erledigt
vespaoldies
Das habe ich dazu gefunden:
"A note on carburettor model designations.
PHBH 28 B S
PHBH - Main body type, each body comes in a range of bores. - The effective diameter bore of the carburettor in mm.
B - Generally rubber sleeve "elastic" type fitting. A - Generally clamp type fitting. Other letters have no specific meaning - they have certain original applications - if you are unsure which model you need, contact us before buying.
S - "Sinistra" - "left" in Italian - Left hand idle mixture and idle speed screws.
D - "Destra" - "right" in Italian Right hand idle mixture and idle speed screws.""
