Next week I will go to the test bench and if possible I will make the comparisons with other exhausts. I am sure that my MHR221 with RD350 valve and 36mm carburetor will exceed 30 hp with this muffler
Bearbeitet von pk_damiano_4hp
Yesterday I tried the muffler, what about ... a real bomb ... the result was that the muffler is perfect for this engine wheel hard to 9000rpm with a high torque.
I will talk about the test bench knowing what values we are talking about but I think it is my goal to get to 30hp is reached.
the sound is higher than normal but is not annoying and in any case is less than the noise produced by the reed valve intake.
I will soon be posting a video.
Tra noi italiani, se tu non ci mostri un grafico della performance reale qui non ti crede nessuno qualcosa :-D  Quando è possibile a vedere uno?
හේයි, අපි දැන් පළ කිරීමට ඔහුගේ ම භාෂාව එක් එක් පටන් ගෙන ඇත? ජර්මානු හා ඉංග්රීසි ඉදිරිපත් නැහැ?
  • Like 3
Unter uns Italienern - wenn Du keine richtige Leistungskurve zeigst, glaubt Dir hier keiner was.
Wann ist es möglich, eine zu sehen?
Habe gerade eben mit Damiano telefonisch besprochen, er hat mir gesagt dass das ding  richtig gut geht, schiebt von unten wie eine LTH box und wo er aufhört (bai ca. 7000 umd.) die neue box noch ein stärker kick hat bis ca. 9000 umd., also der perfekte Auspuff (box) für der malossi membran, diese woche  soll auch ein prüfstandlauf geben, er meint dass nicht auszuschließen ist das der Auspuff auch für DS motoren gut funktioniert, das wird er auch demnächst probieren.
Gut gemacht Damiano.
Maybe you did not read too well because in your eyes the coppainfaccia of 26 May :-D . But I wrote that soon execute a launch at the counter to measure the actual power to the wheel.
I'm not a chatterer, you will in a few days the graph. :cheers:
after megadella XL comes XXL
12246740_1254355821246181_10172061175562
12294755_721384404628986_712242037080209
12308240_721384407962319_748618154668976
12294845_721384391295654_587090195863871
12308487_721384451295648_208877913823952
as far as I'm waiting for the test bench, let me know when I can go to test vespa. Unfortunately my vehicle is too short and must build me a adapter to make sure that the wheel touches the roller; There will be wait next week.
    • Klar...ich mein, wenn Kerzenbild stimmt, das Ding einen guten Leerlauf hat und auch nach dem Gasgeben wieder schön zur Leerlaufdrehzahl zurückfindet bzw fällt, die Verbrennung rehbraun ist und das Teil durchzieht und nicht klingelt...dann ist die Düsengröße am Ende egal.   Zündung spielt auch ein klein bißchen eine Rolle. Wenn Du eine dynamisch verstellbare hast, kann es sein, dass der Motor in manchen Bereichen anders abgestimmt werden will. Vor allem, wenn Du noch bei mehr als 18° bei so um die 6000 u/min bist, sag ich jetzt mal so. Die dynamisch verstellbaren haben die Eigenart genau in dem Bereich, wo man gerne fährt, also so bei 6-7.000 u/min noch nicht komplett verstellt zu haben, je nach dem, wie die Zündung eingestellt ist. Wenn da zum Beispiel noch 19° anliegen, kann das für den Motor nen Tick zu viel sein und er wird heißer, was sich dann auch in einer anderen Bedüsung auswirkt. Ich würde Dir empfehlen, wenn Du ne quasi IDM Zündung fährst, diese so einzustellen, dass Du bei 6.000 schon bei 17° bist. Dann ist das oben raus entspannter. Kann sich dann aber auf die Nadel(position) auswirken.   Ich find ja nach wie vor ne schnöde alte, aber gut gewartete Ducati mit leichtem Polrad super fein
    • Hey. Es wir ja immer von "Fahrtenbuchähnlichen Notizen" oder so gesprochen und nicht vom Fahrtenbuch, wie zB eine Firma fürs Finanzamt benötigt. So handhabe ich das auch, ein kleiner karierter Notizblock wo ich Datum, km und Strecke rein schreib. Ab und zu nehme ich andere Stifte damit es bemüht aussieht : ) Gefragt wurde ich noch nie danache. Weder Kontrolle noch Pickerlüberprüfung. lgT
    • Hab den Motor nicht abgedrückt... Werd ich dann aber wohl müssen.. Würde mich aber echt wundern da ich wirklich peniebel gearbeitet habe und das Dichtmasse, Dichtung, Dichtmasse Prinzip angewandt habe 🤣.      Fahre den Polini R und bin mega überrascht. Lautstärke ist echt ok und er hat ordentlich Dampf unten rum. Würde aktuell bei D22 bleiben da der Motor schön durchzieht.
    • Wie macht ihr das? Hab zwei Roller als Oldtimer typisiert und bis vor ein paar Jahren hat das hier bezüglich Fahrtenbuch keinen interessiert. Seit  ein paar Jahren hab ich dann die App "Oldtimer Fahrtenbuch" von Mostdata benutzt. War recht komfortabel, aber wurde wohl leider eingestellt. Was nun? Kugelschreiber und Heft besorgen?
