
Dis is not a rebuild, dis is original stuff my friend.
Thanks Sucho!
Anyone more info about paperino mp5 prototipo?
Well, there are various informations: some sais that 100 paperinos were produced, nobody sais that there were Not a 100 build. I guess that i have to ask the PR guy I met in vespa museo pondetera. We will see.
Btw: the only detail that differs the tourquise MP5 from the beige one in museo piaggio is the handle bar mounted choke lever.
Everything else is exactly the same: pattern of rear light glass, handle bar fastening ...
a Dinglish emPi Faif Topic :-D
Fred was hast du vor willst du eine  Replika Serie auflegen ...oder hast du eine an der Hand :cheers:
Bearbeitet von schlubbi
Kenn ich. Das is keine paperino. Die is hinten dick wegen px-motor. Meister Piaggio würde sich im Grabe umdrehen. Design-WTF!
Au das wäre fein! Die Bilder müssen nicht HD sein, Hauptsache man kann den Text lesen. Ich PM dir meine Mailadresse.
  • 3 Jahre später...
habe in verschienene Quellen unterschiedliches über die mp5 alias Paperino gelesen. gibt es nur den Prototypen im Museum oder wurde davon "100" Exemplare gebaut und verkauft?
