OOC Helloween Prüstandnacht
Hi,first post here,
sorry don't speak German,
I was following this brilliant topic and decided to buy a S-Box for my Lambretta.
It has by far the worst lambretta exhaust fitting,there is no way to fit it
I tried to contact Marco for a long time but he is not replying,
what have you done for this problem,have you contacted him?
Did he solve the bad fitment problem?
We tested a used Silentbox of Blanky Ddorf. I think, it was a prototype. We had the same fitting-problem with the last Pipedesign-delivered silentbox . Ist was absolutely unfittable. Clash1 had the same problem. May be, it's a problem of Marcos last batch. :???:
Thank you,
when I first got it,I couldn't even fit the main box,I had to elongate the two bracket holes for the M8 studs,plus the M6 tailpipe bracket.
This meant that the exhaust was never tested for fitment.
With the two M8 nuts tightened on the main bracket,the tailpipe was more than half cm out
OK,I've fitted many Lambretta exhausts,this wasn't really a problem,anyone who rides Lambretta knows how to use a dremel.
The real problem comes when the main box is tightened,the stub is way out of the cylinder exhaust port,
the main box is static,this means there is nothing that can be done to fix it,
it needs cut and welding,I'm no expert I cannot do it.
I asked Marco about this long time ago,he had no explanation,he got surprised,I asked him again what we could do about this,I never got any reply,
I'm waiting for a reply a long time now,
I don't have an exhaust to fit and this one wasn't cheap,I can't afford to buy a new one so i'm waiting for Marco's responce.
The exhaust port doesn't line up with the stub.
Italian 200cc crankcase with cast iron Spanish cylinder
Same crankcase,with Italian 200c cast iron cylinder
I even tried it on an Italian crankcase with a Casa 185 kit,nothing,NO WAY,it is IMPOSSIBLE to fit it.
I tried it on another 200cc Italian crankcase with another cylinder,with 175cc crankcase nothing again,the S-BOX DOESN'T FIT,
I don't know what Marco thinks but i have a big problem and he is not helping at all.
What should I do?
Some of the tested crankcases (I also have videos showing how bad it is)
Das von Herrn Clash verbaute Exemplar ist auch auf der Straße nicht leise.
Man sollte sich vom Namen nicht täuschen lassen. Von Silent so im Bereich
eines SIP Road kann keine Rede sein. Leistungsmäßig nicht schlecht, ob
er die BB V1 auf meinem Motor in die Tasche steckt, vermag mein Popometer
nicht zweifelsfrei zu sagen. Ein Prüfstandslauf über Pfingsten wird darüber
vielleicht Aufschluss geben. Auf Grund von sehr schlechter Passgenauigkeit
und der Lautstärke in meinen Augen nicht empfehlenswert. Ob das der
Prüfstand noch rausreißt?
Bearbeitet von Arthur
Hey guys, i think this is not the topic to discuss fitting-problems of one single kind of exhaust. Emphasis should be power-curves of different exhausts. Please open up a new topic to discuss the fitting-problems of Pipedesign-Silentbox and communication-problems with Mr. M.R. :satisfied:
:thumbsup:
Der Gori Sport hier im Test war ja eine 42 mm Version die eigentlich für GG gedacht war. Die TS1-Variante die es ab Werk gibt hat ja 48 mm. Ist das dann auch eine "Sport"-Ausführung (Dämmung innen) oder eine "Racing"-Ausführung? Weiß das hier jemand?
Hm, zumindest bei CLW wird die TS1-Version als "Racing" verkauft und in der aktuellen Bauart "verleisert". Hieße, dass der geneigte Käufer für TS1 nicht mit den hier gemachten Angaben bezüglich Kurven und Lautstärke rechnen kann.
Warte auf Superclubman...
Nachdem die bisher von uns getestete Pipedesign-Silentbox (DANKE Blanky Ddorf) mit Thermoband umwickelt war (also nicht so, wie von PD nornalerweise ausgeliefert) und Herr Powolotti HIER einen super Trick gepostet hat, wie die "unverfälschte" Silentbox trotz der bekannten, massiven Paßform-Problemen doch noch easy montiert werden kann, hatten wir sie heute auf der Rolle.
Sie lief auf einem ungeportetem "out of the box"-TS1 mit Hub 62mm (Auslaß 179°, Überströmer 128°) und KEIHIN 28 PWK. Wir fanden die Leistung und insbes. das Drehmoment der Pipedesign-Silentbox durchaus bemerkenswert:
ich werde den auspuff mal auf meine serie2 stecken und einen straßentest machen.
übersetzung 4.8
mal sehen wie das fährt.
hab halt bedenken, dass das ganze recht früh zumacht und man eigentlich länger übersetzen müsste.
hier wäre ein 5 gang mit 4.8 im 4ten ganz nett.
ich hatte die ja auf meinem Motor mit 4,7er Übersetzung. Bin damit ca. 50km Autobahn gefahren, das fährt sich schon sehr ordentlich und für meine Reisegeschwindigkeit inklusive Überholreserven passt das. 4,6er wäre aber bei dem Motor auch mit dem TSR besser, gilt demnach für die Silentbox noch mehr.
...."out of the box"-TS1 mit Hub 62mm (Auslaß 179°, Überströmer 128°)...
welcher Kolben tut seinen Dienst?
welcher Zylinderkopf?
wie hast du deine benannten Steuerzeiten die ja einem "out of the box" TS1 (130/184) annähernd entsprechen erreicht, trotz 62mm Kurbelwelle?
Zylinder an Zylinderfussfläche abgedreht?
Bearbeitet von mpq
Dankeschön, ist aber genauso wenig OFF-Topic wie die Getriebeanmerkung...
oder der neue OCC-Standard...
Zylinderkopf? Muss ja einiges eingedreht worden sein, oder halt extrem dicke Kodi... deswegen bisher keine Aussage welcher Kopf verwendet wurde
man wird ja wohl noch fragen dürfen was für'n Setup verwendet wurde, wenn nur die halben Infos gegeben werden.
auf jeden Fall, Respekt!!
bekanntlich ist ja Hubraum durch nix anderes zu ersetzen als durch noch mehr Hubraum.... Deshalb sicher auch dieses tolle Drehmoment...
Interessant wäre die PD Silentbox halt mal auf einem 60/110-Motor, bzw. auf dem ursprünglichen Motor dieses Auspuff-Vergleichtopics.
ansonsten gehört dieser Prüfstandslauf eher in "Wer hat welche Leistung", weil der Bezug zum ursprünglichen Setup in Post#1, NICHT gegeben ist.
Klar ist nur m.M.
Bearbeitet von mpq
übersetzung 4.8
hab am WE die dose auf meine serie 2 mit oanser gebaut.
passform superscheisse und viel nacharbeit erforderlich...auch lauter als mein vorher verbauter franspeed race mit band und TSR dämpfer.
diagramme reich ich nach (zwischen 23 und 23.7 ps bei 10 läufen in folge) , aber das ganze fährt sich sehr gut und macht auch nicht so früh dicht wie die angi, die mal drauf war. im 4ten komme ich auf 7500 umdrehungen (mit der angi wurde es bei 6500 zäh und 7000 nur mit anlauf) auf der ebene, was für mich ausreichend ist.
ist mit 4.8er übersetzung der perfekte motor für touren mit pässen.
4ter gang mit 2 personen den brenner hoch und so..
Bearbeitet von gravedigger
ne, die v-max reicht mir.
hatte nur bedenke, dass das ding auf der straße nicht hoch genug dreht bzw. obenrum die kraft ausgeht wie bei der angi.
aber so wie sich das fährt ist das o.kfür mich. ...ausserdem hat man mit so einem  DRT getriebe eine fehlerquelle mehr am start.
nach getrieberechner 126 bei 7400 umdrehungen und bei 100 ca. 6000 passt.
    • Ich fahre derzeit den M260. Werde vermutlich auf den VMC umrüsten.
    • Die PX soll ein Reiseroller sein, da geht's mir weniger um die Leistung. Hab eher etwas bauchweh wenn man von den heftigen Toleranzen bei VMC liest.   Ihr könnt mir auch gerne einen ganz anderen Zylinder als tourentauglich bei dem Setup empfehlen.
    • Herrlich Helmuth,   Bin immer noch in classic enduro unterwegs, dieses mal mit rotax 124 drehschieber, daneben beratend 50ccm für 8 Stunden Rennen...bei den top 3 liegt man dort jetzt bei 22 ps kurbelwelle...nicht spitz sondern breites Band 😉   Aber Blicke ins gsf lohnen immer, so wie sich blicke beim meisterlichen tun am werkstück zu Meister Hess immer lohnten 😉 er redete wenig...aber sein tun und wie er etwas sinnigerweise tat, konnte augen und mein Verständnis unheimlich bereichern...ein Erlebnis    Net schwätzen! Machen 😉   Und du vererhter Helmut bist vom gleichem Schlage, der mir immer wieder ein neues Licht aufgehen lässt 😀   Pluspunkt...du machst dein geballtes wissen hier offen zugänglich...ein Segen für Geneigte 😉 mit deinem gemeinnützigen Umgang stell ich dich in Reihe mit Jan Thiel und Overmars, welche ebenfalls aus dem Nähkästchen plaudern...top!!   Verbundenen Dank an Dich Helmut!!! 😉   Gutes Gelingen ! 😉   Wolfgang
    • Dann wäre selbst 24/63 zu kurz - die oben genannte ist es sicher auf 80er Getriebe
    • Weil der Crono auch Membran gut läuft.  Denke den BGM müsste man für die gleiche Leistung bearbeiten. Habe aber mit beiden Zylinder keine Erfahrung , ist nir das was man so liest.
