hi
my px200 flywheel was lightened to 2000gr. But now to lightening more i need to remove calibrating holes. how can i make calibration? i can`t find any store in portugal that will do it...
regards
eduardo
why do you need more lightening? I suggest to remove the E-Start ring... ist made from steel, and its inertia acts on the worst position given... if you can go further witout the estart, i would propose to reduce the entire diameter of the wheel down to 172mm... thats what I gonna do soon..
If you need balancing, use a "wuchtbock" in order to belance the flywheel statically... in the Internet you gonna find a wide variety of DIY balancing tools:
https://www.google.ch/search?q=wuchtbock+diy&biw=1920&bih=1121&source=lnms&tbm=isch&sa=X&ei=sCRbVdXxK8mksgHqnIL4Cw&ved=0CAYQ_AUoAQ#tbm=isch&q=zentrierst%C3%A4nder+eigenbau
Drill holes accordingly, until the wheel stays in any position...
Cheers
