hello community,
I'm from Portugal and I'm restoring a Vespa Super 150 from 1969
Engine model VBC1M 2 kanal.
at the moment only the engine need to be close to get the vespa ready for run.
some pictures:
BEFORE:
AFTER:
what i need is any trick/perfomance/reliably  tweaks from the "guru's"  before close the engine, any idea ?
can i use carb 20/20 and sito plus with original 150cc cylinder ?
Later the upgrade will be: ddog clutch basket, pinasco 177 (2kanal), carb maybe 24/24 if the 20/20 was not enough and sip road if sito was too noisy.
Thanks for everything
Best regards
Helder
post-48628-0-01393100-1381922540_thumb.j
post-48628-0-14482800-1381922553_thumb.j
post-48628-0-31250900-1381922565_thumb.j
post-48628-0-99039100-1381922580_thumb.j
post-48628-0-74770100-1381922592_thumb.j
post-48628-0-92375700-1381922601_thumb.j
post-48628-0-66326600-1381927163_thumb.j
post-48628-0-92322600-1381927174_thumb.j
post-48628-0-51146600-1381927185_thumb.j
post-48628-0-05995100-1381931522_thumb.j
post-48628-0-54390000-1381931544_thumb.j
post-48628-0-40789000-1381931564_thumb.j
post-48628-0-41060300-1381931583_thumb.j
post-48628-0-54977100-1381931601_thumb.j
post-48628-0-94197200-1381931623_thumb.j
post-48628-0-87843700-1381932896_thumb.j
post-48628-0-62708800-1381932917_thumb.j
post-48628-0-92205700-1381932934_thumb.j
post-48628-0-67154000-1381932954_thumb.j
post-48628-0-97506100-1381932971_thumb.j
post-48628-0-40125900-1381932988_thumb.j
post-48628-0-47870300-1381933007_thumb.j
post-48628-0-85772300-1381933185_thumb.j
post-48628-0-35003400-1381933202_thumb.j
post-48628-0-76600400-1381933220_thumb.j
Bearbeitet von hfpsilva
Hello
Nice Vespa
To your question´s
Yes you can use the 20/20 Carb with the 150cc Cylinder and the Sito+
But i would put the 24/24 Carb. on it now so you can fit the Carb. perfect to the Motorhousing.
The 24/24 also run´s  with the 150cc Cylinder.
My Setup at the VBB150:
DR177 with MMW Head , 24/24 Carb, SIP Road Sport Exhaust,Vespatronic Ignition
Bearbeitet von Pez
thanks for your reply.
so i gone buy a 24/24 carb, do you know the perfect jettings for use on 24/24 ??? any tweak to make on the carb too or is just plug and play ?
nice setup, but dr177 is 3 kanal correct? did you cut the 3º kanal ? how mutch top speed you have with the wheel "8 ??
new pictures from the engine:
what do you think ? anything more that i can tweak ?
open the 3 channel it's a good idea or not ?
post-48628-0-91565900-1382000020_thumb.j
post-48628-0-27411300-1382000036_thumb.j
post-48628-0-57221000-1382000052_thumb.j
post-48628-0-94814400-1382000121_thumb.j
post-48628-0-16083200-1382000140_thumb.j
post-48628-0-65752500-1382000160_thumb.j
post-48628-0-15753700-1382000171_thumb.j
post-48628-0-12473900-1382017099_thumb.j
thanks for the help!
i need a favor from the guru's...
the lettering.... i buy new subtitles from the front ("Vespa Super ") and for the back ("150 Super")
the guy that paint the Vespa close all the holes from the chassi, now i don't know the correct position, someone can help me ?
    • Miss doch einfach nach. Dann kannst du dir die Frage gleich selber beantworten......
    • Moin,   eigentlich passt meine Frage nirgendwo so richtig hin, denn es geht um ein Gokart mit Ciao Motor. Diese Gokarts wurden von der Firma Schlösser GmbH Kunststofftechnik in Süßen (Baden-Württemberg) hergestellt. Die Produktion muss irgendwann in den 70er/80er Jahren erfolgt sein, die Firma existierte von 1971 bis 1983. Auf dem Typenaufkleber steht "Motor: Vespa Ciao". Das ist schon witzig konstruiert, die "Karosse" besteht aus GFK. Das Getriebe ist ein Ciao-Getriebe, allerdings steht hier die Hauptwelle auch aus dem Getriebedeckel heraus um die Antriebswelle aufzunehmen. Auf der anderen Seite ist statt dem Kettenritzel die andere Antriebswelle montiert. Gestartet wurde das Ding über einen Seilzugstarter, ähnlich den Seilzugstartern von Swing, alternativ: Schiebestart.   Kennt jemand so ein Gefährt oder hat gar eins? Ich habe zumindest vorher noch nie etwas davon gehört oder gesehen. Ich wäre für jede Information dankbar.   Gruß Jakob
    • Nein, ich freu mich darüber natürlich nicht. Aber mein erster Reflex ist es, versuchen zu verstehen, was dahinter steckt. Und da ist nun mal ein Urteil des Bundesverfassungsgerichts, das - mit nachvollziehbaren Argumenten - das bisherige System als ungerecht erkannt hat. Es musste also erneuert werden. Und dass es da Gewinner UND Verlierer geben wird, war klar und vorgegeben. Und nur, weil ich jetzt Verlierer bin, seh ich keinen Anlass zum schimpfen. Vielleicht hab ich auch einfach nur viele Jahre ungerechte Vorteile genossen (siehe Urteil)?   Das kommt drauf an. Nur weil es für mich teurer wird nicht.   Ich hab ein Grundstück, bei dem sich die Grundsteuer knapp vervierzigfacht (!) hat. Von 9,- auf 353,- EUR. Das Grundstück liegt teilweise in einem Landschaftsschutzgebiet, ist gänzlich unbebaubar. Das wird vermutlich seinerzeit der Grund für die niedrige Abgabe gewesen sein. Ich vermute, dass dies jetzt übersehen worden ist. Dann möchte ich das natürlich korrigieren lassen. Das halte ich für legitim.   Allerdings, wenn es nun eine bewusste Entscheidung sein sollte, auch solche Grundstücke höher zu besteuern, weil ich da mit meinen vielen geilen Weibern den ganzen Tag naggich in schönster Natur rumtollen und den geilsten  (Blümchen?) Sex habe (haben könnte?), dann ist das halt auch irgendwie nachvollziehbar und dann halt so. Irgendwoher muss das Geld für unsere Gemeinschaft herkommen. Das Sankt-Florians-Prinzip geht mir auf die frei baumelnden Nüsse. Der Besuch im Swingerclub kann übrigens teurer sein (hab ich gehört).
