Hi All!
I have a 1965 SS180 with a Polossi 220 engine for touring...
And for next season I want to upgrade from SIP Road to BGM BigBox...
But I can't fit the BigBox, as it conflicts with the mainstand on the SS180 (spring and attachment on spring on the stand...)
Any suggestions for how I can have my BigBox fitted on my SS180?
(PS, Sidestand is not an option, as I very often have my PAV41 trailer along with it...)
Thanks!
Ø
  • 2 Monate später...
Hi Deichgraf and Happy New Year to you too!
I'm aware of the S&S sollution, but does a main stand for PX fit a SS180 frame?
If so, a swap would solve the case.
I already have a Pipedesign exhaust, but a Silentbox220, as Marco recomended that for a Polossi engine.
But I'm very dissapointed with the exhaust...
-the layout on it makes it hard to turn Right without grounding it, and the sound is allmost like Shito+...
And it has the same conflict with the main stand.
My impression of the BigBox is alot better.
But I need to sort the main stand, so I can continue to tow my PAV...
My Silent Box is pretty equally as loud as the SIP Road I had before - which was still not very noisy as it was almost new.
Did you try a SIP Road? It fitted my Polini 220 very well but since I am running a Malossi Sport now the Silent Box works better.
I'm currently using a SIP Road, and it is ok.
-but the BigBox is supposed to give some more ooohmp.
I could probably use the Silentbox and achieve the same output, but the design of the Silentbox is too bad...
Yes, it is mostly about the layout.
I'll probably rather put it on my sidecar-PX.
-with a 57mm alu-Polini... [emoji6]
  Am 3.1.2015 um 07:43 schrieb Svint1:
Can't tell.
If I were you, I'd weld something together myself, like "put the spring aside the exhaust" or alike that.
I just got it confirmed by various SS180-sites on Facebook that a PX main stand fits the SS180, so then it should be straight forward!  :wheeeha:
