Im restoring a VGLA1t and i am about to take of the flywheel..when do you know that it is time to let it remagnetize and how much does that cost you? I also read in the Haynes Manual that when you take the flywheel off and the stator plate is still on the engine you have to "bridge the flywheel with soft iron in to prevent demagnetizing"does anybody know what they mean by that? And how you do this exactly? I read that after you takre of the stator plate yolu just put that in to prevent demagnetizing but what do you place in there before that?
thanks!
Now, i try to explain. During the years the magnetism of the flywheel gets lost. The result is weak ignition. Batteries cant get pushed up and stay empty. Light also is very weak.
I therefore strongly recommend to remagnetize your flywheel. Costs in Germany at my local service are about 25$.
When you take your flywheel off, the lost of magnetism gets faster. You would not mention it, if the flywheel magnets are "unbridged" for about a hour or so. But you should bridge the magnets by putting a blade of a saw into the inside of it. Anything of iron bridging the magnets will do. Putting the Stator plate into the flywheel is the easyest way to bridge the magnets.
Alien-English, i know... :-D But schooltime is very far away. :-(
    • Also.... geplant war ja die O-Lack Freilegung in der Hoffnung das sexy Apfelgrün der Spanier zu finden. Das hab ich auch gefunden, allerdings nicht als O-Lack  Die Kiste wurde mindestens 2x lackiert und war Original wohl mal blau (zumindest der Hauptteil).  Da war dann kurzzeitig guter Rat. Dann kam mir irgendwann die Idee, die Karre einfach so zu lassen. Denn, das blau erinnerte mich an etwas....also schnell mit dem PC gespielt und das kam dabei heraus       Gut....  Also das Gelumpe zerlegt und zwecks Aufarbeitung. Dabei hab ich dann gesehen, das es auch noch insgesamt 3 leicht unterschiedliche Blautöne war und das Grün stellenweise auch noch durchschimmerte   Da ich das IMMER gesehen hätte und ich mich immer geärgert hätte, weil es kacke aussah, wieder gegrübelt "was jetzt".  Irgendwann aus Frust bissl mit der Kupferbürste aufm Akkuschrauber gespielt und das Bridge Piece entlackt. Und das fand ich dann irgendwie doch recht sexy. Kurz gegrübelt was ich mit Anbauteilen etc mache (sollte ja keine Custom Bude oder ähnliches werden) und dann los. Alles nicht sichtbare wurde schwarz matt aus der Dose mit mattem Klarlack lackiert, alle Gummiteile sollten schwarz werden und der Rest eben blank....   Und dann ab dafür....therapeutisches entlacken war angesagt           Hier ein Lob auf die Produkte der Firma Parkside  Der Akkuschrauber hat den Dauerbetrieb ohne Mucken gemeistert. Als dann alles entlackt war, die ganze Nummer mit Owatrol versiegelt. Hier hab ich mich vorher Tips von @sinfonique geholt, der Bereits eine sehr sexy PX in der Art seit Jahren auf der Strasse bewegt. 2x versiegelt und zwischendrin gut durchtrocknen lassen.         Und da es ein Winterprojekt ist, war es dafür in der Halle zu kalt, also den Keller belegt und da später auch mit dem Zusammenbau angefangen. Man kennt es ja, alles wieder dran und rein, was da eben dran und rein gehört.      Den Rest kennt ja jeder. Züge rein, Elektrik rein usw. Vorne Scheibenbremse, hinten Motor. Der war bereits fertig. Quattrini M210, weil einfach gut. Und auch wenn das Blau nicht mehr da ist, die Playmobil Nummer ging mir nicht mehr aus dem Kopf, also die "Silber/schwarz" Nummer durch ein wenig Farbe aufgelockert. Ich bin persönlich schwer in Liebe           Da ich vor dem Zusammenbau bereits einen TÜV Termin vereinbart hatte, war dann auch ein wenig Druck vorhanden, was der ganzen Nummer gut getan hat. Ausnahmsweise ist auch wenig bis nix schief gelaufen, so das ich gestern zumindest soweit fertig geworden bin, das die Kiste auf dem Anhänger steht und heute zum TÜV kommt     Abwarten welche Kinderkrankheiten dann wieder anstehen
    • ich tippe ja das du denen direkt 2 Bier angeboten hast   gut geworden - bis auf die Farbe der ResRadfelge...
    • Faszinierend, die Ankündigung ist nur eine Seite zurücl, könnte quasi letzten Monat gewesen sein  Waren trotzdem nur 11 Monate bis zur Fertigstellung. In Anbetracht der Tatsache, das in dieser Zeit noch ein Wohnungs und Hallenumzug stattgefunden hat, gar nicht so schlecht. Kiste ist fertig, kommt im nächsten Beitrag....
    • Wenn Du Dir unsicher bist, leg doch die Pumpe einfach still und misch halt beim tanken.
    • Ist der richtige Ansatz. Habe zwei unterschiedlich große Spritzen einmal mit 50ml Benzin und einmal mit 1ml Öl gefüllt und den Roller im erhöhten Standgas 5min laufen lassen.       Sprit ist durch. Ich würde sagen so um die 1:80 im Leerlauf.     Mit der windigen Pappkonstruktion kann ich nicht fahren. Kann jemand verlässlich abschätzen, wie sich das unter Last verhält?
