(sorry for using English, hope it s ok ... :rotwerd: )
I just bought a P200 in parts with a Devil Inside tuned engine. According to the receipt it was built in 1998 but it was never put together and therefor never started. It is a water cooled Malossi with Suzuki piston and 60 mm stroke that shall end up in 220cc
Here is my friend Ola holding up the little engine
Anyone knows if there are any "do and don'ts" on these machines? The build looks solid but anyhow I am interested if people experienced problems with them when they where popular.
I am also curious of someone knows the brand of the reed valves. The logo looks like MA or AM.
Best tuning regards from Stockholm in Sweden
if you intend to use the cylinder I would make "CVF holes" in the piston. it should wake it up a little bit more
you can see with piston in BDC that there are very small transfer port passages
i have a smiliar cylinder on my Touring and it gave some extra power to make the holes in the piston
in general the cylinder is not as easy to make power with as a normal malossi.
cheers
Truls
  • 7 Monate später...
oldschool:
http://www.germanscooterforum.de/topic/98023-200er-malossisuzuki-conversion/page-2?hl=+suzuki
http://www.germanscooterforum.de/topic/102233-suzuki-conversion-225-ccm/?hl=%2Bsuzuki
the Piston has 70mm Diameter so there is more ccm with a 60mm crank
and yes its a polini superval...hard to get these days...
i'm selling one actually.
for more pics: http://www.germanscooterforum.de/topic/201760-es-muss-mal-wieder-platz-gemacht-werden-größtenteils-alte-schule/?p=1066604712#entry1066604712
Där ser jag min vevaxel då, där ser jag min utrustning , det ser jag då min kolv och cylinder, bakom grindarna till Valhall, där de modiga scooter ryttare leva för evigt. Välkommen idrottsman henkan :cheers:
Sorry for my rosty swedish. Familiy left sweden in 1610 A.D.
Ok, lets see what we have here: Malossi Suzuki Conversion. I think, the cylinder is made by Malossi. Hmm yes, taking a look into the cylinder and it looks very similar to the malossi system. The "original" piston for the malossi was a 68,5 mm Asso piston. The drilling looks a little bit greater. Vic says 70 mm piston. So the Asso piston is out and the 70 mm Szuki piston goes in. Remeasuring helps. A portmap will help, like this . We need this later.
I whould check, if the piston rings fit with the cylinder, like this
the distance between the end of the pistong rings should not go below 0,3 mm and should not go over 0,9 mm
You should be sure, that the piston rings do not feather in the "above-streams" or the "outlet"
this is what my "brainstom" tells me by watching the devil inside project. :rotwerd:
the cylinder is a Malossi/Suzuki Conversion like in the links I posted before.
cylinder old Version of malossi 210
Piston 70mm from Suzuki GT 750 "Wasserbüffel" (the right one of the three)
MB Developements, Nordspeed and Devil Inside (and i think many others) made this Conversions in the 90ies
here the biggest topic:
http://www.germanscooterforum.de/topic/168407-mallesuzi-conversion/page-1?hl=+suzuki
Devil Inside had a well earned reputation of quality back in the day. If I were you I'd take the bits and build the engine, and then I'd run it. Only then would I start modifying, if you consider it necessary, that is. With modern components you are likely to find more power quite easily without having to bother with the liquid cooling, but then this here is a bit of a classic in its own right, hence I'd give it a chance as it is.
Well... I know someone who would luckily take the cylinder and head.... :-)
By the way. I would replace the Polini Supervalve. There are a lot of people who were not happy with those. I think they tended to be leaky. Just ask yourself why they are not available anymore...
Bearbeitet von Tupamaro
the piston requires a special conrod because of its gudgeon pin dimension.
so if you suggest to buy/sell such conversion dont forget the crankshaft
  • 6 Monate später...
Project still ongoing, struggling that it will just start after a small splash of petrol in the spark plug hole. Once started it is easy to start again. I suspect that the reed valves has been to stiff during the years. So now I try to find what I can replace it with, superval seams not to be the best option as stated above. Radulf: Tack för hälsningen. I morgon 6 juni är det Sveriges nationaldag, se till att fira ordentligt!
Hello,
I have a Honda NSR 125 reed cage that I dont need anymore. If you you are interested I can send it right into the north for some swedish beer!
Hej Topps!
Have you had the chance to check the effiency of the cooling system? Was thinking of if you get enough with the cooler and fan hidden under the side panel.
mvh
Lars
    • Nach langer Forums- und auch Schrauberabstinenz bräuchte ich mal Hilfe beim Troubleshooting.   Ich habe mit einm Freund eine PK für seinen Sohn aufgebaut. Den Motor haben wir schon vor ein paar Jahren gemacht, jetzt ist endlich alles fertig, aber er läuft nicht richtig.   Sie lässt sich sehr gut antreten und läuft auch im Stand. Wenn man Gas gibt, dreht sie aber nur widerwillig hoch, verschluckt sich, der Vergaser läuft über und auch der Auspuff sifft.   Zuerst habe ich geguckt, ob der Kolben richtig rum drin ist. Ja, ist er, aber man weiß ja nie. Dann habe ich nacheinander CDI, Zündkabel und Kerzenstecker getauscht. Zündung nochmal etwas früher und etwas später getestet und einen anderern Vergaser verbaut.  Der Vergaser ist gereinigt und Schimmernadel sieht auch gut aus (außerdem ist er neu...) Alles ohne Resultat oder Veränderung.   Es handelt sich um einen 75er Polini, SHB 16.15, HD 72 (74 und 70 hab ich auch mal getestet), Zündung ist auf 17° Grad geblitzt, Sito original Auspuf (neu), Rennwelle BGM.   Ich dachte zwischenzeitlich an einen defekten Drehschieber, aber das GSF hat mich dran erinnert, dass sie dann ja im Stand nicht so läuft.   Hat jemand noch eine Idee, oder zwei?   Einlasssteuerzeit habe ich jetzt nicht gemessen, wie würde sich das denn äußern?   Danke im Voraus, schön wieder hier Mitzulessen und zu Schrauben!
    • Naja, hat halt nicht jeder ein passendes Stück Rohr im Fundus, und bevor man da jetzt ne Schlosserei heimsucht und dort bettelt, druckt man das eben schnell selbst... Ich hab schon dümmere Sachen gemacht
    • Ich hab das mal aus unserer PN Unterhaltung frech hier rüber kopiert:   Eigentlich muss das so laufen! Die Reduzierung ist manchmal etwas tricky, ich hab bei mir ein Stück M6 Gewinde mit einer 2mm Bohrung drin. Ruhig mal mit dem Durchmesser spielen, allerdings hab ich Dein Problem noch nicht ganz verstanden: Was meinst Du mit "wie abgesoffen" ?
