Megadella XL
Hello everyone,
My name is Damiano and I'm the boss of whiteoneracingevespa some time ago, with Carmelo (mega), I designed a muffler megadella XL more powerful than any other in the market including bigbox sport. The first prototype was modified to search power at high rpm (8500-9000) by shortening the final cone, but this move proved to be wrong because the muffler had less power than before.
Unfortunately, the construction costs were high and the project was shelved, however, because the interest in this kind of silencers is growing, I decided to take the development with a new megadella XL version 2.0. I'm sure that with the experience gained I can realize the muffler box type best performing on the market.
I show you the photos of the first prototype of megadella XL.
sorry for my bad English.
Each muffler megadella is different, because there are variations that can make it perfect for any engine as opposed to others that although excellent, are not customizable.
warum kommt mir der name des auspuffs nur so bekannt vor? :lookaround:
The megadella XL was produced before Siproad XL and BigBox Sport. Photos on Facebook, in fact back up to nine months.
In wiefern beeinflussen die Löcher im Prallblech die Performance bzw. Was bewirken mehr oder weniger Löcher? Beim Sip Road sind es ja keine Löcher sondern da fehlt ja einfach auf einer Seite eine Ecke
The holes in the bulkhead are to be dimensioned in the number and diameter in proportion with the discharge tube. In the original pot the ratio of the area of the holes and the discharge tube is approximately 2: 1 that is good value, but you can go to 1.75: 1 to increase the rpm or 2.25: 1 to have more torque. The limit values beyond which the muffler deteriorates the performance are 1,5: 1 and 2,5:1.
  • Like 3
ciao mi puoi mandare in mp quando costa sto bel pezzo! io sto scendendo a Salerno e passerei a prenderla. per p200e
saluti
giuseppe
devi sentire privatamente carmelo che la realizza (o su facebook: privitera carmelo o tramite mail: [email protected]), tra 10 giorni sarà pronto il modello 2.0 specifico per motori lamellari
Na, den baue ich mir doch gleich mal. Warum habt ihr eigentlich den Schalldämpferbereich nicht mit angehoben? Würde sich bei einer Kontrolle durch die Rennleitung sicher besser machen. Sopratutto ,bella storia.
I did not understand your post, google translator does not help me, you can write in English?
I think I understand the sense of the intervention. The left side of the muffler was left of the standard sizes to simplify the construction and to not touch in the left corners, in version 2.0 also the right part will be worth tapered to have the footprint as small as possible and do not touch in the bends as with the big box.
To make a pot with the whole carcass increased goes completely redone the interior perforated wall.
Then there is the pneumatic brake exerted by the second chamber does not affect the performance, so we looked for, being a modified muffler handcrafted and made in the factory, we have tried to do only what is necessary.
Heli
dimmi una cosa: le saldature sono fatte a filo contino o a elettrodo? Penso che avete bisogno di migliorare.
Io preferisco Tig, perce le passate sono piu liscio.
Le saldature sono a filo continuo (mig) perché lo spessore della lamiera (1mm) è di impedimento per la saldatura a TIG, infatti il tig non apportando materiale andrebbe ad assottigliare la lamiera nel punto di saldatura rendendola più fragile. Per realizzare marmitte robuste con saldatura a TIG sono necessarie lamiere di spessore minimo 1,5mm, tuttavia dovendo calandrare a mano le lastre di acciaio è più semplice lavorare con lamiere da 1mm.
Lo scopo della megadella non è mai stato quello di essere uno scarico bello esteticamente, ma efficace e con il continuo sviluppo e la personalizzazione, speriamo diventi il più efficace sul mercato.
Un altra questione: e rumoroso quella Marmitta o anche piu basso il Volume?
Scusa per il Mio italiano
Stefan
La marmitta ha il medesimo rumore delle altre megadelle, ovvero appena maggiore di quella di serie.
Non preoccuparti il tuo italiano è decisamente migliore del mio tedesco
p.s. ho scritto tutto in italiano perché credo che sia di più facile la traduzione (usando google translate), se poi qualche anima più volesse tradurre ne sarei felice.
Of course you can use any language here, but please be aware that only a minority understands italian. Maybe one of the guys from Alto Adige could translate the italian parts?
Edit: Please keep the topic in english, because it's generally interesting also for non-italian speakers :-)
Welds are continuous wire (MIG) Because the thickness of the sheet metal (1 mm) is an impediment to the TIG welding does not make any material fact and should be to sheet metal in the welding point, making it more fragile. To achieve robust silencers with TIG welding requires a minimum thickness of 1.5 mm sheet metal, HOWEVER bending the steel plates by hand is easier to work sheets from 1mm.
The purpose of Mega has never been to be the beauty, but effective, with the continuous development and customization, we hope it will be the most efficacious on the market.
The muffler has the sound of other megadella, not more than standard
Bearbeitet von pk_damiano_4hp
Nice Work even when i think that the Tig Process can be used with any Thickness of Material. The Problem in Germany is, that our Police control somtimes the Muffler but most of them are Young and have no knowledge from the old Vespa.And maybe when they see weldings that looks different to the remaining original weldings,than is it possible that they take a look moore.Someone will be in trouble than. Anyway the bgm number in the body should be enough to declare the originality.
Thats the reason why i try everytime to weld similar as possible to the original Weldseems.I try to copy your Muffler by using the posted Fotos. But just for my personal Vespa.Hope that this will be not a Problem for you. I want to modifie the complete Muffler, to see if it really
Touch the street .
Danke auch fuer die klaerenden Worte der Moderatoren . Ich bin sprachlos!
Bearbeitet von scheuerglatze
    • Ok, worauf zielst Du ab?   Gemäss dem Test von MRP: https://www.germanscooterforum.de/topic/199158-wer-fährt-eigentlich-t5/?do=findComment&comment=1069811613 ...ist der SIP R2 sehr ähnlich, der Polini peakt früher (wäre jetzt mein Favorit), der Rest taugt nicht viel, weil man untenrum stark verliert.
    • Hallo, wie versprochen, hier noch ein Bild dazu:     Die Blechplatte mit dem Loch ist nicht original, aber sehr praktisch und somit einfach irgendwo zu verschrauben. Schwarz geht dann auf Masse/Chassis und Rot und Weiß an die Blinkerleitungen rechts/links (oder umgekehrt, das ist egal). Ich habe das Ganze mit neuen Kabeln verlötet (und evtl. mit falschen Farben, sorry), das war leider nötig. Glücklicherweise waren auch die zwei Sperrdioden noch dabei, die habe ich im Schrumpfschlauch verschwinden lassen. Die sind wichtig, sonst würde dir der Piepser deine Blinker ungewollt in eine Warnblinkanlage verwandeln, bzw. brücken.   Kurz ausprobiert (funktioniert einwandfrei) und auch schon verpackt (geht morgen auf die Reise). Bitte unbedingt das Kabel zugentlasten (z.B. mit Kabelbindern) die dünnen Kabel (schwarz und Rot) am Piepser sind nicht mehr taufrisch und schon etwas fragil, also vorsicht. Viel Spaß damit, soweit das möglich ist, mich nervt das gepiepse eher ^^
    • Ungefähr so hat sich mein Motorenbauer auch ausgedrückt. Außerdem habe er für sowas kein passendes Werkzeug und nachträglich wäre das schwierig so zu machen, dass er es mit gutem Gewissen tun könnte.    Er hat mir dann noch ein paar Tipps gegeben, was man tun könnte. Hab es mit Schleifpapier, Unterlegscheibe, Akkuschrauber und solchen Dingen dann irgendwie hinbekommen. Viel hat nicht gefehlt, jetzt ist dicht.    Der italienische Shop hat sich übrigens dumm gestellt und Pinasco hat gar nicht reagiert.
    • Moin   Gibts mittlerweile etwas Neues zu den beiden (oder drei) Zylindern?   Der VMC steht ja zwei mal im Shop   Art.-Nr.: 14002100   Art.-Nr.: 14002300   und der SIP   Art.-Nr.: 14000240   Welche Unterschiede gibt es auf eine 125er pk gesteckt bei Leistung und Band mit Banane oder Box Auspuff?   Bis denne   Michael
